Siding Brake Life Span. - Tools & Equipment - Contractor Talk
Old 12-18-2014, 09:14 PM   #1
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
So I have a Tapco pro 2. about 15 years old
always kept clean and inside.
never tuned up.
probably 300 rolls of coil bent with it.
current job had about 3 rolls worth of wrapping (no big deal)
noticed it's not bending clean and straight anymore.
QUESTION IS.
What's the life span of a brake ?
No local tune up services around
Tapco can't / aren't any help
WANT ME TO BUY NEW.
INPUT ANYONE ??
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 12-18-2014, 09:23 PM   #2
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 960
Re: Siding Brake Life Span.
Thats a good brake! I have the same one about the same age. Search you tube for the video on adjusting it. Then buy a new vinyl/rubber strip for the arm. You can even get new hinge parts if you think that is getting worn.
overanalyze is online now
Old 12-18-2014, 09:26 PM   #3
Donohue Const's Avatar
Rewards Points: 1,550
I also have the same one.
Mine bends more on the outside then in the middle.
I haven't tried to adjust it but probably should.
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 12-18-2014, 09:38 PM   #4
I'm The BOSS
jaydee's Avatar
mine is bending drip cap like an arch.
seriously, small 1/4" ends up 3/8" in the middle.
tried adjusting as , stated above, cleaned, oiled,
time for an upgrade
Taking bids... ANYONE ???
Facebook
jaydee is offline
Old 12-18-2014, 09:40 PM   #5
I'm The BOSS
jaydee's Avatar
I'm bending 38" pieces , across 2 clamps
can't see how it's slipping
thought maybe hinge was worn ??????
Facebook
jaydee is offline
Old 12-18-2014, 09:46 PM   #6
MDjim's Avatar
Trade: General Contracting/Insurance Repair
time for an upgrade
Our pro 2 is doing the same thing. Just noticed on the last job.
MDjim is offline
Old 12-18-2014, 10:04 PM   #7
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 7,284
Get rid of it...Used to have to be a magician with my old brake to get to make clean bends..Bought pro 14 two years ago and well worth the piece of mind. $1200 bucks is a no brainer
NYgutterguy is online now
Old 12-18-2014, 10:18 PM   #8
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Rewards Points: 2,022
If you don't sell it....take it to a scrap yard and get some $$.
On a side note...I've had great luck switching people over to Azek because I hate to bend coil and can communicate my love for PVC over coil.
dougchips is offline
The Following User Says Thank You to dougchips For This Useful Post:
Tom Struble (12-18-2014)
Old 12-18-2014, 10:50 PM   #9
Designed2Fail's Avatar
Trade: residential construction
Rewards Points: 364
Order the hex wrench they make for turning the inside bolt arms on the break. 1/8 turn either clock wise or counter clock wise on every arm, the same direction.
Do this 3 times now break just a piece of scrap. see how it bends. if still the same then split the difference on the end arms so the middle is the same, and now go the other way of the original turn if clock wise go counter this time still only a 1/8, yet leave the ends alone just mess with the middle. now break another piece of metal again and keep doing so till you have back to good.
its the rubber gasket that grips where the handles are that allows the metal to slip as well if you measured that you would see it is thinner in the middle than the outer edges.
Designed2Fail is offline
The Following 3 Users Say Thank You to Designed2Fail For This Useful Post:
Donohue Const (12-18-2014), MDjim (12-19-2014), overanalyze (12-18-2014)
Old 12-18-2014, 10:53 PM   #10
Rewards Points: 364
disregard my post I misread your message. My bad
Old 12-18-2014, 10:53 PM   #11
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
I've had a tapco.pro 19 since 2010 that still bends good and have a tapco pro 14 that I got last year, no issues yet.
You should be able to tune it up.
BamBamm5144 is offline
Old 12-18-2014, 10:58 PM   #12
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i still know guys using 35 year old windy specials..
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
superseal (12-18-2014), Texas Wax (12-18-2014)
Old 12-18-2014, 10:59 PM   #13
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,568
Pretty much normal with them. Adjusting really does not seem to help any. On my Black Max when it does that , most of the time, just run my hand down the end to straighten the piece back up.
Randy Bush is online now
The Following 3 Users Say Thank You to Randy Bush For This Useful Post:
Donohue Const (12-18-2014), Ohteah (12-18-2014), Tinstaafl (12-19-2014)
Old 12-18-2014, 11:05 PM   #14
That's how I've been doing it now
Ryan
Old 12-18-2014, 11:32 PM   #15
Who me?
Bad Boy Biker's Avatar
Rewards Points: 191
Hey, I'm that guy.
And it still works great.
Ride Safe, Wave, I'll Wave Back.
Bad Boy Biker is offline
The Following User Says Thank You to Bad Boy Biker For This Useful Post:
Old 12-19-2014, 05:11 PM   #16
I'm The BOSS
jaydee's Avatar
so today I replaced the rubber strip.
Loosened the adustments to allow stock to slided at all clamp points
Tightened all clamps to the same tension.
AND Presto magic, NO F"in difference.
WHAT THE HELL
NEW PRO 14 OR 19 = $ 1450, IN MASSACHUSETTS
Anyone know a better deal local to me ??
Facebook
jaydee is offline
Old 12-19-2014, 07:04 PM   #17
Randy Bush's Avatar
WHAT THE HELL
When you bend a piece do you mark it out in ends and middle to see if it is staying on the marks once bent?
Old 12-19-2014, 08:55 PM   #18
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 48
WHAT THE HELL
Not local, but $1386 with free shipping from Industrial Ladder. That's where I bought mine from a few years ago.
EricBrancard is online now
The Following User Says Thank You to EricBrancard For This Useful Post:
Spencer (12-19-2014)
Old 12-19-2014, 09:04 PM   #19
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
Same here. Got mine from Industrial Ladder with all the accessories. I think it was the best deal I could find.
Spencer is offline
Old 12-19-2014, 09:51 PM   #20
Box Builder
Morning Wood's Avatar
Rewards Points: 9,898
I got one used from a dude for a couple hundred. It is a tapco. Model before the 14. It over ends on the ends and I night the rebuild kit and tuned it. No difference really. Have any of you guys ever tried to replace the hinge pin in yours? Mine is broken at the end. The last 2" or so is broken.
Morning Wood is online now
Barn Siding - Batten Nailing Technique artinall Windows, Siding and Doors 9 07-13-2012 05:03 AM
Best paint / advice for aluminum siding? Jdub2083 Painting & Finish Work 15 07-12-2012 01:15 AM
Can someone identify this siding? CharlesD Windows, Siding and Doors 2 02-12-2010 12:24 PM
siding break ?? erxloes Windows, Siding and Doors 1 11-24-2009 09:21 PM
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 06:21 PM
