Snap Tile Cutters - Tools & Equipment - Contractor Talk
Snap Tile Cutters
Old 07-17-2011, 07:52 PM   #1
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
Snap Tile Cutters
So I've got my big bridge tile cutter that I drag along for all of my jobs, but recently I got turned on to snap cutters by one of the guys at work. I was always used to the cheap little ones that are flimsy and weak, but the Brutus (QEP) snap cutters at Home Depot actually perform pretty well and aren't crazy expensive. Seeing as how 90% of the cuts we make are full crosscuts, the portability of the snap cutter really shines. This is especially true for second story jobs where you really don't want to be running inside and outside for every few cuts.
For me, it paid for itself on my current tile job. Easily saved me 2-3 hours of running up and down stairs, and let me work longer because I wasn't having to hoof it all day.
Anyone else out there a big fan of snap cutters?
Remodelor is offline
Old 07-17-2011, 08:02 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Snap Tile Cutters
Spend the money and buy a rubi, you'll be glad you did.
http://www.ohiohomedoctorremodeling.com
ohiohomedoctor is offline
Old 07-17-2011, 08:06 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
I hated using them and would spend the time walking to the wet saw. On my current job, Gary convinced me that I need to use it if I ever want to speed up production.
https://www.contractortalk.com/f73/si...-review-68046/
Angus
angus242 is offline
Old 07-17-2011, 08:15 PM   #4
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Originally Posted by ohiohomedoctor View Post
Spend the money and buy a Sigma, you'll be glad you did.
Fixed that for ya
Precision Floors
(772) 237-9900
PrecisionFloors is offline
The Following 2 Users Say Thank You to PrecisionFloors For This Useful Post:
charimon (07-20-2011), CO762 (07-18-2011)
Old 07-17-2011, 08:17 PM   #5
Remodelor's Avatar
Rewards Points: 250
Totally sped me up, and I haven't had to sacrifice any quality. The Brutus 20" cutter is only about $90, and works for most of my jobs. The way I see it, it's kind of an entry level cutter to see if I really like it. If I get ahead (buying a house in a month, so it might be a bit before I can buy some shiny new tools) I will definitely look into some higher end snappers.
By the way, to anyone unfamiliar with the better cutters, the difference between some cheap $25 snapper, and a Brutus is night and day. I have heard that the Sigmas and other comparable ones are supposed to be even that much better than the Brutus level.
Old 07-18-2011, 05:14 PM   #6
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
I don't like them and rarely use them. I think a lot of it comes down to how much and of what one does.
CO762 is offline
Old 07-18-2011, 05:22 PM   #7
CO762's Avatar
Be sure to get the granite wheels. They are 5 point star shaped. Or maybe 6. I forget.
CO762 is offline
Old 07-18-2011, 05:24 PM   #8
Thom
thom's Avatar
Rewards Points: 4,748
It seems the majority of cuts are covered anyway, some by base, some by cabinets, so a perfect cut is not an issue most of the time. I use a snap cutter with a wet-saw and an angle grinder set up in the garage for the cuts that need them.
thom is offline
The Following User Says Thank You to thom For This Useful Post:
SclafaniBuilder (07-20-2011)
Old 07-18-2011, 07:24 PM   #9
jlyons's Avatar
Trade: capenter
Rewards Points: 219
i am surprised how many of you don't use snap cutters for all straight through cuts. not to mention a sigma. used a couple of cheap ones and sigma for sure is the way to go. they really aren't that expensive for how many cuts it will do over its life. and so fast and works every time.
jlyons is offline
The Following 2 Users Say Thank You to jlyons For This Useful Post:
PrecisionFloors (07-21-2011)
Old 07-20-2011, 01:04 AM   #10
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
I have, use, love and would Kill ya if you tried to take my Sigma 2D3 http://www.tools4tile.com/servlet/th...an-tile/Detail it is worth 2X the $$ more if you set on the Diagonal much
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Old 07-21-2011, 07:29 AM   #11
PROcrastinator
onthelevel's Avatar
Trade: Residential Renovation
Rewards Points: 158
Good advice fellas. I don't trust anything from the box stores to last long at all. Not made for professionals. That stuff is made for homeowners who use it once and put it in a closet for 15 years. If you do it all the time spend money.
onthelevel is offline
Old 07-21-2011, 12:37 PM   #12
Paul
That always blows my mind to. I can't count the number of floors I've done with just my Sigma and 4" Makita. Hell I can grid a small floor, make all of the cuts, and set it with RS in less time than it takes to load/unload/re-load the wetsaw, set it up, and break it down Not to mention it's a helluva lot easier on my back. I guess its all in what you're used to.
