TS55 REQ Recall - Tools & Equipment - Contractor Talk
TS55 REQ Recall
Old 07-10-2013, 07:48 PM   #1
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
TS55 REQ Recall
You should see tomorrow that the saw is being recalled due to the fact that the blade is not retracting correctly.
Supposedly all saws are affected
Anderson is offline
Old 07-10-2013, 10:21 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,868
Re: TS55 REQ Recall
That seems to be a rumor. I can't get any confirmation from my sources.
I have been told of some cases about that, but it was quickly resolved.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 07-10-2013, 10:28 PM   #3
Anderson's Avatar
Re: TS55 REQ Recall
They have already taken them off the shelves today and will release info tomorrow.
Anderson is offline
Old 07-11-2013, 05:58 AM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: TS55 REQ Recall
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Dirtywhiteboy (07-11-2013), tenon0774 (07-13-2013)
Old 07-11-2013, 06:18 AM   #5
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: TS55 REQ Recall
Mine had the issue. It was the fastfix blade change gizmo was catching on a small indentation on the blade casing. would have been a very simple fix but I goto my dealer about 5x a week so was easy to just swap it out.
www.bcconstructionllc.com
BCConstruction is offline
Old 07-11-2013, 07:34 AM   #6
General Contractor
greg24k's Avatar
Rewards Points: 8,900
Re: TS55 REQ Recall
It seems my Makita doesn't have this issues
greg24k is offline
Calidecks (07-13-2013)
Old 07-11-2013, 07:39 AM   #7
Trade: Construction
Re: TS55 REQ Recall
That's because the Makita don't have cool features like fastfix lol
Old 07-11-2013, 08:20 AM   #8
I like Green things
Re: TS55 REQ Recall
It is not a recall. They are inspecting inventory to see if there are any more out there with the issue, that way they can take care of it, instead of having to deal with shipping stuff back and forth.
I guess they are now requesting consumers that own the saw to call Festool. If there is a problem, yo they'll solve it.
Warner Mill Works
Facebook
YouTube
Old 07-11-2013, 09:11 AM   #9
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Re: TS55 REQ Recall
Check out my hook while my DJ revolves it.
Rustbucket is offline
The Following 3 Users Say Thank You to Rustbucket For This Useful Post:
chris klee (07-11-2013), Cole82 (07-11-2013), TAHomeRepairs (07-11-2013)
Old 07-11-2013, 09:12 AM   #10
I like Green things
Re: TS55 REQ Recall
I knew there were other cool people here.
Warner Mill Works
Facebook
YouTube
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
Cole82 (07-11-2013), woodworkbykirk (07-11-2013)
Old 07-11-2013, 10:02 AM   #11
VinylHanger's Avatar
Rewards Points: 14,094
Re: TS55 REQ Recall
Other? Does he have a mouse in his pocket?
VinylHanger is offline
Old 07-11-2013, 11:26 AM   #12
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Re: TS55 REQ Recall
...or is he just glad to see you.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 07-11-2013, 12:22 PM   #13
Trade: Construction
Re: TS55 REQ Recall
Just got contacted by my dealer to say there's a recall. He forgot I swapped mine out already.
Old 07-11-2013, 02:16 PM   #14
Anderson's Avatar
Re: TS55 REQ Recall
The mod over on FOG says discontinue use of the saw immediately and contact festal.
I was about to get one and now looks like will have to go with the old saw
Anderson is offline
Old 07-11-2013, 02:29 PM   #15
Trade: Construction
Re: TS55 REQ Recall
Yeah my dealer is having to send all in stock ones back too. My new one dont suffer that issue. Hopefully its not another issue.
Old 07-11-2013, 05:12 PM   #16
alboston's Avatar
Rewards Points: 688
Re: TS55 REQ Recall
Mine seems to retract just fine. Is it an obvious problem? I have only had it for a few weeks.
alboston is offline
Old 07-11-2013, 05:18 PM   #17
I like Green things
Re: TS55 REQ Recall
Yes, it is obvious. I got mine several months before release and noticed it hanging up some. With a bit of use it went away. It seems to be a clearance issue with the fast fix. I believe Festool knows what ones may have an issue (by build date) and are checking all saws in inventory plus checking with current owners of the saws.
Warner Mill Works
Facebook
YouTube
alboston (07-11-2013)
Old 07-11-2013, 05:43 PM   #18
Trade: Construction
Re: TS55 REQ Recall
Yeah the part that's hits is so close to not hitting its unreal. It's a difference of a hair and like Darcy says would prob sort its self after getting caught up a few times.
Old 07-11-2013, 05:43 PM   #19
Power-Whittler
Clarke Carpentry's Avatar
Trade: Custom Carpentry & Cabinetmaking
Re: TS55 REQ Recall
Even Ferraris catch fire sometimes.
Clarke Carpentry is offline
Old 07-11-2013, 06:06 PM   #20
Dirtywhiteboy's Avatar
Rewards Points: 1,600
Re: TS55 REQ Recall
Mine is doing fine too
Dirtywhiteboy is online now
pump recall superseal General Discussion 0 01-07-2011 06:41 PM
18 Volt Drill Recall caseyleen Tools & Equipment 22 12-22-2010 05:38 PM
Thermostat Recall Shock Hazard MechAcc HVAC 1 07-27-2009 01:58 AM
Dewalt Recall jiffy Tools & Equipment 2 08-16-2008 03:29 PM
REHVAC Tool Recall MechAcc HVAC 0 08-04-2007 07:21 AM
