Can You Mount An Underbody Box On Top? - Vehicles - Contractor Talk
Old 10-15-2018, 09:20 AM   #1
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,190
What would happen? Do they leak if installed on top of a flatbed, for example?
Old 10-15-2018, 10:50 AM   #2
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 926
Re: Can You Mount An Underbody Box On Top?
I would think as long as it is a weather tight box, you could mount it anywhere.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
Seven-Delta-FortyOne (10-15-2018)
Old 11-26-2018, 12:37 PM   #3
Trade: Highwayman
I now have toe answer to this, just in case anyone else wants to do the same.
Yes you can mount them on top, but you'll have to raise them about 2 inches or so, so that the door will open. I used Uni-Strut for mine.
Seems that only difference between under-mount and topside, is the door swing.
The only reason I wanted an undermount, is because of the size, that only came in an undermount version.
So it worked.
tgeb (11-26-2018)
Old 12-22-2018, 09:17 PM   #4
51carpenter's Avatar
Trade: Carpenter Contractor
Rewards Points: 444
I love the undermount boxes. Iíve got them in front of and behind both tires.
I donít pack much for tools with me, because I have the tool wagon on site usually.
I like having the bed open for forklifting material on at the lumber yard.
I see lots of rigs with boxes on top though, dirt work, loggers. It seems like everyone else is switching to vans.
Professional wood welder
51carpenter is offline
TV Mount with metal studs Easy Gibson General Discussion 50 02-19-2014 04:44 PM
Weather Proof Fan Mount Boxes tenon0774 Electrical 7 06-17-2013 10:43 PM
Mount Prospect contractor E&D_Remodeling New Member Introductions 1 04-06-2013 09:29 PM
Top mount door hinges elementbldrs Finish Carpentry 3 01-21-2013 11:41 AM
Wall Mount tub faucets. Why don't they make um. crazygirl Plumbing 11 07-28-2011 09:19 AM
