Stud Finder - Tools & Equipment - Contractor Talk
Stud Finder
Old 08-06-2015, 01:09 PM   #1
Creter's Avatar
Rewards Points: 1,966
Stud Finder
Anyone have a recommendation for a dead nuts accurate and reliable stud finder?
Creter is offline
Old 08-06-2015, 01:18 PM   #2
jetdawg's Avatar
Trade: tool supplier
Rewards Points: 602
Re: Stud Finder
Ch hanson for magnetic, franklin 710 for electronic.
jetdawg is offline
Old 08-06-2015, 01:22 PM   #3
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Re: Stud Finder
A strong magnet.
I've been through several stud finders, and my magnet has been dead on every time and has lasted longer than all my other stud finders.
illbuildit.dd is offline
Old 08-06-2015, 02:22 PM   #4
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 354
Re: Stud Finder
I just bought a franklin 710 prosensor from menards a few weeks ago and so far love it. It's easy to use and has been very accurate. A lot easier to get a good reading with the wide scanner. Read a lot of great reviews of it on this site so finally decided to pick one up and so far it's the best stud finder I have used, way better then the expensive zircons that work when they feel like it.
platinumLLC is offline
Old 08-06-2015, 03:27 PM   #5
Creter's Avatar
Re: Stud Finder
Thanks for the input!
Creter is offline
Old 08-06-2015, 03:35 PM   #6
tgeb's Avatar
Rewards Points: 1,170
Re: Stud Finder
I've got a Bosch stud finder that will also locate rebar in concrete and alert you to the presence of electrical wiring behind the wall, or in the slab.
http://www.boschtools.com/Products/T...spx?pid=GMS120
www.gebcon.com
tgeb is offline
Old 08-06-2015, 05:36 PM   #7
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Re: Stud Finder
Another for Franklin. I used a zircon forever. The franklin gives you a much better picture of the framing. I still keep the zircon around for detecting wires though.
Lewis Carpentry
Spencer is offline
Old 08-06-2015, 05:40 PM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Stud Finder
I've been looking for a scanner for concrete and that seems too cheap...is it good?
Inner10 is offline
Old 08-06-2015, 05:57 PM   #9
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Re: Stud Finder
A firm knock on the wall and a keen ear have yet to fail me. My money would be much better spent taking the boys to Hooters a few times for some wings and eye poppin.
kingcarpenter is offline
The Following User Says Thank You to kingcarpenter For This Useful Post:
spartancc (08-09-2015)
Old 08-06-2015, 06:10 PM   #10
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,888
Re: Stud Finder
Frig, I should have kept using an estwing and forgotten the stiletto so I could go to Hooters. Forgot that was an option.
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 08-06-2015, 06:22 PM   #11
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Re: Stud Finder
You can still hear stuff?
NY Times...."Prison Population Growing Although Crime Rate Drops..."
CO762 is offline
The Following 3 Users Say Thank You to CO762 For This Useful Post:
griz (08-06-2015), tgeb (08-06-2015), TimNJ (08-06-2015)
Old 08-06-2015, 06:36 PM   #12
Creter's Avatar
Re: Stud Finder
Not sure how far $52.47 will get you and the boys at Hooters but keep on keeping on!
Creter is offline
Old 08-06-2015, 07:51 PM   #13
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 882
Re: Stud Finder
Johnson is the best I've used to date. Though recently I had a bit of trouble on an insulated wall....maybe I need new batteries
dsconstructs is offline
Old 08-06-2015, 08:00 PM   #14
dutchroots's Avatar
Trade: Residential Builder
Rewards Points: 123
Re: Stud Finder
They don't have a smartphone app for that yet?
dutchroots is offline
Old 08-06-2015, 08:14 PM   #15
tgeb's Avatar
Re: Stud Finder
Good or not , I don't know, but it works.
I'll see if I can post a video of how well it works. It will be next week though...
www.gebcon.com
tgeb is offline
Old 08-06-2015, 08:15 PM   #16
improving homes
Rewards Points: 354
Re: Stud Finder
They actually do, http://www.homedepot.com/p/Ryobi-Pho...5500/205489747.
The Following User Says Thank You to platinumLLC For This Useful Post:
dutchroots (08-06-2015)
Old 08-06-2015, 08:38 PM   #17
Inner10's Avatar
Re: Stud Finder
Nah that's good if it works it works it's only a c note.
Inner10 is offline
Old 08-06-2015, 09:01 PM   #18
diplomat
Golden view's Avatar
Rewards Points: 1,550
Re: Stud Finder
The best thing about the Franklin is it's very clear that it's getting a good reading, and you know if there's 1, 2 or 3 studs. There's no pause while it calibrates, or restarting if you started on a stud.
Golden view is offline
Old 08-06-2015, 09:12 PM   #19
saynever's Avatar
Trade: electrical
Rewards Points: 229
Re: Stud Finder
I use a ch Hanson magnetic at work for metal studs and hat track. It works well on sheetrock with wood studs as well (locating the nails or screws holding it up). If you can source a strong magnetic (quality loose neodymium ones work too) When hanging tv brackets or something heavy requiring lags I'll go a step further and use a very fine drill bit and locate the edges of the stud so I can measure to the center. I don't do much plaster work but the old knock is my go to along with aquired basic framing knowledge and a prayer the framers followed some sort of consistent layout.
saynever is offline
The Following User Says Thank You to saynever For This Useful Post:
kingcarpenter (08-08-2015)
Old 08-06-2015, 09:14 PM   #20
House surgeon
Re: Stud Finder
There actually Is an app. And it works great for metal studs or if you find a screw in wood because it uses magnetic
Construction Master, Rake Wall so1storm Framing 0 07-22-2014 12:57 PM
I need a stud finder that actually works!!!!! CarrPainting Tools & Equipment 31 01-04-2014 03:02 PM
I Love My Stud Finder #1 Handyman Tools & Equipment 39 12-16-2013 08:57 AM
2x4 Basement Stud Walls On a Three Story Home WITH NO FOOTER Baltimore Carpentry 13 08-16-2012 07:02 PM
Stud finder SuperiorHIP Tools & Equipment 10 02-27-2012 11:46 PM
