TBA Meeting 2 (Tool Buyers Anonymous) - Page 26 - Tools & Equipment - Contractor Talk
Old 03-23-2019, 10:50 PM   #501
VinylHanger's Avatar
Rewards Points: 13,036
Re: TBA Meeting 2 (Tool Buyers Anonymous)
Oh, I didn't catch the 1 inch socket part. Yeah, that's a bit big for anything I do as well. But it would look impressive to pull out if the tool box.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Calidecks (03-23-2019)
Old 03-23-2019, 10:59 PM   #502
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,252
It is a beast!
Mike.
_______________
Calidecks is online now
Old 03-23-2019, 11:49 PM   #503
World's Tallest Midget
Mort's Avatar
Trade: Concrete
Rewards Points: 1,580
Itd be great for the tire guy at work, not having to fire up a compressor for changing a flat out on the side of the road.
I hate signatures.
Mort is online now
Old 03-24-2019, 07:20 AM   #504
tgeb's Avatar
Rewards Points: 894
That's what I was thinking, it would be real nice for my dump truck wheels when it's time for service. Other big sized nuts and bolts that currently need a big long pipe and some luck to get loose.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
hdavis (03-24-2019)
Old 03-24-2019, 08:51 AM   #505
META's Avatar
Trade: General and Trades
Rewards Points: 7,160
I have the 1/2" 18V and I love it for setting lags and 5/8" tapcons. For around $200 bare tool, it was a great buy. It does sheer smaller bolts easily though..
META is online now
The Following User Says Thank You to META For This Useful Post:
CityDecks (03-24-2019)
Old 03-24-2019, 09:04 AM   #506
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,760
I looked at a getting an Impact wrench when I was all dewalt because dewalts would regularly burn out driving 1/4" SDS into ledgers and beams. They would get so hot I'd have to have 3 to rotate because I couldn't he them. Ok let's not even get into the conversation if how stupid long they take to charge and hot or cold forget about. You need to carry a tub of batteries. Don't get me wrong I like dewalt that have a lot of great stuff and use them as my 2nd platform but not in my environment or daily grind. They are perfect slk around for Reno work. Anyway I tested Hilti 22v. vrs dewalt vrs Maki. Hilti drove 137 1/4" x 6" SDS with 1/battery and barely warmed up. Maki did 75 but too hot to hold and 1/ bar left. Dewalt (brushless) cooking 50-60 SDS. Then Hilti came out with the sweet 7 1/4 cordless skil saw. The rest is history...I'm all Hilti now. I don't want any more tools then I absolutely need. Can't warrant another tool that will sit 98% if the Time. Like Cali said. I'll take a sawzaw to it. It is nice if needed..
Originally Posted by Calidecks View Post
I don't use it. Too much for anything I would need. It would twist heads off bolts. The largest bolts I use are 3/4" and the smaller one works fine for that. However there are times we are demoing stuff that have bolts with several layers of paint on them. This would do the trick. Even if it twisted the heads off. But it doesn't warrant buying one. A sawzall can make quick work of it.
Mike.
_______________
Sent from my E6810 using Tapatalk
CityDecks is offline
The Following 2 Users Say Thank You to CityDecks For This Useful Post:
Calidecks (03-24-2019), hdavis (03-24-2019)
Old 03-24-2019, 09:36 AM   #507
hdavis's Avatar
Rewards Points: 1,322
That's more automotive to me. With rusty bolts up here, 1000 ft-lbs does nothing, even with a penetrating fluid soak. Some you can't get to the nut to torch it, so more torque is it.
hdavis is online now
mrcat (03-24-2019), tgeb (03-24-2019)
Old 03-24-2019, 06:20 PM   #508
Unger.const's Avatar
Rewards Points: 3,050
Anybody know anything about this dude?
Unger.const is offline
Old 03-25-2019, 06:18 AM   #509
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 5,140
I purchased the Craig tracks saw kit that you attached to the underside of your Skil saw I thought it was a bit sloppy and Hass to be adjusted.....I haven’t tested the skill saw that’s made for the track.
On another note look at the power of the Makita saws all....lol
https://www.liveleak.com/view?t=uSmDl_1553468428
The Following User Says Thank You to Snobnd For This Useful Post: Leo
Snobnd is online now
mrcat (03-25-2019)
Old 03-25-2019, 07:03 AM   #510
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 4,262
Bust some nuts!!! 1800 ft. Lb. Of torque!![IMG]https://uploads.tapatalk-cdn.com/20190324/4318b0b0b51bcebf9a12c668bbed2667.jpg[/IM
POWERSTATE Brushless Motor delivers up to 1,800 ft-lbs. Nut-Busting Torque, Making it the World's Most Powerful Cordless Impact Wrench
Up to 7 lbs. Lighter Weight allowing for less user fatigue
Eliminates Compressors and Generators, providing greater portability and lower cost of ownership
4-Mode DRIVE CONTROL provides greater control over output speed and power.
