Tesla Powerwall - Tools & Equipment - Contractor Talk
Tesla Powerwall
Old 05-02-2015, 07:30 AM   #1
Pako's Avatar
Trade: trim work and mouldings
Rewards Points: 118
Tesla Powerwall
http://www.teslamotors.com/powerwall
I read up about tesla's new powerwall and I was wondering if you could stick that battery (or multiple batteries) in a trailer and replace a generator for a small crew? the fact that its zero emissions and doesn't make any noise is appealing and when you return home you can just recharge it.
Im just wondering how much power 2 skillsaw and a compressor can use during a day of framing. or maybe its enough to power a block heater for a telehandler overnight?
Im wondering what you guys think of the powerwall and if you see a use for it for construction work.
Pako is offline
Old 05-02-2015, 08:17 AM   #2
TheGrizz's Avatar
Trade: Remodeling and handyman
Rewards Points: 967
Re: Tesla Powerwall
What's the cost/benefit ratio? I'm sure this thing will cost much more up front than a generator. You'll recoup the difference in gas savings eventually, but how long?
TheGrizz is offline
Old 05-02-2015, 08:37 AM   #3
Pako's Avatar
Rewards Points: 118
Re: Tesla Powerwall
the device wil lbe around 3500 for the big battery, I don't really know what size a equivalent generator would be, but lets say its around 1000-1500 dollar, it would take quite a bit of fuel to recoup the cost.
i think the main interest is the easy setup on site (no need to take it out of the trailer, no need to fill it with fuel/carry fuel/check fuel regularly) and less constant noise.
Pako is offline
Old 05-02-2015, 08:47 AM   #4
TheGrizz's Avatar
Rewards Points: 967
Re: Tesla Powerwall
Looks like a neat idea, wouldn't be worth it for us though. We've only done one remodel in the past 2 years that needed a generator.
TheGrizz is offline
Old 05-02-2015, 08:52 AM   #5
Box Builder
Morning Wood's Avatar
Rewards Points: 10,090
Re: Tesla Powerwall
F that. You might as well plaster your tool trailer with pv's too. It's a step in the right direction, but batteries for home power still have a long way to go.
Morning Wood is offline
Old 05-02-2015, 09:06 AM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 86
Re: Tesla Powerwall
Power
2.0 kW continuous, 3.3 kW peak
When's the last time you saw a construction crew using a 2kW gas generator? And you'd also need to buy an inverter.
Tinstaafl is offline
Old 05-02-2015, 09:43 AM   #7
VinylHanger's Avatar
Rewards Points: 11,292
Re: Tesla Powerwall
If it works like they say it eventually will, it will be a game changer. A whole house battery that you could charge with a small solar panel. Goodbye electric company.
I can see a future where we no longer need a hard wired power grid.
VinylHanger is offline
Old 05-02-2015, 11:04 AM   #8
CAD Services
wallmaxx's Avatar
Trade: So done with this place...
Rewards Points: 144
Re: Tesla Powerwall
Be careful with that. It may be zero emissions at your jobsite, but somewhere the electricity to charge the system is being made by transforming one form of potential energy, (coal, moving water, nuclear) into another form of energy.
The transfer of energy states creates heat and often additional matter. pssst...CO2 isn't the enemy like people say. Carbon Monoxide...now that's the killa.
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
ScipioAfricanus (05-02-2015)
Old 05-02-2015, 11:05 AM   #9
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Tesla Powerwall
It would be very cool if every home started to come with a whole house battery system as standard building practice. It would make for a much more stable electrical grid.
wallmaxx is offline
Old 05-02-2015, 12:08 PM   #10
Pako's Avatar
Rewards Points: 118
Re: Tesla Powerwall
oh yea I know that. I was saying zero emissions as in you cant run a generator or a gas powered tool indoor but batteries are fine
Pako is offline
The Following User Says Thank You to Pako For This Useful Post:
wallmaxx (05-02-2015)
Old 05-02-2015, 01:15 PM   #11
Railman's Avatar
Trade: Railing
Rewards Points: 689
Re: Tesla Powerwall
Another option might be to run a near quiet small generator like the camping types. Then run it to a series of car batteries, and then run an inverter from there. The batteries would handle the high surges, & the generator would be in a constant charge mode. You could charge up the batts overnight at home for morning job start. The fuel consumption would be very low, as would be the noise, which to me I always found to be exhausting.
It wouldn't be practical for replacing a large compressor on site, but would probably be adequate for saws & such.
Railman is offline
Old 05-02-2015, 01:25 PM   #12
Box Builder
Re: Tesla Powerwall
I wonder if anyone has actually tried that with a big bank of deep cycles and a small inverter generator just running a charger on the batteries? Probably a very pricey setup to do it right.
Old 05-02-2015, 02:03 PM   #13
TheGrizz's Avatar
Rewards Points: 967
Re: Tesla Powerwall
Not to mention heavy. You'd need a ton of batteries to handle the current draw of multiple tools.
TheGrizz is offline
Old 05-02-2015, 02:15 PM   #14
GettingBy's Avatar
Rewards Points: 6,486
Re: Tesla Powerwall
Using one 120vac Skilsaw for an hour might average to 1.5 kwh of energy. The avg. US house takes ~9000 kwh/yr.
GettingBy is offline
Old 05-02-2015, 06:37 PM   #15
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Tesla Powerwall
I still think battery tech ain't quite there yet. In another 10years I think it may be but right now they are unstable and expensive. But when the battery capacity is there and stable I think it's gonna be a game changer. Just like their cars. Them things are seriously powerful but lack range and battery life span. Once the tech gets there though I would have no issue buying a battery truck. I'm amazed trucks ain't happened before cars though. They gave the capacity and the room to store a massive battery and still have great payload.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-02-2015, 07:12 PM   #16
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,937
Re: Tesla Powerwall
It's just a battery. No DC to AC inverter included.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 05-03-2015, 12:26 AM   #17
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 296
Re: Tesla Powerwall
I've built homes fdn to finish on less than 20 KWH of electricity. So the capacity is not an issue.
Golden view is offline
Old 05-03-2015, 06:41 AM   #18
Trade: Construction
Re: Tesla Powerwall
Just read some more about them. 220lbs and real big for only a 2kw continuos output.
You can get that tiny Honda genny that can do that and is super quite for way less money and it will keep supplying power as long as it has fuel in it. This this will be flat at the end of a day even with the larger model.
Old 05-03-2015, 07:50 AM   #19
Future Post Deleter...
rex's Avatar
Trade: Nothing
Rewards Points: 1,092
Re: Tesla Powerwall
I'm in the process of building off grid on some property I own. Was going to start with a solar and batteries and adjust as needed. Will cost thousands to get power back there why not try solar.
rex is offline
Old 05-03-2015, 12:17 PM   #20
CAD Services
wallmaxx's Avatar
Rewards Points: 144
Re: Tesla Powerwall
The reporter said they start at $3500.
http://www.wired.com/2015/05/get-tes...ysics-explain/
wallmaxx is offline
Tesla Charging Station wallmaxx Off Topic (Non Trade) 44 04-09-2014 08:27 AM
New Tesla SUV woodchuck2 Vehicles 0 02-11-2012 05:10 PM
Windmills and Tesla generators KG007 Electrical 25 01-18-2011 10:48 AM
Happy B-day Nikola Tesla wallmaxx Off Topic (Non Trade) 8 07-12-2009 07:42 PM
Tesla Motors? willbone3 Off Topic (Non Trade) 26 07-29-2006 02:04 PM
