Trailer Overloading - Page 2 - Tools & Equipment - Contractor Talk
Trailer Overloading
Old 02-10-2019, 11:05 PM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Trailer Overloading
Take it to a scale and weigh the axles separately.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
tgeb (02-11-2019), TxElectrician (02-11-2019)
Old 02-10-2019, 11:11 PM   #22
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,958
Could drive by my local landfill or the metal recycling place.
Mike.
_______________
Calidecks is online now
Old 02-10-2019, 11:17 PM   #23
Inner10's Avatar
Mike.
_______________
We have a storage and moving company here with a scale, they give you a stamped ticket with weight of each axle for 15 bucks.
Inner10 is offline
Calidecks (02-10-2019)
Old 02-11-2019, 01:50 AM   #24
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,836
First thing I do is put load range G tires on a trailer. Rated at 4800 lbs each at 100 psi.
I haul over my trailer weight on occasion, but between the tires and transferring some more weight to the pin, I don't worry about it.
Sent from my SM-N960U using Tapatalk
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Calidecks (02-11-2019)
Old 02-11-2019, 07:56 AM   #25
TxElectrician's Avatar
Trade: Electrical
Rewards Points: 892
Mike.
_______________
Our recycler weighs mine for free.
Sent from my LG-LS993 using Tapatalk
TxElectrician is online now
The Following User Says Thank You to TxElectrician For This Useful Post:
Old 02-11-2019, 09:14 AM   #26
tjbnwi's Avatar
Rewards Points: 4,042
Another thing about trailer tires, most are rated for 75 or 80 mph.
tjbnwi is online now
Old 02-11-2019, 09:21 AM   #27
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,354
i never cared .big deal .about 10yrs ago i had to stop . every once in awhile thats an issue . another thing with trailers throughout my life is how often the brakes are not there . common reason when i was younger in constr was due to trailer being lent out and someone monkeyed with the cord .less common but something to consider ,cord end gets corosion .i now have a cover on it and put vasoline on the pins . anyhow due to those examples and also connectors coming loose I now really value brakes on the towing truck . My point -hauling no big deal ,oh I bent an axel once ,blown tires but brakes - ability to stop becomes a real issue when you need to stop .
I lived in snow country when I was young .never had trailer go out on me in ice ,I do not imagine thats fun for those who have .
JFM constr is offline
The Following 2 Users Say Thank You to JFM constr For This Useful Post:
Calidecks (02-11-2019), pinwheel (02-11-2019)
Old 02-11-2019, 04:42 PM   #28
TimNJ's Avatar
Rewards Points: 6,838
Most are rated for 65mph max on your average cargo/ utility trailer with a 225/15 or less tire size.
TimNJ is offline
Old 02-11-2019, 05:13 PM   #29
tjbnwi's Avatar
Thatís expressway exit speed.....
Old 02-11-2019, 05:19 PM   #30
Juan80's Avatar
Trade: General contractor
If you go breaks, maybe look at the disc option.
Etrailer has a bolt on kit , Iíll try to post a link.
Charlie
Sent from my iPad using Tapatalk Pro
Juan80 is offline
Old 02-11-2019, 06:05 PM   #31
Lettusbee's Avatar
Rewards Points: 1,498
I heard it was illegal to drive faster than 55 mph when pulling a trailer in California.
Izzat true?
Lettusbee is online now
Old 02-11-2019, 06:31 PM   #32
tjbnwi's Avatar
Izzat true?
If tue another reason Iíll never go to California.
pinwheel (02-11-2019), Xtrememtnbiker (02-11-2019)
Old 02-11-2019, 08:46 PM   #33
TimNJ's Avatar
Izzat true?
I never got any tickets
TimNJ is offline
Old 02-11-2019, 11:06 PM   #34
GC/carpenter
Calidecks's Avatar
First thing after this job is over I'm headed to the tire shop. I'm sure the tires that came with it are more than likely garbage. Tires never crossed my mind. Looking back it should've been the first thing I changed,
Mike.
_______________
Old 02-11-2019, 11:09 PM   #35
tjbnwi's Avatar
Me either......
Old 02-11-2019, 11:11 PM   #36
GC/carpenter
Calidecks's Avatar
Yes all semis and autos with trailers 55. He's the brakes I purchased. I think they will be sufficient for what I'm using the trailer for.
Mike.
_______________
Old 02-11-2019, 11:14 PM   #37
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 368
Mike.
Probably has ST 205's on it. They'll be 4 ply. Upgrading to ST225's will bump you up to 10 ply & be sufficient for what you're hauling.
_______________
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
Old 02-11-2019, 11:17 PM   #38
tjbnwi's Avatar
Mike.
_______________
They'll work just fine.
You'll need to change the plug on the trailer umbilical cord and the socket on the tow vehicle if they are flat 4's. You'll need at least a 5 pin. Your truck may have a round 7, match the trailer to it.
You'll need to run the brake wiring (normally SAE 12 ga, blue positive from the controller, SAE white 12ga. ground), the ground is very important.
Brake controller if you do not have one already, Tekonsha---Prodigy.
Old 02-11-2019, 11:18 PM   #39
GC/carpenter
Calidecks's Avatar
I think the tires it came with are load C rated radials.
Mike.
_______________
Old 02-11-2019, 11:20 PM   #40
GC/carpenter
Calidecks's Avatar
My truck came with a trailer package. Truck has both 3 pin and 7.
Mike.
_______________
low boy trailer kauai88 Sandblasting 24 05-08-2013 07:54 AM
Watch your trailer weights! BCConstruction Tools & Equipment 24 04-15-2013 08:53 PM
What tow vehicle do you think would be best for a mobile blasting trailer? Blast Off Sandblasting 0 03-06-2013 02:06 PM
Trailer size & Truck size(towing capacity) Dmitry Vehicles 19 01-24-2013 09:30 PM
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
