Stud Finders - Tools & Equipment - Contractor Talk
Stud Finders
Old 04-06-2014, 08:20 PM   #1
mako1's Avatar
Rewards Points: 1,094
Stud Finders
What's everybody like for a quality stud finder these days.The old Zircon finally bit the dust.Was not bad but think there should be something better out there these days?
mako1 is offline
Old 04-06-2014, 08:36 PM   #2
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,250
Re: Stud Finders
I bought a Franklen and it's pretty neat. Foolproof. 1, 2, 3 studs is obvious. I have yet to find something that really works on lath and plaster though.
Golden view is online now
Old 04-06-2014, 08:52 PM   #3
mbryan's Avatar
Trade: water restoration
Rewards Points: 552
Re: Stud Finders
Or drywall I have switched to a magnet. Plaster, um, yea....
mbryan is offline
The Following User Says Thank You to mbryan For This Useful Post:
JesseCocozza (06-20-2015)
Old 04-06-2014, 09:00 PM   #4
mako1's Avatar
Re: Stud Finders
I've used the magnet too but do some jobs where it would be nice to have one of the new ones that also locates wiring.Juist figured with todays technology there would be some really good ones out for a reasonable price.
mako1 is offline
Old 04-06-2014, 09:06 PM   #5
edward trowelhands
Trade: Diplomat
Re: Stud Finders
http://www.amazon.com/Franklin-Senso...in+stud+finder
Old 04-06-2014, 09:19 PM   #6
mako1's Avatar
Re: Stud Finders
Never seen the Franklin.I'll check it out.Thanks for the tip.
mako1 is offline
Old 04-06-2014, 09:50 PM   #7
dkillianjr's Avatar
Rewards Points: 2,464
Re: Stud Finders
I just ordered the franklin, I'll post back in a few days when I get it.
Most of the reviews seem pretty good.
dkillianjr is offline
Old 04-06-2014, 10:44 PM   #8
Stoneyard's Avatar
Trade: Journeyman Carpenter
Rewards Points: 249
Re: Stud Finders
My Zircon is still holding up well after 8 years... Though I have been using it less since I am getting better at the Tom Silva wall tap.
Stoneyard is offline
Old 04-06-2014, 10:56 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 2,292
Re: Stud Finders
These work remarkably well...
griz is online now
greg24k (07-06-2015)
Old 04-06-2014, 10:56 PM   #10
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
Re: Stud Finders
I have the franklin, best stud finder I have ever had.
SuperiorHIP is offline
Old 04-06-2014, 11:20 PM   #11
Stoneyard's Avatar
Rewards Points: 249
Re: Stud Finders
But, but, it doesn't have any flashing lights and make pretty little sounds...
Old 04-07-2014, 01:30 PM   #12
Lanya LaPunta's Avatar
Rewards Points: 565
Re: Stud Finders
I have had fewer "false" readings, with the Franklin, than anything other than the magnet based ones.
Magnets .... sometimes, I'll spend a great deal of time, sliding them up down and all around ... trying to find that elusive screw (the fifties through seventies nailed drywall is even more difficult).
It ain't the holy grail, but that Franklin unit is the best that I've found.
Lanya LaPunta is offline
Old 04-07-2014, 01:43 PM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,082
Re: Stud Finders
My knuckles, piano wire and a magnet.
Inner10 is online now
Old 04-07-2014, 02:23 PM   #14
mako1's Avatar
Re: Stud Finders
Thanks guys for the info.I'll order the Franklin based on what I've heard.
mako1 is offline
Old 04-07-2014, 06:46 PM   #15
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Stud Finders
sledge hammer & joint compound
jaydee is offline
The Following 3 Users Say Thank You to jaydee For This Useful Post:
Anderson (04-08-2014), carpenter uk (04-08-2014), DH558 (04-08-2014)
Old 04-07-2014, 08:31 PM   #16
edward trowelhands
Trade: Diplomat
Re: Stud Finders
Another plug for the Franklen: There's no wait for calibration. You don't have to start off a stud. You can start in the air, on a stud, off a stud. As you move it you watch the stud indicators move with the stud. Very easy to tell if it's reading accurately.
Also, I like the horizontal shape when looking for a stud between outlet and cabinet. I've only had it for a couple houses but so far so good.
Old 04-07-2014, 09:57 PM   #17
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 2,188
Re: Stud Finders
Have you checked out the Milwaukee Wall Scanner?
I got to play with it at a supply house, but never really used it.
Of course, it costs $400.00.
Get Off My Lawn.
"There are no big projects. There are only small machines". - R. G. LeTourneau
Old 04-07-2014, 09:59 PM   #18
edward trowelhands
Trade: Diplomat
Re: Stud Finders
I've been eyeballing the Milwaukee too. I'd buy it in a heartbeat if I ever had to drill into a slab I put radiant heat into.
Old 04-08-2014, 12:10 AM   #19
Pitto's Avatar
Trade: Cabinetmaker / Kitchen Designer
Rewards Points: 98
Re: Stud Finders
been using the franklin for a good while now, and its been great. i like the fact it does not beep. :-)
Pitto is offline
Old 04-08-2014, 05:44 AM   #20
builditguy's Avatar
Rewards Points: 1,318
Re: Stud Finders
I was about to buy the Franklin when I noticed the CH Hanson magnetic one, on the same page. I bought the Hanson one. It works great. Obviously not on lath and plaster. Drywall and thincoat plaster it is good. I also never need batteries for it.
builditguy is offline
consequences of improper steel stud drop ceiling installation mohdmaruf Drywall 29 04-02-2013 11:43 PM
Recommendations needed for wall stud scanner... svronthmve Tools & Equipment 6 09-28-2012 04:06 PM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
1-2x6 Stud Cut Through on load bearing wall. 2 top plates still in tact. raguy55 Framing 4 03-23-2012 03:44 AM
stud finders sparelink Tools & Equipment 41 02-15-2012 08:46 PM
