Trimax Trailer Lock - Tools & Equipment - Contractor Talk
Trimax Trailer Lock
Old 03-05-2013, 10:08 AM   #1
Toolwh@#e's Avatar
Trade: framing contractor
Rewards Points: 192
Trimax Trailer Lock
Bad start to the day got to the site and broke my key off in my trailer lock. It's a trimax puck style lock so no bolt cutters. Trying to get the key out but so far no luck. Think I'll be there for days trying to drill it out. Any ideas?
Toolwh@#e is offline
Old 03-05-2013, 04:40 PM   #2
Self Leveler
JBBS's Avatar
Trade: Epoxy Flooring - Concrete Overlays - EIFS
Rewards Points: 550
Re: Trimax Trailer Lock
Torch it
JBBS is offline
Old 03-05-2013, 06:04 PM   #3
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Magnet to grab the key? Worth a shot.
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
Gary H (03-05-2013)
Old 03-05-2013, 08:44 PM   #4
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,692
I don't remember the term for hammering a key into a lock to open it but I was told by the boys at Master Lock it could be done with a puck lock.
Got enough showing to hammer it in or use a center punch?
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 03-05-2013, 08:50 PM   #5
All City's Avatar
Trade: Roofing and siding
Rewards Points: 75
I use a 4" grinder with a metal wheel often at my storage units. But I have not cut that type of lock before.
All City is offline
Old 03-05-2013, 08:51 PM   #6
dkillianjr's Avatar
Rewards Points: 2,464
This may be a shot in the dark, but can you get into the other door of the trailer? Can you unbolt the carrige bolts on the inside and take the whole door latch off and them maybe cut the lock from behind. I have american lock pucks on mine and they have brass slide bolts, so it would seem easy to cut. Maybe
dkillianjr is offline
Old 03-05-2013, 09:19 PM   #7
kyle_dmr's Avatar
Rewards Points: 998
Quickcut says it will open. Your going to be buying a lock either way you see it
kyle_dmr is offline
Old 03-05-2013, 09:26 PM   #8
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
I thought one of those locks would be hard to drill when my employee lost the key- I drilled it in about 7 seconds with a cobalt bit.
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 03-05-2013, 10:54 PM   #9
VinylHanger's Avatar
Rewards Points: 11,512
The main problem would be that your drill and bits are in the trailer you can't get into.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
world llc (03-05-2013)
Old 03-05-2013, 11:17 PM   #10
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
i snaped a key the other day too... the side door lock gets water in it and it freezes and the keys are cheap.
I replaced it with a new set of locks and had some spare keys made while at a locksmith for a client's door, the key he cut me was night and day better quality than the keys i get from depot. Like festool to Ryobi....
world llc is offline
Old 03-06-2013, 12:15 AM   #11
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Wow. Festool makes keys?
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
The Following User Says Thank You to svronthmve For This Useful Post:
world llc (03-06-2013)
Old 03-06-2013, 06:30 PM   #12
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
I've always wanted top notch dust collection on my keys
Jdub2083 is offline
The Following User Says Thank You to Jdub2083 For This Useful Post:
svronthmve (03-07-2013)
Old 03-06-2013, 07:17 PM   #13
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
Squirt wd40 up there and continually tap the lock with a hammer and it should come down enough to grab the broken end. I speak from experience :
CanningCustom is offline
The Following User Says Thank You to CanningCustom For This Useful Post:
dkillianjr (03-06-2013)
Old 03-06-2013, 08:46 PM   #14
nhill2090's Avatar
Trade: Flooring
Rewards Points: 109
I carry a small butane torch in my truck for when the locks freeze. That way you don't risk breaking the keys trying to open them. Takes 5 seconds
nhill2090 is offline
Old 03-06-2013, 09:00 PM   #15
tgeb's Avatar
Rewards Points: 350
A very narrow, small saw blade, such as a broken coping saw blade, can be pushed in the lock lifting the tumbler pins, and then withdrawn.
The points on the blade will grab the remaining piece of key and pull it from the lock without damaging the works.
www.gebcon.com
tgeb is offline
On the Trail of A thief knothead Off Topic (Non Trade) 85 04-29-2015 01:31 AM
enclosed trailer door lock conversion crgmark Vehicles 12 01-23-2013 10:06 PM
Warning check your hitch lock if you have a trailer BCConstruction General Discussion 9 09-02-2012 01:58 AM
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