Integrated lanyard loop allows for safer use and easier storage
REDLINK PLUS Intelligence ensures maximum performance and protects from overloads, heating and over-discharge
ONE-KEY Compatible: Ability to Customize, Track and Manage tools for increased productivity and investment protection. Includes the ability to set a repeatable torque output for maximum control.
Handle rotates 270 degrees and easily adjusts without a tool
LED light to illuminate the work area
Premium rubber overmold withstands corrosive materials and provides increased comfort when in use
Compatible with all M18 batteries
RECOMMENDED PRODUCTS
https://www.milwaukeetool.com/Produc...enches/2867-20
Mike.
_______________
That must be what discount tire uses to put your wheels back on.
Big Johnson is online now
Old 03-25-2019, 05:42 PM   #511
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,744
No kidding
Even when the lugs and not on straight.....their going on
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
Stryker1-1 (03-25-2019)
Old 03-25-2019, 06:21 PM   #512
test
cedarboarder's Avatar
Trade: General
Rewards Points: 815
this is a first, never been sad tool shopping before.
first tool purchase to replace the stolen tools. m12 drill kit for 100 bucks at HD.
hope it can drive a couple of deck screws.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 03-25-2019, 07:22 PM   #513
CityDecks's Avatar
Trade: Deck Builder
Been using these since October.. I'm all cordless with saws Hilti SW60 and dewalts 7 1/4. These blades are 1/2 the thickness if what my Hilti saw came with. I comfortably get 50-60 more cuts out of one battery on Hilti. The dewalt does get More but not sure how many cause it's not my primary but let's say 50 for conversational purposes. Bottom line. Less cost then Diablo. Last lil longer but more importantly less friction on saws get more out of your day. Even if it's a 3 min battery swap.
The Following 3 Users Say Thank You to CityDecks For This Useful Post:
Calidecks (03-25-2019), cedarboarder (03-25-2019), tgeb (03-25-2019)
Old 03-25-2019, 07:26 PM   #514
CityDecks's Avatar
Trade: Deck Builder
Blades side by sideTBA Meeting 2 (Tool Buyers Anonymous)-screenshot_20190325-202605.jpeg
Old 03-25-2019, 08:31 PM   #515
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,350
Originally Posted by Windycity View Post
No kidding
This is what happens when you give 17 year olds power tools. They just want to hear the tick tick tick sound as they crank the lug nuts back on
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
Old 03-25-2019, 08:45 PM   #516
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 406
Do the thinner blades tend to wander/bind more, say when ripping?
mrcat is online now
Old 03-25-2019, 08:57 PM   #517
Hack
asevereid's Avatar
Rewards Points: 346
Hate to add to your sadness... But that drill won't drive a deck screw...
That's the cordless screwdriver. It's great for doing door hardware.
Send me your address, I'll mail you a first gen M12 impact. I've got a spare.
Sent from my SM-G903W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
The Following 3 Users Say Thank You to asevereid For This Useful Post:
cedarboarder (03-25-2019), eyeinstine (04-05-2019), shanewreckd (04-05-2019)
Old 03-25-2019, 10:50 PM   #518
test
Trade: General
Rewards Points: 815
ah damn you're right haha. I was thinking of the m12 impact.
I see that the tool store has the dual combo in the flyer with (see in store for price) so it should be a good deal knowing them.
I'll return this to home depot and pick up the kit at tool supplier . Thanks for pointing that out, and thanks for offering to ship. I'll let ya know on the spare impact you got.
The Following User Says Thank You to cedarboarder For This Useful Post:
asevereid (03-25-2019)
Old 03-26-2019, 01:13 AM   #519
It will. Its pretty much all I use now. Get the bigger batteries though.
Oops, didn't notice it wasn't the impact. The impact is great.
cedarboarder (03-26-2019)
Old 03-26-2019, 05:40 AM   #520
Tom M's Avatar
Rewards Points: 11,408
Return it for the better drill itsgot to be one of the most used tools you own.
Nice gesture by asereveid......
Tom M is online now
Calidecks (03-26-2019)
Jobsite tool and toolbox security platinumLLC Tools & Equipment 15 07-15-2019 12:52 AM
tool definitions go do it General Discussion 10 05-15-2017 01:44 AM
Painter's tool box, what do you use? platinumLLC Painting & Finish Work 29 08-14-2015 08:34 PM
Tool Usage Explained Kowboy Off Topic (Non Trade) 7 05-18-2015 07:42 PM
Working from a Tool Cart basswood Finish Carpentry 41 03-24-2010 03:38 AM
