TBA Meeting (Tool Buyers Anonymous) - Page 954 - Tools & Equipment - Contractor Talk
Old 11-19-2018, 04:58 PM   #19061
META's Avatar
Trade: General and Trades
Rewards Points: 3,156
Re: TBA Meeting (Tool Buyers Anonymous)
Originally Posted by Dirtywhiteboy View Post
Why not just buy the right blade??
Because old blades are a dime a dozen and work fine for everything I do with aluminium and plastics. If I needed precision cuts I'd get the correct blade. I've used fine toothed aluminum blades. Standard large tooth carbides backwards work better for siding and aluminum soffit, IMO.
I run Tenryu on my 12" Bosch and 10" table saw for finish work; both wood and PVC trims.
META is online now
Old 11-19-2018, 05:08 PM   #19062
Dirtywhiteboy's Avatar
Rewards Points: 9,756
oh I thought asevereid was cutting handrails
Dirtywhiteboy is offline
Old 11-19-2018, 05:12 PM   #19063
META's Avatar
I just use my grinder for those....LOL!
META is online now
Old 11-19-2018, 05:15 PM   #19064
META's Avatar
Joking. Looks like I entered midstep in a conversation and added worthless info.
META is online now
Old 11-19-2018, 05:58 PM   #19065
Hack
asevereid's Avatar
Rewards Points: 336
Not worthless... I cut all my soffit with a backwards blade as well. Doesn't make me any friends because of the racket, but it sure is quick
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
The Following User Says Thank You to asevereid For This Useful Post:
META (11-19-2018)
Old 11-19-2018, 10:21 PM   #19066
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Fedex finally got the Festool TS-75 to me today, when it was supposed to be delivered Friday. Immediately mounted it into the CMS-TS-75 plate, but didn't get a chance to install the new Oshlun plastics blade, nor play with it at all yet, as I had to fix the hungry wife dinner. Grabbed a couple Corian counter tops with the plan to re-purpose them into some useful items for the wife, which will be a perfect test for the new to me table saw.
TBA Meeting (Tool Buyers Anonymous)-img_6511.jpg   TBA Meeting (Tool Buyers Anonymous)-img_6512.jpg
Peter_C is offline
The Following 5 Users Say Thank You to Peter_C For This Useful Post:
asevereid (11-20-2018), hdavis (11-19-2018), META (11-20-2018), overanalyze (11-20-2018), Xtrememtnbiker (11-20-2018)
Old 11-20-2018, 05:33 PM   #19067
TimNJ's Avatar
Rewards Points: 4,398
Originally Posted by cedarboarder View Post
I got the same 10" saw, having trouble letting it go for a cordless. I like it too much. Also no guard haha
I bought that saw in '83 and used it until about 2008(?). It was killed on a job one day when there was some kind of surge. My buddy was cutting some trim and said the saw spun backwards right when there was a buzz/flash and about half a dozen townhouses lost electric.
Then I bought the updated version and used that for a few years before I bought the X2, 7 1/2" sliding compound.
I do not miss that old heavy monster.
TimNJ is online now
Old 11-20-2018, 06:44 PM   #19068
That little saw does almost everything I need to do.
TimNJ (11-20-2018)
Old 11-20-2018, 07:06 PM   #19069
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,120
I just flip old saw blades around for aluminum and vinyl soffit; put up many homes that way. I cut through stacks of material in one pass just fine.
I never turn mine around. No need to cuts just fine normal way. But I do use a good blade that only gets used on aluminum soffit.
Randy Bush is online now
Old 11-20-2018, 07:10 PM   #19070
META's Avatar
It's been years since I've cut aluminum forward. Maybe I need to review my practices.
