Small Portable Compressors - Tools & Equipment - Contractor Talk
Old 01-09-2012, 11:32 PM   #1
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
I'm in the market for a small compressor I can throw behind the seat of my truck..
portable and light... Just to shoot some pins and brads nothing big.
What about those hotdog tanks?
Senco, makita and rolair has some decent looking ones... what do you think?
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 01-10-2012, 12:13 AM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 972
Re: Small Portable Compressors
Senco is the one you want.
http://www.coastaltool.com/senco/pc1010.htm
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 01-10-2012, 12:23 AM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 52
Originally Posted by Leo G View Post
Got one, good little compressor for trimming windows.
Randy Bush is online now
Old 01-10-2012, 02:55 AM   #4
Northwood's Avatar
Rewards Points: 266
Yeah the makita is not lightweight. You won't be "throwing" that thing anywhere. But it still may be the one you want depending on your needs. It fills and cycles very fast, has a much larger cfm than the senco, and is oiled so it will last a very long time. It will keep up for small framing.
Northwood is offline
The Following User Says Thank You to Northwood For This Useful Post:
chris klee (01-11-2012)
Old 01-10-2012, 08:18 AM   #5
Repair & Renovation
Rich D.'s Avatar
The makits does look nice... Quiet @ 80 decibles. And fast recovery.. but 52 pounds!!!!!!!
The senco is 20 pounds...
How loud is the senco?
Rich D. is offline
Old 01-10-2012, 08:37 AM   #6
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 972
It is quiet. It is small. The recovery time on the tank is a bit slow but if you are only using it for a trim gun it will keep up without a problem. This is the kind of setup you want if you don't want the big compressor.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-10-2012, 08:41 AM   #7
jb4211's Avatar
Rewards Points: 2,306
What about battery operated instead of pneumatic? I have the DeWalt 18v finish nailer which is great for that stuff, IMO. I've never had an issue.
Jon
jb4211 is offline
Old 01-10-2012, 08:42 AM   #8
Repair & Renovation
Rich D.'s Avatar
I actually need it only for about 20 brads and pins for a job
I have a d55146 4.5 gallon dewalt that can handle the bigger stuff..
I just don't want to drag that around for a couple nails....
Looks like the senco it is!!!
Rich D. is offline
Old 01-10-2012, 08:43 AM   #9
Repair & Renovation
Rich D.'s Avatar
I have the 16ga gas operated paslode...
Wish they made a battery operated pinner....
Rich D. is offline
Old 01-10-2012, 08:46 AM   #10
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 972
That would be sweet, a gas operated 23ga pinner.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-10-2012, 08:52 AM   #11
jb4211's Avatar
They do make electric; would that work better for you?
Jon
jb4211 is offline
Old 01-10-2012, 08:52 AM   #12
Repair & Renovation
Rich D.'s Avatar
One day Leo... One day....
Rich D. is offline
Old 01-10-2012, 08:53 AM   #13
Repair & Renovation
Rich D.'s Avatar
What do you mean? A gas or battery pinner?
Or those plug in Stapler/brad guns
Rich D. is offline
Old 01-10-2012, 08:53 AM   #14
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
CO2 tanks... Will run ANY of you air tools, no need to buy the same tools in cordless versions. a 2.5# will probably give you 500-1000 shots of trim nails. (I can get over 200 framing nails through 1 fill)
RobertCDF is offline
The Following User Says Thank You to RobertCDF For This Useful Post:
CrpntrFrk (02-02-2012)
Old 01-10-2012, 08:54 AM   #15
Repair & Renovation
Rich D.'s Avatar
How much for the set up? And then what's the cost of a new filled tank? Sounds interesting.. I've seen it before but never was interested...
Rich D. is offline
Old 01-10-2012, 09:00 AM   #16
jb4211's Avatar
I meant the plug-in type. I've never used any but I know they're available.
Jon
jb4211 is offline
Old 01-10-2012, 09:00 AM   #17
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 972
Usually you can get them filled at a paintball place. The compressors to fill the tanks are ridiculously expensive topping $4K
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 01-10-2012, 09:29 AM   #18
Repair & Renovation
Rich D.'s Avatar
They all look like all DIY pos
Rich D. is offline
Old 01-10-2012, 10:33 AM   #19
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
That little Senco compressor is great! I also have the Makita MAC700, and it's HEAVY for its size. The Senco is also less noisy. Pins and brads and the occasional 15/16g - Senco all day!
If I need to shoot a lot of 15g, the MAC700. It even keeps up with my framer without a problem. My pace with a framer is more slow and steady, though.
Rustbucket is online now
Old 01-10-2012, 10:34 AM   #20
RobertCDF's Avatar
Best place to fill is a welding supply house. CO2 is filled as liquid with a specialty setup from a LARGE tank (100's of gallons) OR you can fill a small tank (2.5#) from a larger tank (20#) but it can be kind of dangerous if not done properly.
Small commercial job... I mean small shanekw1 Remodeling Picture Post 12 11-01-2009 12:02 PM
pricing for a small job jack 06 Carpentry 14 08-16-2009 09:21 AM
how small a shingle? VAviaCo Roofing 25 05-23-2009 08:32 AM
OK, so DIY'ers are a small, problematic lot-2 sides of the story... Ivinni Marketing & Sales 17 02-03-2009 06:59 PM
SMALL, QUIET, HIGH CFM COMPRESSORS - THOMAS vs OTHERS? - Oilless vs. Oil? adaboy Tools & Equipment 4 09-22-2006 12:14 AM
