TStak Set Ups - Page 3 - Tools & Equipment - Contractor Talk
TStak Set Ups
Thread Tools
Old 06-02-2014, 10:51 PM
mobiledynamics's Avatar
Trade: engineer
Rewards Points: 681
Re: TStak Set Ups
Tony -
I compared the 2 briefly. Given how I use my boxes, I stuck with the Tough as they are that much tougher. I can see how one could see the weight as a issue.
mobiledynamics is offline
Old 06-02-2014, 11:47 PM
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: TStak Set Ups
Originally Posted by pinwheel View Post
I'm 240 & I used 2 tall drawer boxes & one deep box as a chair at lunch today. No flex whatsoever.
it's all about proper load distribution!
m1911 is offline
The Following User Says Thank You to m1911 For This Useful Post:
pinwheel (06-03-2014)
Old 06-03-2014, 04:23 AM
tonylumps's Avatar
Trade: carpenter
Rewards Points: 347
Re: TStak Set Ups
Originally Posted by mobiledynamics View Post
Tony -
No doubt about that. But I found that after loading the boxes with tools I needed a tool tote or tool bag because they where that heavy.The tough box setup with the cart is good for a Carpenter gang instead of just a one man operation I think.
tonylumps is offline
Old 06-10-2014, 08:26 PM
white_lightning's Avatar
Rewards Points: 64
Re: TStak Set Ups
I picked up some more boxes .
I'm starting to love them .
I just need more . The One thing I don't like is there is no middle sized box.
The festool inserts fit perfect in boxes with no movement.
white_lightning is offline
Old 06-11-2014, 09:50 PM
Unger.const's Avatar
Rewards Points: 3,060
Re: TStak Set Ups
On the clear lid box. I needed a little more room then the factory had it. So I popped out the tray and cut out the section under the 7 removable cups
Takes a few seconds to figure out how to remove it.
After cutting it out and relocking it in. Here I can put in a M12 fuel hackzall , M12 right angle drill, M12 dremel tool, M12 fuel impact driver. M12 3/8 ratchet, and an M18 multi tool.
Pull the front lid latch (silver metal part) out from the box causing the plastic to bow out releasing these two tabs (at the end of my pinky and index finger) you may have to wiggle the tray a little to get the front side let loose. Then same with other front latch. Then lift front of tray up till back releases
The reason for keeping the rim of the tray is that these side compartments and the bit holder (center front) are trapped closed by the lid being closed. Thus the small parts/bits aren't playing hide and seek with you everyday.
Click image for larger version
Sometimes I need the square cups to have a lid. And the tray wouldn't allow the lid of main box to close if in place. (Cup lids came from the drawer unit tstak) . Some of my smaller tools won't fit in the smaller boxes. Or the pipe thread paste. Or small glue tubes. In the back right corner cup I have two chalk reels. One with permanent chalk. The other with light chalk so as not to leave a permanent line on a project if needed. The cup keeps the two together without chalk dust all over everything.
Unger.const is offline
Old 06-17-2014, 10:41 PM
cashishift's Avatar
Trade: Demo
Rewards Points: 150
Re: TStak Set Ups
I'll have to take some pictures of how I am using mine.
Currently still building them up. I have a Long Top Handle, 2 drawer, and a basic open one.
Will be putting a Bosch jig saw into the open top one.
I wish they offered some more flexibility with the boxes that have drawer storage or containers.
