TBA Meeting 2 (Tool Buyers Anonymous) - Page 69 - Tools & Equipment - Contractor Talk
Old 09-19-2019, 07:27 PM   #1361
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, decks, additions
Rewards Points: 14,192
Re: TBA Meeting 2 (Tool Buyers Anonymous)
That's for when you just need them out of the way
A&E Exteriors is online now
The Following User Says Thank You to A&E Exteriors For This Useful Post:
Tinstaafl (09-19-2019)
Old 09-19-2019, 07:30 PM   #1362
META's Avatar
Trade: General and Trades
Rewards Points: 5,312
Or you want to be close to the wall
META is online now
The Following User Says Thank You to META For This Useful Post:
A&E Exteriors (09-20-2019)
Old 09-19-2019, 08:32 PM   #1363
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 238
I prefer the jacks/pick on the inside when possible.
Big Johnson is online now
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
B.Johnson (09-21-2019), META (09-20-2019)
Old 09-19-2019, 08:56 PM   #1364
VinylHanger's Avatar
Rewards Points: 11,248
Always on the inside. Too far away when on the outside.
VinylHanger is offline
Old 09-20-2019, 08:25 AM   #1365
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 68
Originally Posted by overanalyze View Post
Made our PamFast flooring screw gun cordless.
Can we go back to this topic for a moment? On our current project, we have about 3200 SF of subfloor to screw down. Is PamFast the go-to for this? What are the other options?
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is online now
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
overanalyze (09-20-2019)
Old 09-20-2019, 09:29 AM   #1366
Railman's Avatar
Trade: Railing
Rewards Points: 675
Originally Posted by Tinstaafl View Post
Looks like that foot injury caused some dain bramage. Ladder jacks usually go on the other side.
It depends on high your putting the pick!
Up high, it's outside, down low it's inside.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Idothat (09-20-2019)
Old 09-20-2019, 10:11 AM   #1367
I hate the plank on the outside. I always feel like it's going to fall.
Old 09-20-2019, 01:02 PM   #1368
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,338
Senco is a good one aswell for stand up autofeed.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 09-20-2019, 01:06 PM   #1369
test
Trade: General
also how can someone get around the plank on the front? crawl on to the plank or climb from the back?
I don't have much experience using them.
Old 09-20-2019, 04:38 PM   #1370
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 66
Set another ladder on the plank
Idothat is online now
Old 09-20-2019, 05:25 PM   #1371
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,046
I fought the Pam because of their proprietary screws at first...but damn they are worth it!! We ran a Senco for a long time. We just installed 3100 sq ft of Advantech with that setup in the picture.
We were getting 20 sheets a battery which is also approx 1 box of screws. That was also holding the trigger on constant when driving screws.
For the entire job I might have had 2 dozen strip outs. That is mostly because the Advantech is so dense sometimes the screw just doesnt go in straight.
That Dewalt was absolutely perfect. It runs at 2500 rpm and didn't miss a beat. Also the bits last forever and 1 comes in every box.
overanalyze is online now
DaVinciRemodel (09-20-2019)
Old 09-20-2019, 05:56 PM   #1372
Rewards Points: 238
Inside until the jacks hit the wall, then I go to the outside if I have to. Usually I don’t because I keep pulling the ladders out at the bottom until it’s really nice and springy.
Old 09-20-2019, 06:02 PM   #1373
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 76
If you have the ladder pitched properly, getting under it with the jack inside is perilous at best. I generally want use of the entire length of plank/pick, so that doesn't play for me.
I put the jacks on the outside, and adjust ladder height according to what I need to reach.
As for getting up onto the plank, I'm a skinny monkey. No problem. Sometimes put up an extra ladder for the chubsters--if they even have enough guts to dance a plank like that. :
Tinstaafl is offline
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Dirtywhiteboy (09-20-2019), mrcat (09-20-2019)
Old 09-20-2019, 07:01 PM   #1374
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 226
You can use other screws with the PAM drive. I didnít have time to get a box of PAM screws from the yard today and ran the cheap griprite ones from the Depot through it instead. Zero issues.
EricBrancard is online now
The Following User Says Thank You to EricBrancard For This Useful Post:
Old 09-20-2019, 07:13 PM   #1375
META's Avatar
You guys are doing that a little differently than I've been framing them by not carrying the subfloor over the sill plate on foundation. It is nice being you eliminate a layer of 2x. We both still need to make sure subfloor to sill is aligned properly so as to maintain equal stud length on exterior wall to interior walls.
Looking good.
META is online now
Old 09-20-2019, 07:14 PM   #1376
Dirtywhiteboy's Avatar
Rewards Points: 12,112
My Makita runs at 2,500rpms and only goes on when the bit is engaged
Dirtywhiteboy is offline
Old 09-20-2019, 07:20 PM   #1377
Always Learning
Yeah but I have zero Makita stuff...and am not interested in another platform...plus that teal...
Old 09-20-2019, 07:22 PM   #1378
Always Learning
Originally Posted by META View Post
You guys are doing that a little differently than I've been framing them by not carrying the subfloor over the sill plate on foundation. It is nice being you eliminate a layer of 2x. We both still need to make sure subfloor is sill align properly so as to maintain equal stud length on exterior wall to interior walls.
Looking good.
It works nice and as long as it's all done right turns out ideal. Really with the perimeter fully blocked it makes for a really solid floor. Really only sucks for the electrician... can't bring anything up from below.
META (09-20-2019)
Old 09-20-2019, 07:22 PM   #1379
Always Learning
Square drive?? I Can't find a square drive bit the right length for the Pam.
Old 09-20-2019, 07:24 PM   #1380
META's Avatar
I asked before, but did you still install a rimboard on the ledger at joist ends, or bridging? We eliminated both on our last at the builder's request being subfloor was fastened to sill in proximity to joist ends.
META is online now
Jobsite tool and toolbox security platinumLLC Tools & Equipment 15 07-15-2019 12:52 AM
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Painter's tool box, what do you use? platinumLLC Painting & Finish Work 29 08-14-2015 08:34 PM
Tool Usage Explained Kowboy Off Topic (Non Trade) 7 05-18-2015 07:42 PM
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 03:38 AM
