Tapco Pro 19 - Tools & Equipment - Contractor Talk
Tapco Pro 19
Old 07-10-2019, 08:31 PM   #1
DLynch0009's Avatar
Trade: Residential Remodeling
Rewards Points: 304
Tapco Pro 19
Anyone ever had an issue with the brake staying open on its own? In the last 2 weeks mine just falls closed on its own. None of the joints seem loose.
Sent from my Pixel 3 using Tapatalk
DLynch0009 is offline
Old 07-10-2019, 09:06 PM   #2
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,564
Re: Tapco Pro 19
There are a couple assist springs, one each end if I remember right . could be missing or stretched out. When I bought my Black Max new years ago it did not have them and would do the same thing, Put the springs on and it stays open now.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
DLynch0009 (07-11-2019)
Old 07-11-2019, 11:49 AM   #3
Randy Bush's Avatar
Re: Tapco Pro 19
This what it should look like.
Sent from my KYOCERA-E6790 using Tapatalk
Old 07-11-2019, 06:33 PM   #4
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 1,006
Re: Tapco Pro 19
All you need to do is just snug each bolt at the pivot joint at the back just a 1/8 - 1/4 turn
M.F Custom is offline
The Following User Says Thank You to M.F Custom For This Useful Post:
Old 07-11-2019, 11:05 PM   #5
DLynch0009's Avatar
Rewards Points: 304
Re: Tapco Pro 19
Yeah it was embarrassingly easy to adjust once I finally cleaned the brake out and found time to look at it.
This is one of the first things that have gone wrong that I really didn't even know about because I have one or two of the guys bend metal now and I didn't even know it was acting up till I used it to break some metal for my overhangs at my house.
The Following User Says Thank You to DLynch0009 For This Useful Post:
M.F Custom (07-12-2019)
