Watch Your Trailer Weights! - Tools & Equipment - Contractor Talk
Old 04-15-2013, 09:02 AM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Just went through scales and calculated some things.
Trailer and truck weight 12040lbs
Trailer weights 5740lbs
Truck weights 6300lbs
Trailer max payload 4550lb as spec'd
So I have to clear 1200lbs of weight from my trailer! guess I'm gonna have to remove some stuff from it. Beware guys as some of you lot with single axles and longer dual axle trailers may be well over your capacities if you get pulled. I can't believe I'm that much over.
www.bcconstructionllc.com
BCConstruction is offline
Old 04-15-2013, 09:12 AM   #2
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
Re: Watch Your Trailer Weights!
It's amazing how fast things add up.
That's why my trailer purchase in the near future is speced with 10k axels and radial tires.
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Old 04-15-2013, 09:17 AM   #3
Trade: Construction
Yeah I only have 7000lb axles and I thought they would be more than enough. It's gonna be hard losing that many lbs worth of tools.
Old 04-15-2013, 09:49 AM   #4
Ciaos mitigator
chris klee's Avatar
Rewards Points: 1,290
wow, you do have a pretty heavy trailer. i am surprised your truck is that heavy also.
i often wondered if i load up a 16' with shelves and tools how much it would weigh?
CK Carpentry
chris klee is offline
Old 04-15-2013, 09:57 AM   #5
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,860
If the payload of your trailer is 4500 pounds, what does the trailer weigh? I don't think it is over loaded.
I think you are close, but I think the math is not quite right.
Heaviest I have been over scales with my 2500 Burban and equipment trailer was 21000 pounds.
Shhhhh, don't tell everyone though.
I agree, that is a heavy 1/2 ton ford.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 04-15-2013, 10:01 AM   #6
Trade: Construction
Just put the truck though the scales on its own. I was a couple hundred off with my hand calculations. The trucks curb weight is 6520lbs with half a tank of fuel.
Trailer weights 2340lbs dry.
What's crazy is if i bought the single axle version I would have 1160lbs payload! You would hit that limit extremely quickly.
Old 04-15-2013, 11:37 AM   #7
Remodeler
TAHomeRepairs's Avatar
Rewards Points: 574
My trailer reads a gross weight of 2980, and the trailer empty is like 1850 on the paper work. So it gives me barely 1100 #. Its a single axle. Axle is a 3500# I keep 6 ply radials on it. Rides real good at around 4000+.........also I have no lettering anywhere, so that may work to my favor.
TAHomeRepairs is offline
Old 04-15-2013, 12:18 PM   #8
cpuhrmann's Avatar
Rewards Points: 25
Attachment 90454
You are fine on your trailer if it is 7000 gvw and it weighs with payload at 5740 you could add 1260 lbs to be right at 7000lbs. Trailer payload is the amount of cargo you can carry not cargo and trailer combined.
cpuhrmann is offline
The Following User Says Thank You to cpuhrmann For This Useful Post:
TAHomeRepairs (04-15-2013)
Old 04-15-2013, 12:28 PM   #9
Trade: Construction
Gvwr means trailer and load combined. Same as it does on a vehicle. You have to delete your curb weight from your GVWR then what ever is left is your payload capacity.
Ok I get what your saying. Seems my math is crap lol. Panic over I can add more tools lol
Right I see where I went wrong I forgot to take away the weight of the trailer from the total to get my current payload
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 04-15-2013, 12:35 PM   #10
cpuhrmann's Avatar
Rewards Points: 25
Correct
Old 04-15-2013, 12:44 PM   #11
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
never mind was correcting math lol
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Old 04-15-2013, 12:52 PM   #12
rrk's Avatar
Rewards Points: 5,688
Right up until you get into and accident and they decide to weigh your trailer, then you are screwed. Insurance won't cover you then. I know someone who had this problem. He is still paying.
The 2990 gvw is so they don't need brakes on the trailer if I remember correctly. Anything over 3000 needs brakes.
rrk is online now
Old 04-15-2013, 12:54 PM   #13
Remodeler
Rewards Points: 574
That's correct with the brakes
Old 04-15-2013, 01:00 PM   #14
Joasis's Avatar
Rewards Points: 1,982
Just a matter of time until every trailer will get tagged and weighed, and ignorance of the law will not be an excuse. This is more about revenue then safety, although the DOT will tell you it is all about safety while they write tickets totaling thousands because you didn't know.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 04-15-2013, 04:35 PM   #15
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
Too bad you were not a little closer. Then you could have rearranged it a bit to have more tounge weight.
smeagol is offline
Old 04-15-2013, 04:38 PM   #16
Remodeler
Rewards Points: 574
Huh?
Old 04-15-2013, 07:39 PM   #17
Manager/Diplomat/Builder
darthdude's Avatar
Trade: Lead Carpenter
Rewards Points: 392
His point is that if you load heavier items towards the front of your trailer, some of their weight is transferred to the rear axle of the truck. FYI a general rool of thumb, if that no matter how heavy your trailer, 20% or more should be tongue weight.
darthdude is offline
The Following User Says Thank You to darthdude For This Useful Post:
Old 04-15-2013, 07:53 PM   #18
Box Builder
Morning Wood's Avatar
Rewards Points: 10,404
Yeah. You have to be careful with those single axle trailers. I went across the scale at the gravel pit with 5 yards of crushed stone. 22660 total. Not bad with my truck and dump trailer. Don't have an empty weight so I don't know if I was overweight or not. Probably slightly.
Morning Wood is offline
Old 04-15-2013, 08:08 PM   #19
tjbnwi's Avatar
Rewards Points: 5,106
Actually it is 10%. The same as the hitch total load, tongue weight load differential.
Also all ratings are for a properly equipped vehicle. The more weight you place on the rear axle, the more weight you take off the steering axle, that's a bad thing. A proper load distributing system splits the load between the axles.
tjbnwi is online now
Old 04-15-2013, 08:18 PM   #20
txgencon's Avatar
Rewards Points: 468
I used to pull my 10,000 GVWR dump trailer with a 3/4 ton van.
The first time I went to the dump, I had two 2600 pound transformers in the back of the van and a load of scrap drywall in the trailer. On the way in, I weighed 16,800 pounds. On the way out, I weighed 11550 pounds. This established my "empty weight" of 11550 for the van/trailer combo. So, the next time to that dump, I could just weigh and pay on entry.
On the next trip to the dump, I had the trailer piled high with some shipping boxes, pallets and other fairly lightweight stuff. On the way in I weighed 10,420.
Ooops.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Estimating with Excel for the Small Contractor YouTube cargin2 Business 127 12-09-2019 12:06 PM
What tow vehicle do you think would be best for a mobile blasting trailer? Blast Off Sandblasting 0 03-06-2013 02:06 PM
Trailer size & Truck size(towing capacity) Dmitry Vehicles 19 01-24-2013 09:30 PM
for all you watch guys opiethetileman Off Topic (Non Trade) 6 09-09-2011 07:08 PM
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
