Telsla A28D Bucket Truck Hydralics Will Not Work - Tools & Equipment - Contractor Talk
Old 09-17-2020, 04:57 PM   #1
kyguy's Avatar
Trade: Home Renovation
Rewards Points: 2
Found via Google an old article about other issues with Bucket Truck. Had some good answers for the problem the guy had.
This is a 98 model so it has been used a lot. Picked it up cheap. Worked good, then wife had surgery and It sat for 4 months. Boom will not move now. I have checked the electrical controls, Overides and control switches ect. They all seem to be flowing electric as they should. The boom does nothing. Hydralic pump is working. I am thinking it is low on Hydralic fluid. Sounds simple; I have been all over it and cannot find a fill point. There is a hydralic tank inside the trunk the boom sits on. Filter is directly over it. That tank has a plastic cap on it, when you take the cap off it appears to be only a vent. Got the Manuals on it. No where does it show how to add Hyd fluid. It says there is a sight glass on the boom but I dont find one. Goggled it an found no help there Help Please.
kyguy is offline
Old 09-17-2020, 06:28 PM   #2
rustyjames's Avatar
Rewards Points: 26
Re: Telsla A28D Bucket Truck Hydralics Will Not Work
If it was working before it was parked I doubt it's low on fluid, unless there's a puddle under it. Four months isn't that long of a time span. The cap you removed is probably the fill because most systems use a vented cap.
I suspect a rodent might have chewed a wire, or a bad control wire connection is more likely the problem.
rustyjames is online now
The Following User Says Thank You to rustyjames For This Useful Post:
kyguy (09-18-2020)
Old 09-17-2020, 06:29 PM   #3
Stunt Carpenter's Avatar
Rewards Points: 3,234
Take the vent off a dip the tank.
Could be a solenoid is stuck.
https://builddaley.com/
Stunt Carpenter is online now
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
kyguy (09-18-2020)