Precision Floors
(772) 237-9900
Old 07-21-2011, 11:58 PM   #13
Remodelor's Avatar
Rewards Points: 250
I wouldn't write everything off in the box stores. I've found many of the products they sell to be of professional quality. It's just a matter of weeding out the stuff for homeowner "occasional use" and the heavy tools we need to use every day.
I'll swear by most Kobalt and Husky hand tools as being professional quality, and many of the power tools made by Ridgid are very tough and high quality. Plus, you can find brands like Makita and Bosch in any Lowe's and Home Depot, and if those aren't professional grade, then I don't know what is.
The Brutus may not be a Sigma, but as someone who installs a lot of tile every year, I have to say that it certainly meets my needs.
Old 07-22-2011, 08:38 PM   #14
CO762's Avatar
Then it's a good fit for ya.
Maybe it was menards he was talking about not being worth a sh*t?
They don't "give preferential treatment to the military" as they call doing what HD/Lowes does. What those gomers do do though is put out a very light sprinkle of real, adult power tools out, then fill in the majority of their shelf space with their junk workforce and tool shop garbage.
I needed a socket to sink some lags in and they had a bunch of them, each one, $0.98!
CO762 is offline
Old 07-23-2011, 01:51 PM   #15
Plumber Will's Avatar
Trade: Plumbing
Sigma and "The Big Clinker" you can get at Home Depot (made by Ishii, under the Brutus name) are the best you can buy.
Plumber Will is offline
Old 07-23-2011, 09:15 PM   #16
CO762's Avatar
We were at a HD this afternoon to pick up a few plants, so I walked over to the tile dept and checked out the biggest brutus snap cutter.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
If it's this one and I were Ishii, I'd not put my name on it either.
CO762 is offline
Old 07-23-2011, 10:38 PM   #17
tileman2000's Avatar
Trade: tile contractor
Rewards Points: 528
I've had the Brutus cutter for about 8 years now. Used it on residential and commercial jobs. Cuts just about every tile I've had to deal with. With the exceptions of glass,marble and stone, then a wetsaw is a must.
My next cutter will be a Sigma though.
Michael
Miller Tile on Facebook
tileman2000 is offline
Old 07-23-2011, 11:16 PM   #18
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
CO762 (07-24-2011)
Old 07-24-2011, 09:38 AM   #19
CO762's Avatar
Do you have experience with both the push and the pull ones?
I've only used the pull ones (superior) and found you can get pretty good repeatability by how you grip it. And the longer one uses it, the more slop there is in it. (be interesting to know if the sigmas have this). Air tool lube works well to keep it smooth and I always have a small bottle of that around somewhere.
I saw someone else doing a ceramic floor and he had the push one. It looked like physics wise, that's a lot easier. It certainly slid well, but it looked new.
That HD brutus I messed around with had a tremendous amount of slop in the bearings and with the leverage the push handle would give you, I'd not see it lasting long. An ishii like this one should resolve that as not only is the handle more stout, but it looks like the bearings and attachments are also.
I rarely did ceramic and a lot of the porcelain I did was part of larger jobs that used mostly stone, so I had to have a wet saw there anyway. (and not to mention that snappers can walk away easier than a wet saw, but not as easy as angle grinders).
I'd like to test some of these snappers and see how well they do on the thicker, harder porcelain.
Who knows, I may get back into doing the smaller HO jobs on the side and if that's the case, may throw out the one I have and get on of those solid handled Ishiis.
CO762 is offline
Old 07-26-2011, 11:28 PM   #20
charimon's Avatar
I have used both the push and the clickclock I personally like the push
im messing with some tile tom maybe i will bring my flip and make a vid
charimon is offline
Time for a new tile guy? orson Tiling 22 06-14-2013 04:39 PM
Tile Installation Failures in a High End Remodel ChrWright Tiling 139 03-04-2013 06:28 PM
Question for the tile & carpet Guru's RocknTJ Flooring 15 08-11-2011 09:01 PM
ADS tile for driveway bridge mcdanie1 Excavation & Site Work 4 06-26-2011 09:26 PM
Tile job goin sour, what to do ? mendelectric Tiling 64 08-19-2009 02:49 PM
