1999 F350 - Vehicles - Contractor Talk
1999 F350
Old 09-07-2014, 09:01 PM   #1
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
1999 F350
I've been looking at trucks for awhile with more pulling power and came across a 99 f350 dually with the 7.3 Diesel engine. 177k miles for $6100.00. The body is in decent shape.
Any major issues with this engine?
BamBamm5144 is offline
Old 09-07-2014, 09:03 PM   #2
The Sheriff
Jaws's Avatar
Trade: Builder
Rewards Points: 15,344
Re: 1999 F350
Its a bad ass engine imo. My ex boss from 12 years ago still has one running around that must have 500k miles on it.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
The Following 2 Users Say Thank You to Jaws For This Useful Post:
BamBamm5144 (09-07-2014), Big Shoe (09-12-2014)
Old 09-07-2014, 09:15 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,838
Re: 1999 F350
It's ok. with 4.11 gears you will get 10-11mpg. The engine may last, but when something goes wrong, they are not cheap to work on.
At 177k you are probably close to injectors, maybe a turbo and a couple other minor things. I think injectors are about 3k to change out.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 09-07-2014, 09:58 PM   #4
Patrick's Avatar
Rewards Points: 2,364
Re: 1999 F350
Tranny been rebuilt or replaced yet? Engines GREAT, its everything else lol
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 09-07-2014, 10:58 PM   #5
tjbnwi's Avatar
Rewards Points: 4,096
Re: 1999 F350
I have 300K on my 2000 Excursion 7.3. Not a single thing listed above has been replaced. I did break a ring gear, wheel hop can do that.
tjbnwi is online now
Old 09-07-2014, 11:01 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 1,982
Re: 1999 F350
I had a 99 F350, 7.3.
Had a couple of injector problems.
Ran like a bat out of he!!....
griz is online now
Old 09-07-2014, 11:18 PM   #7
dougger222's Avatar
Trade: Roofing Contractor
Rewards Points: 1,116
Re: 1999 F350
That's a really low price with decent miles. How it set up auto tranny? X-cab, reg-cab, crew-cab? 4wd? XL, XLT, Lariat?
If it's a crew cab and at least an XLT 4x4 with minimal rust and you don't buy it send me the link to it!
I have 4 of them with 1,100,000 miles combined and only the 99 dually has needed injectors. The 99srw with 338K miles is still running all 8 factory installed injectors. Never removed the heads off any of them. As far as trannies the SRW is on it's third. Put a tranny in the dually for the first time last Summer, got real stuck at the dump burnt it up. The 265K 00 X PSD and 294K 02 X PSD are still running the original tranny and they run cool.
All of them get everything synthetic and all have a second and the dually a third aftermarket tranny cooler. The older 3 all have tranny temp gauges. They are all old, have rust, BUT THEY ARE ALL PAID FOR!
The SRW needs a rear drive shaft but given the miles not surprised much. For several years it towed the dump trailer. Speaking of towing you can't go wrong with a dually...
dougger222 is offline
Old 09-07-2014, 11:22 PM   #8
dougger222's Avatar
Re: 1999 F350
Also,
The 01-03 7.3 got powdered metal internals while the 94-00 got forged rod internals.
IMO the late 99's and 00's are the ones to have. My DRW has a build date of 4/99 and the SRW a build date of 6/99 making them late 99's.
Old 09-07-2014, 11:58 PM   #9
General Contractor
Doctor Handyman's Avatar
Rewards Points: 418
Re: 1999 F350
I have a 2002 f350 with 201,000. Had the High Pressure Oil Pump leak so did a new gasket myself about 50k miles ago. Replaced 4 injectors on driver side this year for $1600 ( separate instances). Steering is a little loose even after new gear box (Redhead), tie rods and pitman. Already installed new hubs and ball joints. Pretty typical for Ford, but I think the 6" lift and 37" tires contribute to the advanced wear.
Gets 12mpg. Crew cab long bed, 4x4. 85% city driving. Tows like a beast but plan on u-joints and pinion seals. It has required relatively little service since I have owned in past 10 yrs.
Change the oil every 5k and your golden. I screwed up last year and went 17k w/o oil change and think that is why my injectors took a dump.
It is a very reliable engine with minimal maintenance. But when repairs need to be done your talking $$$.
