Ryobi Hinge Template Kit - Page 3 - Tools & Equipment - Contractor Talk
Old 01-05-2011, 06:09 PM   #41
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
Re: Ryobi Hinge Template Kit
looks to me like you could set the template out 1/16th of an inch and then grind the edge of the hinge 1/16 the of an inch and pulll it in to close those gaps >
?????? im just a taper but plan on doing this as a diyer soon.
oldrivers is offline
Old 01-05-2011, 06:25 PM   #42
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
Originally Posted by BCConstruction View Post
Don't anybody use the porter cable ones. I find they fit the hinges perfect. That ryobi one looks about as good as their tools are. I could make a tighter fit with a plumbers chisel.
The PC is the only one I own and will use.
I have a set of hinge leaves for each size hinge to set the jig up on the jamb.
Pop those in the old mortise on the jamb tack the individual guides to the jamb set the spacer bars, remove and rout door. It is always dead nuts accurate never have a hinge slightly off so 2 go in and the third is off and has to be redone.
It did however cost more than $25.00
The nail holes have never been an issue.
Catching sunbeams and putting them to work
WWW.solarsaves.net
[email protected]
naptown CR is offline
Old 07-04-2015, 12:21 PM   #43
mikecarsy's Avatar
Rewards Points: 190
For rounded edges I use a 1/2 spade bit in the two corners then cut the rest out with a chisel, if I don't buy square hinges.
I was thinking about buying a 1/2 round chisel but I might just give this Ryobi template a try.
mikecarsy is offline
Old 07-04-2015, 02:13 PM   #44
tjbnwi's Avatar
Rewards Points: 4,332
I have used the Ryobi hinge template, very nice for a few doors. Unlike the pictures in the original post the hinges fit perfectly.
tjbnwi is offline
Old 07-04-2015, 07:06 PM   #45
TimberlineMD's Avatar
Rewards Points: 738
I think it's the collar on the router that is wrong. They have a thin wall and a thick wall collar. I know if I get them mixed up with my porter cable fixture vs. my templaco fixture I get strange results.
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
Old 07-05-2015, 05:47 PM   #46
Perfectionist
MF Custom's Avatar
Trade: Custom Carpentry
Rewards Points: 764
That Ryobi kit comes with a top bearing bit to follow the plastic jig, the kit is plastic and a bit sloppy...
MF Custom is offline
The Following User Says Thank You to MF Custom For This Useful Post:
TimberlineMD (07-06-2015)
Replacing My Dewalt Tools With Ryobi Tools rstarre Tools & Equipment 181 07-26-2017 06:19 PM
Stanley hinge template Pakfan Finish Carpentry 14 04-01-2010 06:45 AM
1960s craftsman hinge mortising template loneframer General Discussion 9 03-17-2009 05:20 AM
Which hinge template gzec Carpentry 3 03-09-2007 09:03 PM
Door hinge template Pearce Services Tools & Equipment 4 03-11-2006 06:28 PM
