SDS Max Or Spline Rotary Hammers - Tools & Equipment - Contractor Talk
Old 06-09-2019, 08:54 PM   #1
J.C.'s Avatar
Rewards Points: 170
Question
I'm pondering getting a medium duty rotary hammer and was wondering what everyone prefers, SDS Max or Spline? Does one work better in some applications than others or why is there 2 choices? Thanks
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 06-09-2019, 09:30 PM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 22,478
Re: SDS Max Or Spline Rotary Hammers
The SDS max is my goto. Unless you're drilling or chipping big stuff the spline is too big imo. I believe spline only comes in the big stuff.
Mike.
_______________
Calidecks is online now
greg24k (06-11-2019), J.C. (06-10-2019), overanalyze (06-10-2019)
Old 06-09-2019, 09:44 PM   #3
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,052
spline comes in everything sds max does . I have both sds max and spline . I Sujest the that you hit your supply house and see what they carry in bits .what is easiest for you to purchase . I suspect it is SDS MAX . The real money has been in the bits for me .some of the longer larger bits are over 100$ .not sure what you will use it for or what varity of sizes you will purchase .I now have a ton .every size requires several lengths . what size holes are you expecting to drill . SDS plus can handle just about everything size wise just fine in a smaller easier to use machine
Check ebay and craiglist . used ones can be a lot cheaper .
mine are primarily used in seismic upgrade work.
JFM constr is online now
The Following 2 Users Say Thank You to JFM constr For This Useful Post:
Calidecks (06-09-2019), J.C. (06-10-2019)
Old 06-09-2019, 09:56 PM   #4
GC/carpenter
Calidecks's Avatar
You can use SDS Max with the spline but the drill itself is a little big for anything SDS Max is needed for. Imo
Mike.
_______________
Old 06-09-2019, 10:27 PM   #5
JFM constr's Avatar
Mike.
_______________
SDS max and spline are the drive type . they are not compatible .i believe spline was here first and sds max [sds ] came over from europe .I believe in our time , pretty sure when the two of us got into the trades sds wasn't very popular if around at all.there were a couple of chuck/shank types .spline being one of them .the bits or cutting edge,cutting type has come along way in the last 10 years let alone 40 yrs .
The Following User Says Thank You to JFM constr For This Useful Post:
Old 06-09-2019, 10:33 PM   #6
GC/carpenter
Calidecks's Avatar
I understand the difference. But you can use an sds adapter on a spline, but not vis versa I don't think.
Mike.
_______________
Old 06-09-2019, 11:56 PM   #7
JFM constr's Avatar
got it .got it .yeah you can an adapter .i have never seen an adapter that would run sds to spline either .
Calidecks (06-10-2019)
Old 06-10-2019, 11:35 AM   #8
J.C.'s Avatar
Rewards Points: 170
I was doing other online research and they say the same, that SDS Max is the way to go.
I currently have a Bosch Bulldog that works great but I'm in need of a 12" deep 1 1/2" hole through a footer and it doesn't look like that's possible with the bulldog. It would also be nice to have something a little bigger for misc. chipping. Any recommendations on brand? Are the Makitas any good? Looks like they have a few options made in Japan. My boss has a 20+ year old Bosch that I've used in the past that I've never been a big fan of but a lot has changed in 20+ years. I know Hilti used to be considered the gold standard, is that still true? It's amazing how many choices there are...
J.C. is offline
Old 06-10-2019, 12:21 PM   #9
GC/carpenter
Calidecks's Avatar
I just purchased a Bosch 1-5/8. Great great for digging as well.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Old 06-10-2019, 01:07 PM   #10
J.C.'s Avatar
Rewards Points: 170
Mike.
_______________
Is that one of their German made models? It looks like it gets excellent reviews.
J.C. is offline
Old 06-10-2019, 02:27 PM   #11
GC/carpenter
Calidecks's Avatar
Yep.
Mike.
_______________
Old 06-10-2019, 08:41 PM   #12
Sisyphus's Avatar
Trade: Renovation and property management
Rewards Points: 991
I just purchased a Bosch 1-5/8. Great great for digging as well. ...
Mike.
_______________
My Bosch is similar (older version), great tool. I use it more for digging and chipping than drilling. Extensions save my back ....... https://www.homedepot.ca/product/mak...ter/1000777226
https://www.homedepot.ca/product/mak...ion/1000777227
Sisyphus is offline
The Following 2 Users Say Thank You to Sisyphus For This Useful Post:
Calidecks (06-10-2019), J.C. (06-12-2019)
Old 06-10-2019, 08:49 PM   #13
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 946
Mike.
_______________
I have the same one. It has been awesome! Bunch of tile demo and core drilling with it.
Sent from my SM-T380 using Tapatalk
overanalyze is offline
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
Old 06-12-2019, 12:18 PM   #14
JFM constr's Avatar
another insight to add to your choice .from what i have read so far not sure what your needs are . one thing that is important to me is to be able to put hold down bolts for shear walls in straight .some machines are to wide to get close enough to the post to drill a straight /plumb hole .tweaks me to do them at an angle .
One of the 1 9/16 machines has a switch on oneside that gets in the way .the other 1 9/16" machine is just to friggen large ,wide .oh well .
J.C. (06-12-2019)
Old 06-12-2019, 03:48 PM   #15
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 746
Sds max here, I have the bulldog been using it the last 5 days, but for the real work I have a Hilti
Still "Shakin" the tree boss
sunkist is online now
The Following User Says Thank You to sunkist For This Useful Post:
J.C. (06-12-2019)
Old 06-12-2019, 03:58 PM   #16
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 278
I have this one form Milwaukee.
https://www.cpomilwaukee.com/milwauk...up=miln5316-21
1 3/4" SDS Max.
It's a beast.
Made in Czech Republic. Seems pretty solid, I've had it for a couple years.
Remember when "Climate Change" was a thing??
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Calidecks (06-12-2019), J.C. (06-12-2019)
Old 06-12-2019, 05:07 PM   #17
JFM constr's Avatar
1 3/4" SDS Max.
It's a beast.
what are you using it for .when does the size pay off .
Old 06-12-2019, 07:04 PM   #18
J.C.'s Avatar
Rewards Points: 170
Since everyone seems to give the Bosch good reviews, I ordered one last night. Should have it Friday.
J.C. is offline
The Following User Says Thank You to J.C. For This Useful Post:
Old 06-12-2019, 08:08 PM   #19
JFM constr's Avatar
what model
Old 06-12-2019, 08:39 PM   #20
Trade: Highwayman
Rewards Points: 278
I can drill 3/4" x 6" or 3/4" x 7" holes in aged concrete in less than 30 seconds a piece.
Makes quick work of 4" holes, too. I'll drill a bunch of smaller holes and then blow it out with the chipping function.
The chipping function is really good. I've chipped out sections of footings and sidewalks with it.
It's big and heavy, but for the remodel stuff that I do, it works well for me.