Doctor Handyman is offline
Old 09-08-2014, 06:31 AM   #10
dougger222's Avatar
Re: 1999 F350
When I ran conventional diesel oil went 10K miles between oil changes. With synthetic oil go 20K miles between changes.
The fuel mileage on my dually is not the greatest either, 11-14mpg. It tows mainly so it's around 10-11mpg.
On the other hand the Excursion get in the high teens.
I don't feel the cost of repairs are too bad for these vehicles. Over the years the parts have come down in cost and there's tons of used options out there. Running a 7.3 will cost you a fraction of running a 6.0!!!
Old 09-08-2014, 08:52 PM   #11
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Re: 1999 F350
My 7.3 is at the shop getting a new y-pipe and 2 injectors it has 138k.
rex is offline
Old 09-08-2014, 09:58 PM   #12
Talking Head
EthanB's Avatar
Rewards Points: 438
Re: 1999 F350
I have the e350 with a 7.3 and usually get 14-15mpg with a running weight of 9k lbs. 185kish miles. I think the engine alone is probably worth around $3-4k.
Planer.....
EthanB is offline
Old 09-08-2014, 10:34 PM   #13
VinylHanger's Avatar
Rewards Points: 13,022
Re: 1999 F350
I just had my 2001 into the ture shop to check alignment and a clunk underneath.
Perfect alignment and the clunk looks to be a bad shock. 214,000 miles.
I've had it since 170,000 miles and have done 7 and 8 injector, both injector harnesses, alternator, water pump and power steering pump.
It does cost a bit more to fix them, bit you have a lot of truck after you do. I hope to keep this one for a long time. The new Fords are looking pretty good though. I'll probably get me a brand new 2015 in 2022 or so.
VinylHanger is online now
Old 09-10-2014, 03:13 PM   #14
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Re: 1999 F350
How good a used 7.3 is really depends on how previous owner/s ran and maintained the truck.
I got mine with 95k, and I had to completely rebuilt the tranny @ 110k. Other than that nothing major has happened. I always do Regular oil changes and fuel filters..I have an oil air filter and periodically clean that too. I keep the egt and tranny temps within safe operating range, I always let the turbo cool after a tow by letting it idle for 10 mins. These trucks will last a long time if cared for properly.
Btw, I get way better than 10-11mpg...closer to 14-15 city and I consistently get 18 on the highway..but it's very flat in this part of SC.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 09-10-2014, 03:44 PM   #15
I like Green things
Re: 1999 F350
Then you either have a 2wd and most definitely not 4.11 gears.
Warner Mill Works
Facebook
YouTube
Old 09-10-2014, 03:54 PM   #16
Trade: Stonemasonry
Re: 1999 F350
Nope..4x4 dwr. And 8 years of constant testing. That's not every tank, but fairly consistent.
Old 09-10-2014, 03:59 PM   #17
I like Green things
Re: 1999 F350
Gears?
Warner Mill Works
Facebook
YouTube
Old 09-10-2014, 04:04 PM   #18
Trade: Stonemasonry
Re: 1999 F350
Actually, the mpgs were closer to what you posted when I lived in CT. 'City' driving in rural SC is more like highway up there.
Old 09-10-2014, 04:12 PM   #19
Trade: Stonemasonry
Re: 1999 F350
Originally Posted by WarnerConstInc. View Post
Gears?
I've always assumed 4.10 because it's drw. 4.11? Didn't know that was an option.
Old 09-10-2014, 04:16 PM   #20
I like Green things
Re: 1999 F350
I have driven a 97 and 01, both got 10.5 loaded or unloaded.
My uncles 99 7.3 in his 450 gets 7.
To get decent milage they need 3.53 or 3.73 tops.
Warner Mill Works
Facebook
YouTube
1999 Bobcat 763F Skidsteer with 1200 hours - Cab/heat, hi-flow, new tires arbor pro Contractor Swap 0 07-02-2012 12:59 PM
Box body on F350 pickup frame? smitty58 Vehicles 6 01-04-2012 07:52 AM
1999 Ford f150 v6 andeeznuts Tools & Equipment 3 02-23-2011 06:51 PM
F/S: 1999 Jeep Cherokee Sport BreyerConstruct Contractor Swap 1 09-30-2009 08:08 AM
Paslode f350 major air leak HRUBY Tools & Equipment 4 03-01-2009 06:53 PM