Might have to dream up something.
cashishift is offline
Old 06-25-2014, 07:30 PM
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Re: TStak Set Ups
The tough box really lets you load up. Probably more than you should. Honestly, the x large box, should not be loaded with compact tools, just bulky tools. I estimate you'd probably be able to pack it with 10000 4" nails easily with room for your lunch. Not saying you should, as that would be like a 300 lb box. The cart is definately heavy duty compared to the tstak, but you'd more likely scratch up finished floors with it compared to the tstak with the forward wheels. But, it does offer a tool lock feature, which is not great security, but it does prevent the "can I borrow a...." from borrowing it while your out.
madmax718 is offline
Old 06-26-2014, 04:25 AM
tonylumps's Avatar
Trade: carpenter
Rewards Points: 347
Re: TStak Set Ups
The Tough box for sure is a Tough Sturdy System if that is what you need. I bought it and it does not work for me. I went with T-Stack. Not as durable. Not water proof.But it works out better because of the smaller and lighter boxes I think they are a better alternative than Festool boxes witch I have a couple of .I don't know about L boxes even though all of my battery tools are Bosch.
Old 09-22-2014, 10:38 PM
Re: TStak Set Ups
Got some tough boxes to blend with my tstaks.
The Following User Says Thank You to Unger.const For This Useful Post:
thezoo (09-23-2014)
Old 09-23-2014, 07:38 AM
thezoo's Avatar
Rewards Points: 238
Re: TStak Set Ups
That's a nice setup, diamondback cover, nice bedd slider, looks organized and pro.
thezoo is offline
The Following User Says Thank You to thezoo For This Useful Post:
Unger.const (09-24-2014)
Old 10-14-2014, 05:42 PM
Re: TStak Set Ups
Rainy day.......might as well get a little more organized
As with my tstaks trying to figure out how to interchange some of the tough boxes. The medium-sized box will fit under my cover but the large is just an inch to tall. So in order to fit I would have to lay it on its face to fit. I wanted the large to fit my suspendavest tool belt in. As the medium didn't seem to alow it to fit.
The little tool carrier in the back of the large unit (finger in pic showing where yellow tool carrier use to be) will fit in the medium unit. And still allows tray (shown in second picture) to fit. Downside is that taller tools may not fit with lid down.
I was hoping I could swap the lid of the small box with that of the large. It would reduce the hight to just fit under truck cover. Unfortunately the width of all boxes are the same but the depth of the large box is an inch plus of the small and medium.
My puppygirl 'Whiskey' isn't being helpful either. But she is cute so I added a picture of her before she chews on some tools for sport.
TStak Set ups-forumrunner_20141014_154115.jpg   TStak Set ups-forumrunner_20141014_154252.jpg   TStak Set ups-forumrunner_20141014_154435.jpg
Old 11-27-2014, 06:55 PM
maxwage's Avatar
Trade: Commercial Construction
Rewards Points: 791
Re: TStak Set Ups
Originally Posted by Unger.const View Post
So buy swapping the tops of middle and left box. It will make the new hybrid tstak
on the right.....
On the back side the hinge is TWO small metal rods the make one long hinge pin (same concept as a piano hinge) push one side just enough to send the hinge pin out the other side. Grab wire/pin with pliers and pull. This will leave other pin in box. Go up under center of hinge and chase the first pin back (the one you shoved in to shove out other pin you grabbed with pliers.) Thru the small slots of plastic it will be evident once you see how it works
Absolutely genius!!!!
I am investing in the TStak system and it is on my Xmas list from family members. I am definitely stealing this idea.
I'm a beast at everything I do.
I buy tools. Not brands.
maxwage is offline
The Following User Says Thank You to maxwage For This Useful Post:
Unger.const (11-28-2014)
Old 11-28-2014, 09:25 AM
Tom M's Avatar
Rewards Points: 668
Re: TStak Set Ups
Im very happy with my Tstaks as well, I may get a couple of more drawer bins
Tom M is offline
Old 11-29-2014, 09:36 PM
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
Re: TStak Set Ups
funny how many guys are running the dewalt box setups but are running milwaukee gear lol
i have the bosch lboxxs and some of the dewalt tough boxes.. they house milwaukee m12 cordless. makita 18 cordless gear or bosch / makita routers, multitools and jigsaws
woodworkbykirk is offline
Thread Tools
Rate This Thread
Dewalt TStak Storage System MLCcarpenter Tools & Equipment 90 05-12-2016 11:01 PM
