TBA Meeting 2 (Tool Buyers Anonymous) - Page 91 - Tools & Equipment - Contractor Talk
Old 01-16-2020, 12:19 AM   #1801
diplomat
Golden view's Avatar
Rewards Points: 738
Re: TBA Meeting 2 (Tool Buyers Anonymous)
Originally Posted by Dirtywhiteboy View Post
No , that one takes the different angle nails. Maybe the ones in the paper. The NR83 takes the 21ļ nails in the plastic.
No both the NR83 and NR90 have paper and plastic versions. The NR90 is a lighter duty gun, cheaper, used to be made in China when the 83 was Japan.
Golden view is offline
Old 01-16-2020, 07:04 AM   #1802
META's Avatar
Trade: General and Trades
Rewards Points: 5,922
The 83 and 90 have different heads and driving mechanisms. The 83 is the heavy duty version that can handle sand and debris in the head better.
The 90 has a multi valve head with a bunch of springs. Light and compact, but will not handle debris well.
I have a MAX short head which is being rebuilt right now and likely one of the valves is hung up.
My 83S rarely have that issue.
META is online now
Old 01-16-2020, 08:03 AM   #1803
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 956
Or ring shank nails. I have a nail head busted off and jammed between the drive pin and the carrier. Going to be fun to get that out. I guess most (or any) guns donít like ring shanks longer than 2-3/8Ē though.
Big Johnson is offline
Old 01-16-2020, 08:05 AM   #1804
Rewards Points: 956
FYI I like to use 3” RS on interior bottom plates (studs to plate and plate to floor) to minimize squeaks.
Old 01-16-2020, 06:57 PM   #1805
JoeStanton's Avatar
Trade: Construction
Rewards Points: 48
I have luck with a punch as close to the same size as the pin. We've actually has them fuse together when running sheathing.
JoeStanton is online now
The Following User Says Thank You to JoeStanton For This Useful Post:
META (01-16-2020)
Old 01-16-2020, 07:14 PM   #1806
META's Avatar
That's a pain. I usually drive the driving pin back down with a large nail set or larger nail/rod.
META is online now
Old 01-16-2020, 07:31 PM   #1807
Rewards Points: 956
Already tried that, this nail head must be extra thick or heavily burred. I’ll get it eventually just haven’t had time.
META (01-17-2020)
Old 01-16-2020, 08:17 PM   #1808
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,332
Old sds bit works great for that.
Mike.
_______________
Calidecks is online now
META (01-17-2020)
Old 01-17-2020, 08:41 AM   #1809
rblakes1's Avatar
Rewards Points: 3,638
Picked this up last night, so far I like it
-Rich
rblakes1 is online now
The Following 2 Users Say Thank You to rblakes1 For This Useful Post:
asevereid (01-17-2020), overanalyze (01-17-2020)
Old 01-17-2020, 10:05 AM   #1810
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 28
I could have used that a few days ago. Fitting paper raised panel doors to replace original flush hollow cores...
I made a Frankenstein jig for the router. It worked for the moment...
Porterfarm is offline
Old 01-17-2020, 10:38 AM   #1811
Dirtywhiteboy's Avatar
Rewards Points: 13,202
-Rich
I have that kit and it does what it sopossed to do.
Dirtywhiteboy is offline
The Following 3 Users Say Thank You to Dirtywhiteboy For This Useful Post:
asevereid (01-17-2020), overanalyze (01-17-2020), rblakes1 (01-17-2020)
Old 01-17-2020, 02:52 PM   #1812
rblakes1's Avatar
Thats all I'm looking for in a tool!
I like how this kit has all the extras for doing the latches and strikes. For not even $40, well worth it, especially since it came with the centering drill bit
I have the Ryobi one, but that only does the door side of the hinge, not the jamb side.
Old 01-17-2020, 02:54 PM   #1813
rblakes1's Avatar
Got it at Lowes for ~$40
Old 01-17-2020, 03:06 PM   #1814
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 2,097
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
cedarboarder (01-17-2020)
Old 01-17-2020, 03:24 PM   #1815
test
cedarboarder's Avatar
Trade: General
Rewards Points: 2,343
Dang, another tool for my list. haha
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 01-17-2020, 08:16 PM   #1816
Porterfarm's Avatar
Rewards Points: 28
Oh man so many steps and graphs...
Old 01-17-2020, 08:51 PM   #1817
Porterfarm's Avatar
Rewards Points: 28
https://www.portercable.com/products...late-kit/59381
This one is a nice template set. You can set it and do the door and frame. If I see one at a good deal I would get it.
Or if I had a bunch of doors to do..but one or two at a time is not that high of a priority.
I just screwed together a few 1x4 s, two in a T. Two spaced an 1-1/2" from the edge of the hinge top and bottom. 3/4 x3/4" cut-off made the door depth stop.
Set the depth of the bit.
Ran the router, cuts the top edge of the T. Ensure that the hinge fits. Adjust as required. I happened not to for this instance. The cut lines up to your hing mark. Clamp it with a large c- clamp route. Repeat at each hinge.
Then modified the jig for the latch plate.
Door jams had top and bottom hinges already. Just had to locate the middle hinges, and two of the doors needed strike plates. All of which I did by hand.
Until the next time....
Old 01-17-2020, 09:06 PM   #1818
Stunt Carpenter's Avatar
Rewards Points: 2,348
Thatís the jig I have. Itís nice that itís actually built for job site just.
https://builddaley.com/
Stunt Carpenter is online now
Old 01-17-2020, 11:06 PM   #1819
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 40
These come up on CL/ ebay pretty regularly. The bummer is that they've usually lost a part or two and replacements are either crazy $$$ or unavailable. I ended up buying 3 and making two complete kits... sold one and made my net cost almost nothing.
It's really nice to have at least 4 of the templates so that when you've assembled the usual 3, you've got a loose one to set router depth with. (Or, I suppose you could be brilliant and set the depth before, but let's not get crazy or nothing...)
Defenestrate is offline
The Following User Says Thank You to Defenestrate For This Useful Post:
Lettusbee (01-18-2020)
Old 01-18-2020, 01:09 PM   #1820
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 858
Originally Posted by NYgutterguy View Post
Used it yesterday after I did the final mow of the year and cleaned up the yard a little bit. Pretty impressive power on full blast. Got about 12 min on number 4. Think
It will work out well for blowing out some gutters.
Was able to do the entire house of these very wet, heavy leaves the other day on full power. Started dying right at the end Couldnít be happier with it.
NYgutterguy is online now
Jobsite tool and toolbox security platinumLLC Tools & Equipment 15 07-15-2019 12:52 AM
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Painter's tool box, what do you use? platinumLLC Painting & Finish Work 29 08-14-2015 08:34 PM
Tool Usage Explained Kowboy Off Topic (Non Trade) 7 05-18-2015 07:42 PM
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 03:38 AM
