TBA Meeting 2 (Tool Buyers Anonymous) - Page 70 - Tools & Equipment - Contractor Talk
Old 09-20-2019, 07:26 PM   #1381
Dirtywhiteboy's Avatar
Rewards Points: 5,172
Re: TBA Meeting 2 (Tool Buyers Anonymous)
Originally Posted by overanalyze View Post
Yeah but I have zero Makita stuff...and am not interested in another platform...plus that teal...
Oh, I know it,, just sayin
Dirtywhiteboy is offline
overanalyze (09-20-2019)
Old 09-20-2019, 07:32 PM   #1382
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,556
Originally Posted by META View Post
I asked before, but did you still install a rimboard on the ledger at joist ends, or bridging? We eliminated both on our last at the builder's request being subfloor was fastened to sill in proximity to joist ends.
Full blocking. We always used i-joists. Setup a table saw and start cutting. Makes them nice and square. We fill the back up with foam before installing them so there isn't a void and potential cold spot.
overanalyze is offline
The Following 3 Users Say Thank You to overanalyze For This Useful Post:
META (09-20-2019), SmallTownGuy (09-20-2019), Xtrememtnbiker (09-21-2019)
Old 09-20-2019, 07:57 PM   #1383
META's Avatar
Trade: General and Trades
Rewards Points: 7,580
12" chopsaw works for us most times. In our case that area was insulated with loose or batt.
META is online now
The Following User Says Thank You to META For This Useful Post:
Old 09-20-2019, 07:59 PM   #1384
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Square drive?? I Can't find a square drive bit the right length for the Pam.
Phillips for these ones.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
Old 09-20-2019, 08:05 PM   #1385
Always Learning
That makes sense then..Pam doesn't make a square bit..they want you using their subfloor screws...and they are better than the Senco or generic squares we used to use.
Old 09-20-2019, 08:06 PM   #1386
Always Learning
Personal preference but I don't like fiberglass batt in the box. Nuwool isn't bad. We still have ours sprayed foamed even with the Dow we installed.
META (09-20-2019)
Old 09-20-2019, 08:11 PM   #1387
Rewards Points: 986
They did make one in the past. 140mm #2 square. Shows as out of stock most places but I bet a few local lumberyards may have some deadstock. I’ll check around next week. If I find some I’ll send one your way in case you need to use another brand in a pinch.
The PAM screws are awesome and work way better, but sometimes you need a backup option.
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
DaVinciRemodel (09-20-2019), overanalyze (09-20-2019)
Old 09-20-2019, 08:32 PM   #1388
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 1,258
Eric, If you find some send one or two my way as well.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
EricBrancard (09-20-2019)
Old 09-20-2019, 09:12 PM   #1389
Rewards Points: 986
I'll let you know what I come up with.
DaVinciRemodel (09-21-2019), overanalyze (09-20-2019)
Old 09-20-2019, 09:15 PM   #1390
Always Learning
They did make one in the past. 140mm #2 square. Shows as out of stock most places but I bet a few local lumberyards may have some deadstock. Iíll check around next week. If I find some Iíll send one your way in case you need to use another brand in a pinch.
Yeah I definitely wouldn't mind a backup solution. The Pam screws aren't stocked locally. I can get them Tuesday or Friday from my yard but you know there will be a time I am out and need something to finish a job.
Old 09-20-2019, 09:16 PM   #1391
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,248
I love the Simpson QuikDrive. Comes in square in multiple lengths.
Mike.
_______________
Calidecks is offline
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
overanalyze (09-20-2019), rblakes1 (09-21-2019)
Old 09-20-2019, 09:18 PM   #1392
Always Learning
I will do a video this weekend of the Pam with our Dewalt gun in action. Framing an addition on my house this weekend.
Old 09-20-2019, 09:19 PM   #1393
Always Learning
Mike.
_______________
Had a Quickdrive before our Senco. Maybe they made it better now but at the time the Senco blew it out of the water.
Calidecks (09-20-2019)
Old 09-20-2019, 09:24 PM   #1394
GC/carpenter
Calidecks's Avatar
Haven't used it in years. This was back before hidden fasteners really took off.
Mike.
_______________
Old 09-20-2019, 09:43 PM   #1395
What length bit does the Pam Drive take?
Old 09-20-2019, 09:45 PM   #1396
Always Learning
It's an oddball size. Metric I believe.
Dirtywhiteboy (09-20-2019)
Old 09-20-2019, 11:14 PM   #1397
Rewards Points: 986
140mm
Old 09-21-2019, 10:03 AM   #1398
rblakes1's Avatar
Rewards Points: 4,026
Mike.
_______________
I have one that I use mostly for quieting down old noisy sub floors
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
Calidecks (09-21-2019)
Old 09-21-2019, 04:21 PM   #1399
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
For you guys looking for a square drive for the pam drive...
I bought a 6" milwaukee bit, cut it to 5 1/2" and then ground a new relief in it for the bit holder to grab. It works fine.
https://www.milwaukeetool.com/Produc...its/48-32-4805
Home Designer Series Software
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
cedarboarder (09-21-2019), overanalyze (09-21-2019)
Old 09-21-2019, 06:02 PM   #1400
Sounds like a lot of work,, I'm glad I use a SuperDrive and can get the bits locally at Grabber Hawaii or now called J&M materials.
My SuperDrive takes a 6" bit.
For the mass work of collated screws we always use the Wagner bits.. maybe called lox bits now?? There is no better bit.
The Following 2 Users Say Thank You to Dirtywhiteboy For This Useful Post:
overanalyze (09-21-2019), TheConstruct (09-21-2019)
Jobsite tool and toolbox security platinumLLC Tools & Equipment 15 07-15-2019 12:52 AM
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Painter's tool box, what do you use? platinumLLC Painting & Finish Work 29 08-14-2015 08:34 PM
Tool Usage Explained Kowboy Off Topic (Non Trade) 7 05-18-2015 07:42 PM
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 03:38 AM
