#181 | |
I like Green things
Rewards Points: 5,682
Re: Chevy 2500 Crew Cab Long Box GasQuote:
Just measured my door sill height, 26" off the ground. Sent from my SM-N960U using Tapatalk |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
#182 | ||
Trade: General and Trades
Rewards Points: 5,370
#183 |
GC/carpenter
![]() Trade: Decking, Railing, Carpenter/General Contractor
Rewards Points: 1,582
Mine are stainless big difference in price. I've already replaced the plastic step pad on top. Nice that you can replace them.
Mike. _______________ ![]() ![]() |
The Following User Says Thank You to Calidecks For This Useful Post: |
META (02-24-2019)
Sponsored Links | |||
Advertisement |
#184 |
I spent hours trying to find a decent wheel to wheel stainless that would fit this truck. I couldn't find anything that I liked other than just a straight rail.
The Following User Says Thank You to META For This Useful Post: |
Calidecks (02-24-2019)
#185 | |
GC/carpenter
I figured you did. Those you have look nice. Powder coating will last a good while. And they can always be redone for pretty reasonable. Around here anyway. Mike. _______________ ![]() ![]() |
META (02-24-2019)
#186 |
I just got back from towing the 1500 home from the dealer, in a blizzard.
We checked it over briefly, isolated the battery after starting it; it still randomly died after driving it a bit. So, when the weather clears some I'll see what I can do to get it going. |
#187 |
Rack-it is way behind on their orders. Just contacted them today for an update and they are about 2 weeks behind; two more weeks until I get this truck fully functional. That is a drag being I've been stuffing tools in the back seat. It's been about 5 weeks since order.
Sent from my SM-N950U using Tapatalk |
#188 |
Rack finally arrived.
So, I've filled the gas tank about 4 times since purchase. The first three times the tank overfilled and gas ran down the side of the truck. I got pissed after the third time and took it in this week. Turns out the tank isn't burping properly and they need to replace it. They gave me a 2020, 1500 as a loaner. However, the new tank won't be in until Friday, so I got my truck back and will burn down the gas so they don't need to pump 30 gallons out. Hopefully next week they can swap it out. I am getting tired of cramming small tools in the cab...need to get this rack and my boxes installed. ![]() Sent from my SM-N950U using Tapatalk |
#189 |
Rack-it rack and two Weather Guard boxes installed without any bolting through the truck bed or rails.
Most of the rack hardware has been swapped out with stainless. I drilled one hole through each of the four rack uprights (upper area), and used each existing lower hole, to bolt the boxes on. In total, each box has 6 bolts, 2 per upright, and 2 through the bottom incorporating the rail fastening system. They are extremely sturdy. I am very happy with how it all came together. ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-N950U using Tapatalk Last edited by META; 04-04-2019 at 07:03 PM. |
#190 |
The rack did not come with a cross member for over the cab area so I cut a piece of galvanized pipe, painted it black and bolted it in. Rack-it would send an additional powder coated steel bar, but charge $99 shipped to me.
I may put some protection over the upper portions of each cross member being its only a matter of time the powder coating wears off and rust begins. ![]() Sent from my SM-N950U using Tapatalk |
mrcat (04-04-2019)
#191 | |
GC/carpenter
I bought the extra cross member. Mike. _______________ ![]() ![]() |
META (06-23-2019)
#192 |
Trade: Home improvement of all types
Rewards Points: 140
Sweet ride , I’d be scared to take it on a job site .
The Following User Says Thank You to Idothat For This Useful Post: |
A&E Exteriors (04-04-2019)
#193 | |
GC/carpenter
With the weight I haul I was too concerned to not bolt to the bed. I made the plunge. Beautiful rig META. Mike. _______________ ![]() ![]() |
META (06-23-2019)
#194 |
Re: Chevy 2500 Crew Cab Long Box Gas |
Calidecks (04-04-2019)
#195 | |
Trade: Pole Barns, Residential Framing
Rewards Points: 72
Can throw rebar up there now and not worry about scratching the roof when you slide it off. |
The Following User Says Thank You to mrcat For This Useful Post: |
META (06-23-2019)
#196 |
Rewards Points: 72
BTW, how are those steps holding up so far?
#197 |
mrcat (04-04-2019)
#198 | |
Shingler extraordinaire
Trade: Roofing, decks, additions
Rewards Points: 14,290
The Following User Says Thank You to A&E Exteriors For This Useful Post: |
META (04-28-2019)
#199 |
You sell your old rack and boxes yet?
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Come on, Share some pictures of your work... | Dyer | Sandblasting | 577 | 08-22-2015 09:31 PM |
2002 Chevy 2500 Utility | nakarsten | Contractor Swap | 2 | 11-23-2012 10:09 PM |
long term planning question | guardian | Business | 1 | 04-19-2011 12:49 AM |
Crew or Sub work out? | KES | Decks & Fencing | 6 | 10-30-2008 10:32 PM |
Go to Page... |
