GC/carpenter
![]() Trade: Decking, Railing, Carpenter/General Contractor
Rewards Points: 10,968
Trailer Overloading
Doing the quick math I'm at 3560lbs on an axial with a 3500lb capacity. Should I be worried?
Mike. _______________ ![]() ![]() |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Rewards Points: 1,284
Re: Trailer Overloading
Not unless you get caught.
Tom Advertisement |
The Following 3 Users Say Thank You to tjbnwi For This Useful Post: |
Did you calculate your weight into this? Most forget that weight.
Tom |
Rewards Points: 682
Re: Trailer Overloading |
Rereading this, I think Mike is referring to the trailer axle only. His weight would not be a factor unless....
Might wear tires unevenly. Tom |
The Following User Says Thank You to tjbnwi For This Useful Post: |
Californiadecks (02-10-2019)
#6 | |
Focusing on solutions.
![]() Trade: hardwood floor contractor & so much more
Rewards Points: 368
Re: Trailer OverloadingQuote:
If the payload is already over the weight of the axle, then the weight of the trailer, he's even further over. As for the original question, I'd want to know how far & how fast before I made the decision to roll or get a heavier trailer. |
#7 | |
GC/carpenter
I added the trailer weight. I did some math to come up with my payload weight. Put my tool carts on a scale and went from there. Just ordered brakes for the trailer I'll be adding brakes to it next weekend. I estimated on the high side, so the exact weight could very well be under. Mike. _______________ ![]() ![]() Last edited by Californiadecks; 02-10-2019 at 06:59 PM. |
#8 | |
GC/carpenter
The weight I'm carrying now is just temporary. I've got my genie lift and 4 bags of concrete in it. Including my tools of course. The tools are permanent. Mike. _______________ ![]() ![]() |
GC/carpenter
The Following User Says Thank You to Californiadecks For This Useful Post: |
rrk (02-10-2019)
GC/carpenter
Don't think I'm required to go through the scales. According to the trailer sales place anyway.
Radical Basement Dweller
![]() Trade: Whatever needs to be made or repaired
Rewards Points: 5,444
Put the concrete in your truck bed.
Immigration is not supposed to change the character of the nation. Immigration is supposed to change the character of the immigrant. |
GC/carpenter
The Following User Says Thank You to Robie For This Useful Post: |
Trade: Pole Barns, Residential Framing
Rewards Points: 272
You'll be fine, especially if it's only temporary.
I didn't realize how heavy I was running my 7000 lb tool trailer, until we got the new one and started transferring tools. Depending on the job, I estimated that trailer was grossing well over 8,000 lbs on a regular basis. Other than it eating tires, I didn't have to much trouble with it. Sent from my SM-G930V using Tapatalk |
The Following User Says Thank You to mrcat For This Useful Post: |
Rewards Points: 272
Thankfully I never had to go through a DOT checkpoint with that trailer though. Sent from my SM-G930V using Tapatalk |
edward trowelhands
Trade: Diplomat
Rewards Points: 5,674
I've always wondered, couldn't you subtract the tongue weight? It's not on the axle.
Also, there's gotta be some safety factor.
Half of all people are below average. |
The Following 2 Users Say Thank You to Golden view For This Useful Post: |
Californiadecks (02-10-2019),
mrcat (02-10-2019)
Rewards Points: 682
The Following 2 Users Say Thank You to rrk For This Useful Post: |
TxElectrician (02-11-2019)
#18 |
Trade: Home improvement of all types
Rewards Points: 944
The brakes are a good idea , stopping an additional 3500 lbs is going to be much easier with brakes on the trailer .
The Following User Says Thank You to Idothat For This Useful Post: |
#19 |
Rewards Points: 3,914
Usually the trailer itself isn't a problem.
When you're pushing the weights it's the tires that are the weak link. There are some really crappy trailer tires out there.
Trump-The "Con Man's" Con Man. |
The Following 2 Users Say Thank You to TimNJ For This Useful Post: |
pinwheel (02-11-2019),
SouthonBeach (02-10-2019)
#20 |
Rewards Points: 4
I hate to say it but Ive had the single axle 3500lb cargo trailer up over 5000 pounds several times... Regularly well over 4000 pounds. Not proud of it. Snapped both leaf springs on separate occasions over the course of 2 years. Trailer was 11 years old when we bought it.
Have a tandem 7000lb now with brakes that I am much more comfortable with. Its usually at 6000 or so and might tip that 7000lb every month or 2. Ive loaded my 3500 pound landscaper up over 5000lb for short trips with no issue. My point is overloading by 60 pounds isnt going to make a huge difference but if you are constantly overloading get a tandem! I wouldnt even consider a single axle anymore. Sent from my LG-H812 using Tapatalk Advertisement |
The Following User Says Thank You to Platesurfer For This Useful Post: |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
low boy trailer | kauai88 | Sandblasting | 24 | 05-08-2013 07:54 AM |
Watch your trailer weights! | BCConstruction | Tools & Equipment | 24 | 04-15-2013 08:53 PM |
What tow vehicle do you think would be best for a mobile blasting trailer? | Blast Off | Sandblasting | 0 | 03-06-2013 02:06 PM |
Trailer size & Truck size(towing capacity) | Dmitry | Vehicles | 19 | 01-24-2013 09:30 PM |
Drawer-Based Trailer Project (Lots of Photos) | BuildersII | Tools & Equipment | 48 | 04-10-2011 11:12 AM |
Go to Page... |
