Charge Wire For Dump Trailer - Page 2 - Vehicles - Contractor Talk
Old 10-12-2018, 07:09 PM   #21
rrk's Avatar
Rewards Points: 4,858
Re: Charge Wire For Dump Trailer
Originally Posted by dayexco View Post
.run a 4 ott..how the hell you spell that..
4/0
rrk is offline
Randy Bush (10-12-2018)
Old 10-12-2018, 09:25 PM   #22
Box Builder
Morning Wood's Avatar
Rewards Points: 10,368
The plow is using the truck battery which is connected right to the alternator. The dump trailer battery is only connected by a small wire with a 25 amp fuse. Itís not a high charging wire. I think my issue may have been more the battery than anything. But Iím still thinking about a heavier wire in case I run into that problem again. At least itís gravity down.
Morning Wood is offline
Old 10-12-2018, 09:35 PM   #23
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
it's nothing more than a 12 volt motor driving a hydraulic pump...very similar situation to a snow plow...shouldn't really draw much more than a starter motor. i plowed snow 35 years, never did the 2nd battery thing, the alternator always kept up. think the biggest one i had was about 100 amps.
were it me, and you're using that dump repeatedly during the day....run a 4 ott..how the hell you spell that...welder cable from battery to battery. that way the pickup battery can help while it's hoisting.
can't believe it would never keep up.
Originally Posted by rrk View Post
4/0
lololol !!! That's funny !
"aught"
"ought" vs "aught" vs "naught" - oye !
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
mrcat (10-13-2018)
Old 10-13-2018, 12:12 PM   #24
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,588
Originally Posted by Morning Wood View Post
Now the question is: if Iím running both wires together: the factory charge and the heavier wire I install, will the heavier wire back feed current into the factory charge wire since itís running right off the truck batteries and the alternator?
Negative.
The current will split in parallel circuits, proportional to resistance. For a variety of reasons, it's not a good idea to have 2 different wire sizes in parallel.
Old 10-13-2018, 12:15 PM   #25
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Originally Posted by Seven-Delta-FortyOne View Post
Negative.
What variety would that be?
Inner10 is offline
P42003 (10-30-2018)
Old 10-13-2018, 04:15 PM   #26
tjbnwi's Avatar
Rewards Points: 4,012
My truck has the charging wire and it works. It just doesnít have enough charge in it when doing close dump cycles. Thatís why Iím thinking heavier wire to really get a good charge and as backup power if my trailer battery canít keep up with factory charge wire.
The current will follow the path of least resistance. It makes absolutely no difference if you leave the original charging wire connected.
I have a 270 amp alternator on my truck. I run 4ō cable to the batteries and have the factory lead connected also.
tjbnwi is offline
Old 10-13-2018, 04:42 PM   #27
Trade: Highwayman
I'll give you a beginners lesson in electrical theory later. Kinda busy right now.
Old 10-13-2018, 05:10 PM   #28
Inner10's Avatar
Inform me, I know nothing of electricity.
Inner10 is offline
Old 10-13-2018, 05:40 PM   #29
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
I've had a charge wire on my dump trailer since I built it 8 years ago and have never had any issues. I don't dump on a regular basis but it's never let me down.
dave_dj1 is offline
Old 10-13-2018, 06:41 PM   #30
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,495
Originally Posted by Windycity View Post
What about this?
https://youtu.be/KjA33ImEV7Y
http://www.purkeys.net/boss-dump-tra...arging-system/
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
All Materials Supplied ..... How Much Would You Charge Per Sq Ft? vforte Carpentry 1 03-30-2013 04:20 PM
"Wireless" LED Trailer Lights DirtMoverUSMC67 Landscaping 5 10-12-2009 09:19 AM
