Saw Horses - Page 2 - Tools & Equipment - Contractor Talk
Saw Horses
Old 12-05-2013, 09:32 AM   #21
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 492
Re: Saw Horses
I have the best set of saw horse you ever see, I have to get a picture of them, a guy PA makes them, not sure if he has a website, but he has a welding shop, they are just legs and clamp them on any 2 x 6 or 2x4, I have even put a 16' 2x8 on to cut rafters, I'll get apicture!!
Jonbuild is online now
Old 12-05-2013, 07:52 PM   #22
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Re: Saw Horses
Originally Posted by KAP View Post
Aside from the ones we make for ourselves, as far as store-bought goes, these are some of the strongest, economical, lightweight, stable, easy up and down, small-footprint and versatile horses around...
Bought ours for $27/each 6-8 years ago... now they go for $37/each... they da' bomb...
I use these daily. The biggest problem is they went from AL legs to plastic a while ago, the plastic ones are MUCH LESSSTABLE. It is sad when they have a product that is awesome and in an effort to save $3-4 a unit they make it 1/2 what it used to be.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Old 12-05-2013, 08:04 PM   #23
KAP's Avatar
Trade: Custom
Rewards Points: 38,038
Re: Saw Horses
Still have the ones we bought years ago... no need to get a newer one, these will last forever, but sad to hear about the downgrade... they are awesome though...
KAP is offline
Old 12-05-2013, 09:33 PM   #24
Jonbuild's Avatar
Rewards Points: 492
Re: Saw Horses
Here is a few pictures of my saw horse, prob 5 or 6 years old and just like new, maybe a few more coats of paint from spray painting trim, my last color was white as you see, new they are a gray color
Old 12-05-2013, 09:43 PM   #25
smeagol's Avatar
Trade: new construction and remodeling
Rewards Points: 638
Re: Saw Horses
Anyone else use stablemate horses? We love em
smeagol is offline
Old 12-05-2013, 10:41 PM   #26
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Re: Saw Horses
Conceptually looks like the Trojan's.
Rustbucket is offline
Old 03-13-2014, 07:15 PM   #27
Carpenter
Boda's Avatar
Trade: Residential Carpentry
Rewards Points: 464
Re: Saw Horses
Here is what I am after. A set of saw horses that has the following.
Light Weight
Portable
Foldable
Sturdy
Compartment to hold a saw, like between the legs at the end of the horse, so you don't have to bend over and set your saw on the ground or hang it off a nail, where it gets bumped and crashes to the floor ****ing up the table.
I am thinking about just building a set out of wood, though the folding and light weight issues are the biggest challenge.
Boda is offline
Old 03-13-2014, 07:25 PM   #28
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,272
Re: Saw Horses
Yep! Have two sets. They are nice.
overanalyze is offline
Old 03-13-2014, 07:25 PM   #29
Always Learning
Re: Saw Horses
Light Weight
Portable
Foldable
Sturdy
Check out Basswood's tri horse design.
Old 03-13-2014, 07:56 PM   #30
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Re: Saw Horses
Trojans
http://www.amazon.com/Trojan-TS-35-T.../dp/B0000224RO
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 03-13-2014, 08:18 PM   #31
FSCROB's Avatar
Trade: General Contracting, Metal roofing
Rewards Points: 252
Re: Saw Horses
Originally Posted by shakey0818 View Post
The best ones i have and are super light weight and easiest to fold up are the metal ones from depot.
http://www.homedepot.com/p/Workforce...1#.Up_rQcRDu8A
I do like these the best for height adjustment but there a pain in the azz if you don't use a bolt and a wing nut to keep the adjustable legs from falling off.I really like that you can adjust the height when my back hurts and need my work area higher.
http://www.homedepot.com/p/Crawford-...9#.Up_sGMRDu8A
I had a pair of those collapse on me once destroying a really expensive cabinet. I won't buy them again.
FSCROB is offline
Old 03-13-2014, 09:23 PM   #32
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Re: Saw Horses
why were you under them?
m1911 is offline
Old 03-13-2014, 10:25 PM   #33
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Saw Horses
These might fit the bill.
