Use Your Track Saw Today? - Tools & Equipment - Contractor Talk
Old 03-19-2015, 05:20 PM   #1
BradingCon's Avatar
Rewards Points: 740
Ok guys. I'm about to pull the trigger on a track saw but I need a gentle nudge. Did you use your track saw today? And for what purpose? The responses will give me the needed push I'm sure.
BradingCon is offline
Old 03-19-2015, 05:26 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 350
Re: Use Your Track Saw Today?
I haven't used it in a month, but I am so glad that I own it. We were talking about it with another carpenter today who does not have one.
Easy Gibson
Warren is offline
Old 03-19-2015, 05:29 PM   #3
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
No, not used it for a while, but buy it anyway...
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 03-19-2015, 05:32 PM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Just buy it and once you need it you will be glad you have it.
www.bcconstructionllc.com
BCConstruction is offline
Old 03-19-2015, 05:32 PM   #5
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
Used it today to cut some crazy tapered extension jambs.
Like butta........
BlueRidgeGreen is offline
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
Spencer (03-19-2015)
Old 03-19-2015, 05:35 PM   #6
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Travis, just do yourself a favor and pull the trigger.
I did use it today. Worked on a crappy rental property.
Cut down probably 6 doors. Cutting down doors with a track saw is wonderful. The dust collection is also wonderful.
I had a couple extension jambs that were way different so I used it to taper them. Can't beat the track saw for a long 80" taper.
Then I had a real screwed up situation where the previous homeowner installed windows that had been installed on a previous home...so the extension jambs were already screwed onto the window anywhere from 1/2" to 1-1/2" proud of the drywall. The walls were all screwed up so they were all tapered. I was able to mark the jambs, remove the screws that held the whole deal to the window, and cut it with my 55" track. It was a little tricky but super fast compared to disassembling the whole thing, making tapered cuts on the table saw, and reassembling.
So yeah, I was glad I had it today.
Spencer is offline
Old 03-19-2015, 05:37 PM   #7
Jswills76's Avatar
Trade: custom carpentry
Rewards Points: 836
I got mine 2 weeks ago. First day I used it I thought it was a waste of money. The next day I started to like it. I'm glad I bought it. I have the makita, dust collection is alright, and a little under powered
Jswills76 is offline
Old 03-19-2015, 05:42 PM   #8
Trade: Construction
What was you cutting for it to feel under powered?
Old 03-19-2015, 06:02 PM   #9
Livin the dream...
Spencer's Avatar
Travis, another thing, I bought a hose off amazon that worked with the festool track saw and regular ridgid shop vac when I first bought my festool. Its nice if you don't want to drop the coin on a festool vac right now.
http://www.amazon.com/Bosch-VAC005-5...+shop+vac+hose
Spencer is offline
The Following 2 Users Say Thank You to Spencer For This Useful Post:
alboston (03-19-2015), BradingCon (03-19-2015)
Old 03-19-2015, 06:34 PM   #10
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Yup. Cut up some plank flooring in an outside storage building to access underneath. Could I have made marks, snapped a line, and cut with a circular? Absolutely. But I got a perfectly straight cut with less time spent.
Used it a couple days ago cutting field deck boards to run a border around the perimeter. Way easier than lining up ends and cutting them ahead of time.
Buy it, and you will use it. If you are looking for ways you're not used to, you will find lots.
Xtrememtnbiker is offline
Old 03-19-2015, 06:51 PM   #11
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
I used mine to cut a top of a door insitu that was rubbing on the jam. didnt even pop it off the hinges
Anderson is offline
The Following User Says Thank You to Anderson For This Useful Post:
CarpenterSFO (03-19-2015)
Old 03-19-2015, 06:56 PM   #12
schaefercs's Avatar
Rewards Points: 520
I have that hose which I use with the Festool y adapter for my ct26. When I'm set up in one area, two hoses saves a lot of time hooking up two tools at once. For 35 bucks, absolutely worth it.
schaefercs is offline
The Following User Says Thank You to schaefercs For This Useful Post:
Old 03-19-2015, 07:01 PM   #13
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 350
I was pretty skeptical as well, but haven't looked back. It's the right tool for so many jobs. You won't regret the purchase.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Old 03-19-2015, 07:08 PM   #14
Raawwwrrrr
blackbear's Avatar
Trade: finish carpentry
Rewards Points: 1,394
All day, everyday. Would be lost without it.
blackbear is offline
Old 03-19-2015, 07:09 PM   #15
CarpenterSFO's Avatar
Rewards Points: 2,044
Almost every day for the last 2 months, including today, in a retail remodel: shelves, benches, floor transitions, display walls, tapered jambs, floor edges, miscellaneous boxes and covers. Today was floor transitions and shelves.
We finish up tomorrow, then it's on to a bath and kitchen remodel where it will see less work.
The magical tools in this job were the track saw, the Fein multi-tool, the cordless finish nailer, and my new cordless impact driver.
- Bob
CarpenterSFO is offline
Old 03-19-2015, 07:15 PM   #16
BradingCon's Avatar
Rewards Points: 740
I knew I came to the right place. Thanks for the suggestions on uses.
Old 03-19-2015, 07:22 PM   #17
Jswills76's Avatar
Rewards Points: 836
Reclaimed barn lumber
Old 03-19-2015, 07:41 PM   #18
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,437
Brought it with me to my last install. Didn't need it. But always glad I bring it. If you need it, you need it and it works great.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 03-19-2015, 07:48 PM   #19
m1911's Avatar
That's another tool that gets used as much, if not more than, a track saw, and one of those tools that once you have it, you wonder where it was all your life.
m1911 is offline
The Following 2 Users Say Thank You to m1911 For This Useful Post:
CarpenterSFO (03-19-2015), Robinson1 (03-19-2015)
Old 03-19-2015, 08:06 PM   #20
Gumphri's Avatar
Trade: Carpenter/Timberframer
Rewards Points: 142
Trimming countertops, window sills, cabinet fillers, and cutting doors this week. It paid for itself on the first job I was on. It is one of those tools that once you have you don't understand how you lived without it.
Gumphri is offline
Another Track saw hits the market. TBFGhost Tools & Equipment 14 01-09-2013 11:24 AM
exterior metal frame wall advice Spike7 Framing 7 01-09-2013 10:49 AM
Steel framing: fixing studs to track, overhead UpNorth Framing 1 06-06-2010 05:34 PM
The House of Tomorrow from the Recession Today NC2X4 General Discussion 11 02-28-2009 05:05 PM
