Tool Trailer Wiring - Tools & Equipment - Contractor Talk
Tool Trailer Wiring
Old 08-07-2013, 09:42 PM   #1
bigz's Avatar
Rewards Points: 151
Tool Trailer Wiring
I have noticed that i cant plug my tool trailer to a circuit with a GFI. My trailer was rigged up with a heavy cord wired to a breaker box with 2 circuits feeding off of it, i recently took the cord out of the panel and put in a park power RV plug wired to the panel. It would not work with a GFI with the old setup or the new setup. any ideas? Thanks
bigz is offline
Old 08-07-2013, 09:46 PM   #2
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Re: Tool Trailer Wiring
Possibly check your grounding / bonding on the trailer. Most likely somewhere your neutral & ground are together.
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
Old 08-07-2013, 09:50 PM   #3
bigz's Avatar
Rewards Points: 151
i forgot to mention that it even trips the GFI with the breakers off too...
bigz is offline
Old 08-07-2013, 09:51 PM   #4
bigz's Avatar
Rewards Points: 151
ive checked all wires in the panel box and replaced it all when installing the RV plug... do i need to pull recepticals and check all those connections too?
bigz is offline
Old 08-07-2013, 09:57 PM   #5
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Is the plug on the end of the wire hitting the test button on the gfci?
jlsconstruction is offline
Old 08-07-2013, 10:13 PM   #6
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
I would. I suspect somewhere in your system there is a connection.
The Following User Says Thank You to svronthmve For This Useful Post:
bigz (08-07-2013)
Old 08-08-2013, 06:11 AM   #7
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
That's exactly the way I've wired a number of trailers and they've always worked on gfi outlets.
RobertCDF is offline
Old 08-11-2013, 01:31 PM   #8
bigz's Avatar
Rewards Points: 151
i still cant figure it out... no loose connections or wires touching... it doing it with the breakers in the trailer off too is what puzzles me and i am using another power supply cord than i had before so it cant be that
bigz is offline
Old 08-11-2013, 01:35 PM   #9
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Have you tried it on a different circuit? maybe its mot your trailer. My ts75 was tripping a GFI the other day. I plugged it into my Bosch radio on a different circuit and it was fine. I guess it was an issue with the GFI
www.bcconstructionllc.com
BCConstruction is offline
Old 08-11-2013, 01:51 PM   #10
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 966
A GFCI trips when it senses a difference between the amount of current flowing in the hot wire and the neutral wire. Since you say it trips even when all breakers in the trailer are off, that would indicate either faulty wiring before the panel, or some device that's hooked up independently of the panel.
Disconnect the panel completely. If it still trips, disconnect the other end of the wire at your RV connector and try it. If it still trips, replace the connector. If it doesn't, replace or correct the connections on the wire.
Tinstaafl is online now
Old 08-11-2013, 02:09 PM   #11
bigz's Avatar
Rewards Points: 151
yea ive tried several circuits...
bigz is offline
Old 08-11-2013, 02:10 PM   #12
bigz's Avatar
Rewards Points: 151
its all been swapped. i did have it set up with a cord hooked directly to the breaker box and would plug it in then i took that out and went with the rv plug set up so everything is different all the way to the box... thanks
bigz is offline
Old 08-11-2013, 02:12 PM   #13
bigz's Avatar
Rewards Points: 151
with my luck i probably got a cord with a bad wire in it or something both times... im going to get a new cord to go to rv plug and if that dont work change the wire from plug to the breaker box again
bigz is offline
Old 08-11-2013, 04:40 PM   #14
Resident Pain
CanningCustom's Avatar
Rewards Points: 1,730
I had the same issue with a 30amp twist lock plug. I just ended up making a 4' "whip" and that fixed my problem. I just wanted a 100' 10g cord wired in just like a rv, just open the inlet and pull the cord. But apparently I am not smart enough to pull that off. Oh well the whip has been working fine.
CanningCustom is offline
Old 08-12-2013, 11:35 PM   #15
Toolwh@#e's Avatar
Trade: framing contractor
Rewards Points: 192
Sounds like the neutral and ground are bounded together. Usually a screw on the neutral bar that connects to the metal casing or some kind of jumper bar. This is how mines setup. The straight blade is for general power. The twistlock is for the compressor.
Toolwh@#e is offline
The Following 2 Users Say Thank You to [email protected]#e For This Useful Post:
CanningCustom (08-13-2013), svronthmve (08-13-2013)
Old 08-13-2013, 10:17 AM   #16
bigz's Avatar
Rewards Points: 151
i will have to check that... ive seen that bar your talking about on boxes before im not sure if my box in my trailer has that but i will look... thanks
bigz is offline
Old 08-13-2013, 11:19 AM   #17
Resident Pain
[email protected] where did you get your inlets from
Old 08-14-2013, 07:21 PM   #18
Toolwh@#e's Avatar
Rewards Points: 192
There made by hubbell I got them from Nedco but any electrical supply house will have them. Not cheap though the covers were $60 each and the inlets were $25 for the straight blade and $60 for the twistlock I think. Works good though and nice and clean.
The Following User Says Thank You to [email protected]#e For This Useful Post:
CanningCustom (08-14-2013)
low boy trailer kauai88 Sandblasting 24 05-08-2013 07:54 AM
Watch your trailer weights! BCConstruction Tools & Equipment 24 04-15-2013 08:53 PM
trailer wiring? brakes question paper Vehicles 2 09-21-2010 04:45 AM
New enclosed trailer on order, show me how you set up your layout for tool storage. beachremodlr Tools & Equipment 20 10-11-2009 07:11 PM
Trailer wiring charlesmd Tools & Equipment 3 04-30-2008 08:36 AM