RobertCDF is offline
Old 03-14-2014, 05:25 AM   #34
Carpenter
Boda's Avatar
Rewards Points: 464
Re: Saw Horses
Those look nice.
I assume your just using door hinges on those?
Do they seem fairly sturdy, do they fold in on themselves when you don't want them to?
Thanks.
Boda is offline
Old 03-14-2014, 06:17 AM   #35
Stephen H's Avatar
Trade: Slate& Tile Roofing/Exterior Carpentry
Rewards Points: 2,848
Re: Saw Horses
robert,
I am glad you showed those folding horses.
we use some that are very similar- I think I stole the design that I saw years ago in a Fine Homebuilding issue. Our design has the legs splaying in 2 different directions though.
I made the first pair out of some scrap redwood5/4's that I had. Eventually we liked them so much we built 3-4 more pairs out of poplar.
they are very strong and very stable-we use them as low level staging often.
occasiuonally we will screw a scrap piece of wood across to lock them open-but those cases are few and far between.
then are VERY strong-we stack slate on them every day, use them as saw tables in conjunction with a home made miter saw extension we have, we use them as sheet metal brake stands etc. Ours are tall enough that I can fit a trash can under them and set 2 planks spaced on top and cut slate right there letting the debris fall directly into the trash can. they are durable-we have been using the same4-5 pairs for YEARS-and they take up little room on the truck. Every truck has 1-2 pairs at all times so every job will have 2-3 pairs of these set up and working.
stephen
Stephen H is offline
The Following User Says Thank You to Stephen H For This Useful Post:
RobertCDF (03-14-2014)
Old 03-14-2014, 06:38 AM   #36
RobertCDF's Avatar
Re: Saw Horses
Those look nice.
Thanks.
Thanks. Yup, just crappy brass door hinges.
They can want to fold in on you but I find the plastic folding ones tip over in the same situations.
Old 03-14-2014, 12:00 PM   #37
BenderBoy's Avatar
Trade: Siding
Rewards Points: 38
Re: Saw Horses
I have used the Trojans and they are sturdy and compact, but those DeWalt horses look awesome.
BenderBoy is offline
Old 03-14-2014, 04:27 PM   #38
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
Re: Saw Horses
Thanks for the mention. I'll post a few photos here of my design and a link to the LJ thread on them. I'll be happy to answer any questions.
http://lumberjocks.com/projects/96307
Saw Horses-943354_519461721423322_1610508865_n.jpg   Saw Horses-945410_527298287306332_286138605_n-1.jpg   Saw Horses-1902839_637461402956686_271239669_n.jpg
basswood is offline
The Following 2 Users Say Thank You to basswood For This Useful Post:
Boda (03-15-2014), mikeswoods (03-15-2014)
Old 03-14-2014, 04:41 PM   #39
Stunt Carpenter's Avatar
Rewards Points: 2,486
Re: Saw Horses
We uses these for everything.
Really stable and lightweight.
https://builddaley.com/
Stunt Carpenter is offline
The Following User Says Thank You to Stunt Carpenter For This Useful Post:
wallmaxx (04-30-2015)
Old 03-14-2014, 05:02 PM   #40
Nail-Bender
Brutus's Avatar
Rewards Points: 2,020
Re: Saw Horses
I make my own out of 5/4x4 and 2x6....
2' long legs, 2x6 top 3' long, edges ripped at 5* with spreaders 1' off the ground. PL and screw it together.
Originally Posted by 2ndGen
If you haven't bled while working once in your life, you haven't worked!
Brutus is offline
Fat Max Horses TBFGhost Tools & Equipment 30 06-10-2012 08:05 PM
Foldable saw horses. DuFast Tools & Equipment 42 09-22-2011 09:52 PM
High Horses and "Ironing Boards" for Detail Work basswood Finish Carpentry 47 06-15-2010 06:31 PM
A Morton Building, 4 horses, and me mc handyman Carpentry Picture Post 5 09-24-2009 01:34 PM
Shocked horses tgeb Electrical 19 02-21-2007 08:47 PM
