Slider Saw Problem - Tools & Equipment - Contractor Talk
Slider Saw Problem
Old 05-15-2011, 03:46 PM   #1
Home remodeling
jhcontracting's Avatar
Trade: home remodeling
Rewards Points: 157
Thumbs down
Slider Saw Problem
Looking for some answers. I just recently bought a makita 12"compound slider miter saw. First time for a slider style miter saw. When I cut even a 2x4 if it is just a little bowed it wants to buck back on me. But not all the time. But enough to make my concerned My son has had the same problem.
We have tried all different methods of cutting but get the same results. Had the factory guy out and of course it didn't buck on him. So he thinks theirs nothing wrong. Were not amateurs with these tools. So I'm wondering if anyone else has had the same problem. If so how do you fix it or is this inherent in all slider style miter saw
jhcontracting is offline
Old 05-15-2011, 03:57 PM   #2
GettingBy's Avatar
Rewards Points: 6,486
Re: Slider Saw Problem
******************x
GettingBy is offline
Old 05-15-2011, 04:23 PM   #3
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Are cutting correctly? Pulling the saw out, then plunge down and push in....I see a few people who think a slider is like a radial arm saw and pull it through the cut, when you should be pushing.
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
JHC (05-15-2011)
Old 05-15-2011, 05:25 PM   #4
GettingBy's Avatar
When the rep was there did he do the cutting or did you do the cutting?
You could try running many experiments on spare pieces on how often and when this happens. Damp or dry wood, wood dimensions, adequate voltage to the saw, etc.
This search using Google's advanced search option
cause saw kickback OR buck
seems to give some good hits.
You could also search for 'factory recall' or 'hidden warranty' or Technical Service Bulletin from Makita to solve this 'non-existent' problem
or class action lawsuits against Makita for similar product defects and/or product liability.
My Harbor Freight saw (was a gift) has never done this but I rarely use it. The blade rotation pushes the wood against the backstop.
Old 05-15-2011, 05:40 PM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Something you may want to consider is "hook angle" of your blade. A sliding miter saws geometry is different than that of other saws and warrants a negative hook angle. Check out these links.
http://www.justsawblades.com/systimatic/terminology.htm
http://www.rockler.com/articles/saw-...tion-guide.cfm
http://www.infinitytools.com/SawBladeUni_2.asp
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
PrecisionFloors (07-23-2011)
Old 05-15-2011, 05:43 PM   #6
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
Is your lumber crowned ? Are you supported to high on one side? I have a dewalt that sometimes trys to rip your arm off. Usually a 2x up on edge.
Chris@Sunrise is offline
Old 05-15-2011, 06:57 PM   #7
Finish Carpenter
TBFGhost's Avatar
Not true. Negative hook angle saw blades are really ment for saws like radial arms where you PULL the blade through the cut. The negtive hook helps to keep the blade from grabbing into the material and over powering you.
If your correctly using a sliding miter saw, the blades forces are pushing back against you as you push the saw towards the fence making it MUCH harder for the saw to grab in and over power you.
Think about using a circ saw, if you using it normally its not a problem to control and you have also felt how it pushes back against you as you cut. Now if any of you have used a circ saw and cut backwards you will know how much easier it is for the saw to buck and kick....
Its sorta the same thing with routers, you use a router in a counter-clockwise motion as this works against the bit, but if you go clockwise, the bit will try and push you out of the cut....
Basically, its not the hook angle.
First I would make sure you using the saw correct...second I would look at the material your cutting, if it warped and warped so where you cutting is away from the fence, as you complete the cut the two off cuts will be pushed back against the fence by the blade, which in turn will close the kerf, pinch the blade and send one or both off cuts flying.
TBFGhost is offline
Old 05-15-2011, 07:28 PM   #8
KemoSabe
loneframer's Avatar
Im not sure then why the majority of mitersaw blades are manufactured with 0 or negative hook angles.
http://www.festoolusa.com/products/s...de-495387.html
http://www.forrestblades.com/chopmaster.htm
http://justsawblades.com/ten/miter_saw_blades.html
Chr[email protected] (05-15-2011)
Old 05-15-2011, 07:37 PM   #9
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Because a positive kerf blade will tend to bite into or try and pick up the material off of the field table,depending on how you are advancing the blade into the material.
B,
PrestigeR&D is offline
Old 05-15-2011, 07:51 PM   #10
Home remodeling
Rewards Points: 157
I have looked at the way we are using it and I am confident we are using it correctly as far as how the lumber lays. I agree that if the lumber is bowed away from the fence this could be a problem. If that's true, then as far as I'm concerned that is a poor design.
With lumber the way it is today, quite often you will have lumber that is a bit bowed. Even if you go to the lumber yard and pick straight ones, they can bow at the job site before you get to use them. I will call Makita tomorrow, and report back my findings
Old 05-15-2011, 07:54 PM   #11
Dirtywhiteboy's Avatar
Rewards Points: 13,070
Originally Posted by GettingBy View Post
******************x
Dirtywhiteboy is online now
Old 05-15-2011, 07:55 PM   #12
KemoSabe
loneframer's Avatar
B,
I already knew that B. I've experimented with many blades over the years and I prefer -2 degrees in most cases for sliding saws. No more than +5 in a non slider.
Old 05-15-2011, 07:56 PM   #13
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 52
******************x
That is usually the response generated when the piece jumps on ya.
Warren is online now
Old 05-15-2011, 08:29 PM   #14
Finish Carpenter
TBFGhost's Avatar
Really? How in the world is that a design flaw?
TBFGhost is offline
Old 05-15-2011, 08:35 PM   #15
KemoSabe
loneframer's Avatar
Obviously, the fence should swivel to match the bow in the material.
Old 05-15-2011, 08:48 PM   #16
Custom Builder
Rewards Points: 502
You guys dont have flexable fences? Well then you guys must not have the auto miter corrector for bowed, twisted, cupped and crowned lumber. Im still mad that none of my saws will cut a 45 straight on a 2x12 thats cupped 3/4". Darn manufacture defects.
The Following User Says Thank You to [email protected] For This Useful Post:
loneframer (05-15-2011)
Old 05-15-2011, 08:52 PM   #17
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 420
This is actually an excellent point. I did field service work for quite a few years, and it didn't take too long at all for me to learn that if the problem wasn't evident right away, the best thing was to have the user demonstrate it to me.
In many cases, it was either a procedural error on his part, or an experience-related trick I was using without realizing it.
Tinstaafl is offline
Tom Struble (05-15-2011)
Old 05-15-2011, 09:06 PM   #18
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
yea.... but your just a mechanic
Tom Struble is offline
Tinstaafl (05-15-2011)
Old 05-15-2011, 09:10 PM   #19
KemoSabe
loneframer's Avatar
I thought he was an applicator.
Old 05-15-2011, 09:13 PM   #20
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 420
I think I'll just brush past that one.
Duraspin deck screw problem HandyHails Decks & Fencing 9 06-04-2012 05:33 PM
Gonna build a new work station for my slider. Input wanted. pinwheel Finish Carpentry 49 01-25-2011 08:31 PM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 05:41 AM
Problem in corners woodchuck2 Painting & Finish Work 28 08-01-2009 10:07 AM
Bosch 12 dual mitre saw, transport lock wont hold? commen problem? woodworkbykirk Tools & Equipment 10 10-28-2008 08:18 PM