META is online now
Old 11-20-2018, 07:50 PM   #19071
Renaissance Man
superseal's Avatar
Rewards Points: 5,810
When red Germans come to the door, you let them in!
supersealconstruction.com
superseal is offline
The Following 3 Users Say Thank You to superseal For This Useful Post:
asevereid (11-21-2018), Calidecks (11-20-2018), Peter_C (11-20-2018)
Old 11-20-2018, 08:46 PM   #19072
Peter_C's Avatar
Rewards Points: 412
After a Costco run this evening, I dropped by Home Depot to see if I could finagle a deal on the Packout's. Walked out the door for $177, which included a piece of 1/8" masonite to be used for building inserts for Systainer's. Might have to hit HD again tomorrow, and see if I can get the same deal again. Really I could use a few more Packout stacks to replace all the Ridgid stacks I have and be on just two tool box systems, not three.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
Old 11-20-2018, 08:46 PM   #19073
TimNJ's Avatar
Wasn't Hilti from Lichtenstein?
TimNJ is online now
Old 11-20-2018, 09:00 PM   #19074
META's Avatar
Yeah ^
META is online now
Old 11-20-2018, 09:09 PM   #19075
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,514
Got to stack them.
Plus the cutest little edge sander made.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
The Following 3 Users Say Thank You to WarnerConstInc. For This Useful Post:
asevereid (11-21-2018), Lettusbee (11-21-2018), pinwheel (11-20-2018)
Old 11-20-2018, 11:03 PM   #19076
GC/carpenter
Calidecks's Avatar
Rewards Points: 16,822
Just ordered one. Don't need it, but it's too good to not buy.
Mike.
_______________
Calidecks is online now
Old 11-20-2018, 11:21 PM   #19077
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 576
Couldn't let Darcey have all the fun.
Stole this 5 head moulding sander today. $325
pinwheel is online now
The Following 8 Users Say Thank You to pinwheel For This Useful Post:
asevereid (11-21-2018), Deckhead (11-23-2018), hdavis (11-21-2018), Lettusbee (11-21-2018), overanalyze (11-24-2018), tgeb (11-21-2018), WarnerConstInc. (11-20-2018), Xtrememtnbiker (11-21-2018)
Old 11-21-2018, 12:22 AM   #19078
Unger.const's Avatar
Rewards Points: 2,906
Originally Posted by Californiadecks View Post
Will those thin boxes hold 10" blades? I'm thinking of buying one and dedicating it to circular blades.
Mike.
_______________
Sorry cali
Had been a while since I was on and didn't see your question. Till tonight.
Unger.const is offline
The Following User Says Thank You to Unger.const For This Useful Post:
Calidecks (11-21-2018)
Old 11-21-2018, 12:28 AM   #19079
I'm not even sure my wife knows what I do for a living.
Mike.
_______________
If she guesses golfing...
Then she's on to you!
Old 11-21-2018, 01:00 AM   #19080
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 376
Edit: quoted the wrong post heh.
I'm down in the High Desert for a couple weeks for nieces 1st birthday, grandfathers 92nd and Thanksgiving, and to change out a couple toilets and repair/paint a fence for my grandfather. He's been a carpenter in Southern California since his mid-late 20's up until 7 or so years ago (just doing little odd jobs for some life long clients) and he has that same chop saw/ also missing the guard. Its actually a great little saw, and is by far the lightest 10" saw I have ever used. I don't know if it's all of them, or the brushes are worn down or something else but man does that thing scream bloody murder when you pull the trigger. His hearing is shot, and I think I've found the culprit.
I keep meaning to ask him if he ever came across or knew of Larry Haun But he sure could build the hell out of custom cabinets with the only power tools used being a tiny old table saw and an all metal circular saw that was stolen out of his garage a few years back.
TRThomas is offline
Toolaholics Anonymous Announcement; 2ndGen Tools & Equipment 31 02-23-2013 09:13 PM
The tool repair called me after 2 years nywoodwizard Tools & Equipment 3 05-21-2007 02:37 AM
The most Effective Tool on the market now! Mr. Wms General Discussion 3 01-23-2007 03:32 AM
FEEDBACK: Online Survey Tool Nathan Off Topic (Non Trade) 9 08-29-2006 05:20 PM
PVC Pipe Tool Box denick Excavation & Site Work 35 04-25-2006 05:35 AM
