Stair Gauge Shape - Tools & Equipment - Contractor Talk
Stair Gauge Shape
Old 04-15-2015, 07:42 AM   #1
born2climb's Avatar
Trade: Roofing
Rewards Points: 62
Stair Gauge Shape
I have wondered for years (and still do), why no one has come out with ROUND stair gauges. They are all hexagonal, aside from the blade-type Starretts. Often, when you reach the end of a board, the last mark requires flipping the square to get the mark lined up. At times, merely dropping the square BELOW the board will line it up, but, as the gauges are hexagonal, the contact points will not be EXACTLY the same as they were above the board. Does anyone know WHY the inventors chose to make them only hexagonal? I cannot see any advantage at all over round.
While on a stair gauge tangent, I also don't agree with the way most folks mount them. When using gauges, I always hold my square firmly to the stock at the desired pitch, then slide the gauges tight against the square and tighten them. If you place the gauges at the desired pitch FIRST, the reading will NOT be exact. If you don't believe me, try it yourself. It won't be off a lot, but it will not be perfect.
born2climb is offline
Old 04-15-2015, 07:45 AM   #2
Perfectionist
MF Custom's Avatar
Trade: Custom Carpentry
Rewards Points: 764
Re: Stair Gauge Shape
Agreed...
MF Custom is offline
Old 04-15-2015, 08:20 AM   #3
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Lee Valley makes round ones
TaylorMadeAB is offline
The Following User Says Thank You to TaylorMadeAB For This Useful Post:
thehockeydman (04-15-2015)
Old 04-15-2015, 08:41 AM   #4
born2climb's Avatar
Trade: Roofing
Rewards Points: 62
That's good to know. First I've seen. I even contemplated making a set out of 3/4" brass.
It's funny how things like that are. "They've always made them that way..." Never questioning WHY...and possibly dramatically improving a useful product.
Old 04-15-2015, 08:44 AM   #5
hdavis's Avatar
Rewards Points: 1,344
Because round stuff rolls away....
hdavis is online now
Old 04-15-2015, 08:56 AM   #6
edward trowelhands
Golden view's Avatar
Trade: Diplomat
The only thing I can say about the hex gauges is on lumber with an eased edge, it's a little hard to see where the gauge is touching the edge, and the hex provides a straight line to align with your previous pencil mark, even though the angle is usually off a little.
Golden view is offline
Old 04-15-2015, 11:58 AM   #7
Railman's Avatar
Trade: Railing
Rewards Points: 607
Even better would be a floating hex. That way you get the best of both.
Railman is online now
Old 04-15-2015, 12:21 PM   #8
pizalm's Avatar
Rewards Points: 824
I have a dedicated square for stairs. It's clamped between two 2x2's that slide on the edge of the stringer. Works great and impossible for it to disappear. Lol
pizalm is offline
Old 04-15-2015, 09:45 PM   #9
hdavis's Avatar
That's pretty old school.
Old 04-15-2015, 11:43 PM   #10
Young-Guy Framer
thehockeydman's Avatar
Rewards Points: 266
I have not used hex gauges since buying my round ones. Yes, they are superior in just about every way. "Roof Framing" by Marshall Gross has a nice little explanation on the advantages of round gauges to hex gauges.
Here's the link to the round ones:
http://www.leevalley.com/en/wood/pag...=1,42936,42944
thehockeydman is offline
The Following 2 Users Say Thank You to thehockeydman For This Useful Post:
griz (04-16-2015), MF Custom (04-16-2015)
Old 04-16-2015, 12:00 AM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 20
The guys who can cut stairs, without screwing up a bunch of material, who are few and far between, don't care what, if any, kind of gauge there is available.
One of the finest staircutters I have ever seen did not use a framing square.
He knew how to use one as he was a master roof cutter also.
griz is online now
Old 04-16-2015, 12:22 AM   #12
GC/carpenter
Calidecks's Avatar
Rewards Points: 26
I made this. Works great and took me about 10 minutes to make.
Calidecks is online now
hdavis (04-16-2015), m1911 (04-16-2015), MF Custom (04-16-2015)
Old 04-16-2015, 12:43 AM   #13
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
that's pretty cool
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 04-16-2015, 05:47 AM   #14
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
I use these. For rafters tooName:  ImageUploadedByContractorTalk1429181239.658619.jpg
You can rest when you're dead
SAcarpenter is offline
Old 04-16-2015, 06:24 AM   #15
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Yep. I keep lot of gauges everywhere because you know as soon as you want them, you won't be able to find them, or you loose one...
Spencer is offline
Old 04-16-2015, 07:13 AM   #16
born2climb's Avatar
Trade: Roofing
Rewards Points: 62
Originally Posted by SAcarpenter View Post
I use these. For rafters tooAttachment 168234
I have never laid hands on a set of those, but it seems if you needed to swap sides of the board, those would be farther off than the hex gauges. Am I correct?
Old 04-16-2015, 09:17 AM   #17
hdavis's Avatar
OK, now you have to say how he did it
Old 04-16-2015, 02:25 PM   #18
mako1's Avatar
Rewards Points: 1,094
I have to agree.I don't do a lot of stairs but have never owned a set of stair gauges until a few year ago.Maybe old school or behind the times but they do make life a little easrier.I have done a few sets where gauges would be pretty much useless.
mako1 is offline
Old 04-16-2015, 03:26 PM   #19
born2climb's Avatar
Trade: Roofing
Rewards Points: 62
If he did not use a framing square, what use would gauges be to him anyway?
Old 04-16-2015, 03:38 PM   #20
mako1's Avatar
I don't even know him but still found that funny for some reason.
mako1 is offline
Hitatchi 18 gauge nailer issues Wood Worx Finish Carpentry 47 03-30-2014 11:02 AM
Best adhesive for stair nosing, treads and risers etc etc BCConstruction General Discussion 11 03-31-2013 01:15 AM
1/2 story steel fire escape stair App-ironworks Specialty Trades Picture Post 6 03-09-2013 09:34 AM
Rail or stair gauge Tim the toolman Finish Carpentry 1 11-06-2010 01:09 PM
Stairtool. Stair Gauge Jeff farris Carpentry 13 03-05-2010 04:44 PM
