Snips - Tools & Equipment - Contractor Talk
Snips
Old 12-09-2017, 10:15 AM   #1
Jw92106's Avatar
Trade: Framing and remodel
Snips
What is the best snips have dewalt ones don't care for them some of my guys have fat max don't really like them
Jw92106 is offline
Old 12-09-2017, 10:28 AM   #2
Donohue Const's Avatar
Rewards Points: 1,728
Re: Snips
I like Midwest
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
Old 12-09-2017, 10:32 AM   #3
Lettusbee's Avatar
Rewards Points: 1,904
Re: Snips
Milwaukee just redesigned theirs. Might be worth a look.
Lettusbee is online now
Old 12-09-2017, 10:34 AM   #4
VinylHanger's Avatar
Rewards Points: 302
Re: Snips
What are you using them for? Malco 12's are my go to for most things, unless it is long rip cuts, then just a normal pair of offsets.
VinylHanger is online now
Old 12-09-2017, 11:18 AM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,038
Re: Snips
I use Malco offset snips.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 12-09-2017, 11:28 AM   #6
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,512
Re: Snips
I use the Malco Andy snips. I cut up a lot of scrap gutter with them. Only thing I don't like is they tighten up every so often. Not sure if it's because I'm a lefty
NYgutterguy is online now
Old 12-09-2017, 11:31 AM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 26
Re: Snips
What are you using them for mainly? I use duckbill tinner snips most of the time especially for long and smooth cut, Midwest ones too. Aviation green or red for detail cuts. Two or three sets of them a year ,just flat wear them out.
Randy Bush is online now
Old 12-09-2017, 11:32 AM   #8
Randy Bush's Avatar
Rewards Points: 26
Re: Snips
Sometimes I wish they made lefthanded tinner snips.
The Following User Says Thank You to Randy Bush For This Useful Post:
NYgutterguy (12-09-2017)
Old 12-09-2017, 12:31 PM   #9
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,654
Re: Snips
It seems that the yellow red green selections from even the same manufacturer can be hit or miss.
I bought a pair of C&R Roofer's Choice yellow a couple years ago that were fantastic. Smooth cutting the full length all the way to the tip.
Unfortunately the C&R no longer give me the same satisfyingly consistent cut. They are worn.
The Wiss M1R, M2R and M3R are usually decent, but they still have performance variation from pair to pair.
I tried the FatMax a couple years ago and returned them. I thought they were terrible.
I have MidWest left and right offset...they are reasonably good. I like them better than Malco snip of the same configuration.
I have a pair of FatMax yellow I paid $4. I wouldn't return them at that price, but they are strictly bench warmers, second string. I use them when they are a handy grab and won't complain much.
As far as shears, the Malco Andy M14 are my go to for longer and cleaner cuts. I don't think you can consistently get smooth, distortion free cuts with aviators when the cut is longer than 3" or 4"
Back to the basic aviators, L,R and straight....aside from comfort and jaw action, I think cutting performance is very hit and miss even within the same brand. IDK, I guess at around $12 we can't expect too much.
There are $40- $65ish pairs from some European makers here STORZ
I would hope at these prices their QC was more of a priority. I haven't tested the water.
Above all, a good roof
Mr Latone is offline
Old 12-09-2017, 12:53 PM   #10
TimNJ's Avatar
Rewards Points: 924
Re: Snips
I use the Wiss M7 offsets.
TimNJ is offline
Old 12-09-2017, 02:02 PM   #11
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
Re: Snips
To the leftorium!
Sent from my XP7700 using Tapatalk
SectorSecurity is offline
Old 12-09-2017, 07:35 PM   #12
Designed2Fail's Avatar
Trade: residential construction
Rewards Points: 16
Re: Snips
Erdi by Bessey branded snips. Best snips I have used hand down.
I like them better than Midwest as the cutting head is not so bulky and gets in the way. Offset as well because I can't cut crap any more with non offsets it seems.
https://www.amazon.com/Bessey-D29ASS...s=bessey+snips left cutting
https://www.amazon.com/Bessey-D29ASS...KQNHCK0DG17C62 right cutting
Designed2Fail is offline
The Following User Says Thank You to Designed2Fail For This Useful Post:
M.F Custom (12-29-2017)
Old 12-09-2017, 08:33 PM   #13
Randy Bush's Avatar
Rewards Points: 26
Re: Snips
Those look like some pretty nice snips. I like the fact that they have a smooth cutting edge. Just might have to try a set.
Old 12-09-2017, 08:43 PM   #14
Rewards Points: 16
Re: Snips
They are not serrated so don't leave the "ripple" effect.
They make a even better version but I am no longer in commercial metal work so no need for them. Never used them but do know the ones I did post are incredible for steel and aluminum.
Do like they are not made in China so that is a big plus for me. Made in Germany
Old 12-09-2017, 09:16 PM   #15
FrankSmith's Avatar
Rewards Points: 5,124
Re: Snips
I have several larger pair for long straight cuts but use the little red lift/straight snips for most all aluminum work or j channel. Anything with small cuts and bends.
FrankSmith is offline
Old 12-10-2017, 07:37 AM   #16
BeforeChristoff's Avatar
Trade: RENOVATIONS
Rewards Points: 136
Re: Snips
Nothing wrong with us lefties
BeforeChristoff is offline
Old 12-10-2017, 08:56 AM   #17
MTRmatt's Avatar
Rewards Points: 4
Re: Snips
Used a lot of different brands of aviation snips over the years. Worked on a snap on dealers kitchen and picked up a pair of reds and greens from him. Little pricey even at cost but when they dull Iíll send them back for a new set. Best Iíve used to date. IIRC 35 bucks a pair.
Matt
MTRmatt is offline
Old 12-17-2017, 04:46 PM   #18
BlueNails's Avatar
Rewards Points: 40
Re: Snips
wiss snips - tho it's only for small work, got an 18v 165mm metal saw and it's so damn handy
Sent from my ONEPLUS A3010 using Tapatalk
BlueNails is offline
Old 12-17-2017, 05:01 PM   #19
Rewards Points: 16
Re: Snips
When using offset snips don't matter what is your dominate hand. left or right. Only really work in well in one direction.
Old 12-17-2017, 07:00 PM   #20
Randy Bush's Avatar
Rewards Points: 26
Re: Snips
It is with duckbill or tinner snips that it really makes a difference.
NYgutterguy (12-17-2017)
snips.. Tom Struble Windows, Siding and Doors 10 07-09-2015 10:18 PM
German snips "Stahlwille, Hazet, ..? Designed2Fail Tools & Equipment 10 05-02-2013 01:59 PM
Great Deal on awesome Snips.... gillisonconstru Tools & Equipment 33 09-02-2012 10:03 PM
Best snips for vinyl siding? jfranklin Windows, Siding and Doors 5 01-25-2010 10:13 AM
now, what about blades and snips! bmaurice Roofing 10 10-25-2009 04:55 PM
