TBA Meeting 2 (Tool Buyers Anonymous) - Page 58 - Tools & Equipment - Contractor Talk
Old 07-22-2019, 10:55 PM   #1141
GC/carpenter
Calidecks's Avatar
Rewards Points: 4,066
Re: TBA Meeting 2 (Tool Buyers Anonymous)
Originally Posted by META View Post
It's just not a true worm drive; just a sidewinder with rear handle/ gril.
Milwaukee is coming out with a full size (comparable to corded) in their 18v package soon, though that I'll be interested in.
I don't think any of the rear handles are true wormy's.
Mike.
_______________
Calidecks is offline
META (07-23-2019)
Old 07-22-2019, 11:31 PM   #1142
diplomat
Golden view's Avatar
Rewards Points: 706
Worm drive isn't really a feature, it's a solution to a problem with AC motor size/torque/speed limitations. The only way to get good power out of an AC motor without making it huge and heavy is to make it spin faster. But then the torque is low, so they gear it down with the worm drive. Either way it's still fairly long, so better to turn it 90 degrees and make a saw shape that West coast carpenters like.
Now that they can (supposedly) make a BLDC motor with good torque and rpm specs for such a saw, they can go direct drive, and eliminate the need for oil and gears to sap power.
Golden view is offline
The Following 6 Users Say Thank You to Golden view For This Useful Post:
Calidecks (07-22-2019), cedarboarder (07-23-2019), Dirtywhiteboy (07-22-2019), Inner10 (07-23-2019), VinylHanger (07-23-2019), Wile E Coyote (07-23-2019)
Old 07-23-2019, 12:01 PM   #1143
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Yup, it's like converting a saw to three phase power.
Inner10 is offline
Old 07-23-2019, 06:10 PM   #1144
META's Avatar
Trade: General and Trades
Rewards Points: 5,850
People were out calling it a worm drive awhile ago....hence my statement.
This boy is used to direct drive, so the longer body doesn't appeal. I will take a more powerful 18v, though, when Milwaukee comes out with it hopefully in 2020.
META is online now
Old 07-23-2019, 08:45 PM   #1145
META's Avatar
Thumbs down
Mike.
_______________
Yeah, I am not aware of any either. I had a Dewalt cordless circular saw about 18 years ago that didn't have much power. I doubt the battery could have supported the loss of energy via worm geering.
META is online now
Old 07-23-2019, 08:49 PM   #1146
GC/carpenter
Calidecks's Avatar
The last saw Milwaukee made has more power. It's a right side blade.
Mike.
_______________
Old 07-23-2019, 09:09 PM   #1147
META's Avatar
Mike.
_______________
I went to a tool show about a month ago and the Milwaukee guy had a full size 18v circ. It was about as heavy as a corded saw, same size. They want it out next year but are working out the kinks, he said.
META is online now
Old 07-23-2019, 09:16 PM   #1148
GC/carpenter
Calidecks's Avatar
This saws a beast maybe it was this one that he's taking about. It's the third generation.
https://www.cpomilwaukee.com/milwauk...xoCWG0QAvD_BwE
Mike.
_______________
META (07-23-2019)
Old 07-23-2019, 09:49 PM   #1149
META's Avatar
Not really a purchase, but a fun laser combo use.
So this was a surprise for me today. We were framing daylight and walkout walls and had both my Hilti and Stabila LA 180-L lasers out. We had the Stabila receiver attached to a stick level and were about to check elevations. All of a sudden it went off, and we discovered it was picking up the Hilti level laser beam. Cool, because it's a lot smaller and easier to maneuver around.
META is online now
The Following User Says Thank You to META For This Useful Post:
Calidecks (07-23-2019)
Old 07-24-2019, 05:22 AM   #1150
duburban's Avatar
Trade: building
Rewards Points: 1,772
Can you tell us how effective that stabila is for squaring ??
duburban is offline
Old 07-24-2019, 06:05 AM   #1151
META's Avatar
The biggest issue I have is getting a good line of sight when squaring up walkout foundations. However, if you can generally position the laser at center of either end, of a shorter run of a home, and align it to the center of the other side....it does well at squaring up. I try and set up parralel to the longest runs. I also use the finest setting and then I even center my actual mark between the slight variance on the receiver. In other words, I find the outside area of where the reader signals true (side to side), and then center it.
Its certainly saving me time and improving accuracy, especially on multi level foundations.
META is online now
Old 07-24-2019, 07:06 AM   #1152
META's Avatar
Just got finished comparing the accuracy between the Stabila and Hilti reads via the Stabila receiver. They were dead nuts at around 40'. I don't see much of an issue using it out to 75'. I'd verify 75' and beyond before trusting it.
META is online now
Old 07-25-2019, 08:10 AM   #1153
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 886
Big Johnson is offline
Old 07-25-2019, 11:51 AM   #1154
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 1,225
Great strategy for Bosch if they can pull it off. No one else makes the lock system (yet) so you have to buy their premium priced accessories. Or it could just flop cause no one wants to buy proprietary tools with proprietary accessories.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 07-25-2019, 12:03 PM   #1155
test
cedarboarder's Avatar
Trade: General
Rewards Points: 2,245
ya.. getting disks off easy isn't worth looking for proprietary discs in a bind. You know they will be sold out or not around when you need them haha. Hopefully they come put with an attachment to use normal discs as well
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 07-25-2019, 01:47 PM   #1156
VinylHanger's Avatar
Rewards Points: 11,674
Or the big box only carries two choices and it's never the disc you need.
Besides, I rarely change the discs on my grinder. I've had the same one on there for probably 5 or 6 years. I only grind aluminum normally, but its doesn't interest me too much.
VinylHanger is offline
Old 07-25-2019, 03:38 PM   #1157
test
Trade: General
it does suck when I can't find the wrench and im using a flat head and hammer to loosen the disc...
Old 07-25-2019, 04:54 PM   #1158
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 440
I can't remember the last time I needed a tool to change a disk--and I switch them out fairly regularly. I just hold the lock button with one hand and tighten or loosen the nut by turning the disk with the other hand.
They don't need to be super-tight to work well.
Tinstaafl is online now
The Following 7 Users Say Thank You to Tinstaafl For This Useful Post:
A&E Exteriors (07-30-2019), Deckhead (07-25-2019), Defenestrate (07-26-2019), Dirtywhiteboy (07-25-2019), Mordekyle (07-25-2019), overanalyze (07-26-2019), Xtrememtnbiker (07-25-2019)
Old 07-25-2019, 06:32 PM   #1159
test
Trade: General
that's the only way I do it. and probably why I lost the wrench haha. just one time the thing was rusted or the nut was put on with a 3 foot pipe wrench haha.
Old 07-25-2019, 07:32 PM   #1160
Mordekyle's Avatar
Rewards Points: 5,594
I went with the EGO system. Got the Weed wacker, leaf blower and the lawn mower. So I have two 2.5Ah batteries and a 7.5Ah battery. Batteries are 56 volts. Out of all of them the leaf blower is the battery sucker. Definitely like the non gasoline system.
I canít recommend their chainsaw.
The battery has such low runtime I thought it was faulty
Mordekyle is offline
Jobsite tool and toolbox security platinumLLC Tools & Equipment 15 07-15-2019 12:52 AM
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Painter's tool box, what do you use? platinumLLC Painting & Finish Work 29 08-14-2015 08:34 PM
Tool Usage Explained Kowboy Off Topic (Non Trade) 7 05-18-2015 07:42 PM
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 03:38 AM
