-   Vehicles (https://www.contractortalk.com/f41/)
-   -   Charge wire for dump trailer (https://www.contractortalk.com/f41/charge-wire-dump-trailer-412163/)
rrk 10-12-2018 07:09 PM
Originally Posted by dayexco (Post 7385873)
.run a 4 ott..how the hell you spell that..
4/0
Morning Wood 10-12-2018 09:25 PM
The plow is using the truck battery which is connected right to the alternator. The dump trailer battery is only connected by a small wire with a 25 amp fuse. Itís not a high charging wire. I think my issue may have been more the battery than anything. But Iím still thinking about a heavier wire in case I run into that problem again. At least itís gravity down.
SmallTownGuy 10-12-2018 09:35 PM
it's nothing more than a 12 volt motor driving a hydraulic pump...very similar situation to a snow plow...shouldn't really draw much more than a starter motor. i plowed snow 35 years, never did the 2nd battery thing, the alternator always kept up. think the biggest one i had was about 100 amps.
were it me, and you're using that dump repeatedly during the day....run a 4 ott..how the hell you spell that...welder cable from battery to battery. that way the pickup battery can help while it's hoisting.
can't believe it would never keep up.
Originally Posted by rrk (Post 7385881)
4/0
lololol !!! That's funny !
"aught"
"ought" vs "aught" vs "naught" - oye !
Seven-Delta-FortyOne 10-13-2018 12:12 PM
Originally Posted by Morning Wood (Post 7384097)
Now the question is: if Iím running both wires together: the factory charge and the heavier wire I install, will the heavier wire back feed current into the factory charge wire since itís running right off the truck batteries and the alternator?
Negative.
The current will split in parallel circuits, proportional to resistance. For a variety of reasons, it's not a good idea to have 2 different wire sizes in parallel.
Inner10 10-13-2018 12:15 PM
Originally Posted by Seven-Delta-FortyOne (Post 7386207)
Negative.
What variety would that be?
tjbnwi 10-13-2018 04:15 PM
My truck has the charging wire and it works. It just doesnít have enough charge in it when doing close dump cycles. Thatís why Iím thinking heavier wire to really get a good charge and as backup power if my trailer battery canít keep up with factory charge wire.
The current will follow the path of least resistance. It makes absolutely no difference if you leave the original charging wire connected.
I have a 270 amp alternator on my truck. I run 4ō cable to the batteries and have the factory lead connected also.
Seven-Delta-FortyOne 10-13-2018 04:42 PM
I'll give you a beginners lesson in electrical theory later. Kinda busy right now. :blink: :jester:
Inner10 10-13-2018 05:10 PM
Inform me, I know nothing of electricity.
dave_dj1 10-13-2018 05:40 PM
I've had a charge wire on my dump trailer since I built it 8 years ago and have never had any issues. I don't dump on a regular basis but it's never let me down.
Leo G 10-13-2018 06:41 PM
Originally Posted by Windycity (Post 7384067)
What about this?
https://youtu.be/KjA33ImEV7Y
http://www.purkeys.net/boss-dump-tra...arging-system/
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
