'06 6.0 Powerstroke Long Crank To Start - Vehicles - Contractor Talk
Unread 06-29-2020, 10:06 PM   #1
Fire up the BBQ
griz's Avatar
Rewards Points: 2,312
Extremely intermittent & no codes thrown.
it always starts.
it has always fired right up when i hit the starter.
warm or cold and no telling when or why.
any ideas?
EGR valve, EGR cooler(Bullet proof diesel) & oil cooler being replaced next week. Turbo will also be checked out.
any ideas????
griz is offline
Unread 06-29-2020, 10:14 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,806
Re: '06 6.0 Powerstroke Long Crank To Start
My first guess would be an injector issue.
But I'm a nail bender, not a mechanic, so take that for what it's worth.
But I did have that same issue with my powerstroke, and it was injectors.
Bathe 'Em, Baptize 'Em, and Brand 'Em.
Unread 06-29-2020, 10:25 PM   #3
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 11,861
Weak fuel pump. Turn the ignition on without starting it. Wait 10 seconds and see if it starts normally.
If it does it's one of two possibly, weak pump, leaky fuel system.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Unread 06-29-2020, 10:29 PM   #4
tjbnwi's Avatar
Rewards Points: 4,608
Change both the batteries. Check the charging system also.
tjbnwi is offline
Deckhead (Today)
Unread 06-29-2020, 10:34 PM   #5
LRG WoodCrafting
Leo G's Avatar
Oof... diesel.
count me out.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Unread 06-29-2020, 10:39 PM   #6
Fire up the BBQ
griz's Avatar
new batteries, 30 days old, check out good.
griz is offline
Unread 06-29-2020, 11:11 PM   #7
Stunt Carpenter's Avatar
Rewards Points: 2,880
Did it start after the new batteries?
John Wood who used to be on here had a V10 that would do that if the battery got disconnected for any reason. Would last a few weeks then be fine again.
https://builddaley.com/
Stunt Carpenter is offline
Unread 06-29-2020, 11:14 PM   #8
Fire up the BBQ
griz's Avatar
yes, just fine. then started the intermittent thing again.
griz is offline
Unread Yesterday, 05:17 PM   #9
rustyjames's Avatar
Rewards Points: 1,830
If it's doing it hot or cold I'd have to speculate fuel delivery issue.
rustyjames is offline
Unread Yesterday, 08:31 PM   #10
pizalm's Avatar
Rewards Points: 832
Could be a failing hpop (High pressure oil pump) or issue with the system. It won’t build enough pressure to fire the injectors.
pizalm is online now
The Following User Says Thank You to pizalm For This Useful Post:
Deckhead (Today)
Unread Yesterday, 09:37 PM   #11
Trade: Highwayman
Forgot about the HPOP. Been in a Cummins for so long.
That's exactly what my '04 PowerStroke did right before the HPOP finally bought the farm late one night.
Not a cheap repair. It's in the botttom of the engine.
Unread Today, 06:21 AM   #12
tgeb's Avatar
Rewards Points: 1,032
I asked a friend who works on the 6.0 fairly frequently.
He said the ICP sensor and the wire pigtail.
The FICM.
The camshaft position sensor.
The HPOP.
www.gebcon.com
tgeb is online now
