Ryobi AirStrike Trim Nailer - WORTHLESS - Tools & Equipment - Contractor Talk
Old 12-06-2018, 06:22 PM   #1
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,502
No,worse than useless.
Still on first box of nails.
Gets cold - at all - wont fire.
Warm it up - go back outside - maybe 6 shots and it craps out again.
Use it inside - fkn POS cant even consistently set shoe molding.
I said shoe molding ! Nails standing proud ! FFS
And heavy? My God, its weights more than my old antique Paslode framer.
SmallTownGuy is online now
Old 12-06-2018, 06:24 PM   #2
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 112
Re: Ryobi AirStrike Trim Nailer - WORTHLESS
They’re all junk. I have the hitachi’s. I had a dewalt. Junk junk junk.
The Hitachi’s are now going for like $200 for the kit with battery and charger.
Big Johnson is offline
Old 12-06-2018, 06:55 PM   #3
test
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,096
Originally Posted by Big Johnson View Post
Theyíre all junk. I have the hitachiís. I had a dewalt. Junk junk junk.
The Hitachiís are now going for like $200 for the kit with battery and charger.
I hope not I just got a dewalt 18ga. haha
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 12-06-2018, 06:56 PM   #4
Rewards Points: 112
Good luck.
Old 12-06-2018, 07:09 PM   #5
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 190
My employee has been using mine instead of air for about 2500' of trim. 18 gauge one. It looks different than yours. No issues aside from the weight. Also using Milwaukee 15 GA for the same job. Also heavy as hell but very convenient to just hang on belt and work.
Golden view is offline
TRThomas (12-07-2018)
Old 12-06-2018, 07:19 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 15,847
I have that gun and it's fine for occasional use. Try putting a bigger battery on it.
MarkJames is offline
Old 12-06-2018, 07:24 PM   #7
rrk's Avatar
Rewards Points: 2,612
I have one and it works great so i got the pin nailer also
Heavy but not heavier than the old dewalt I gave away
rrk is offline
Old 12-06-2018, 07:32 PM   #8
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 600
Well, it is a Ryobi.
I made the mistake of buying a couple Ridgid products. Not honest-to-goodness Ridgid plumbing tools, I mean HD Ridgid crap.
Should have just set my fvxxing money on fire.
The Following 4 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
avenge (12-06-2018), Azekdust (12-07-2018), Calidecks (12-06-2018), SmallTownGuy (12-06-2018)
Old 12-06-2018, 07:34 PM   #9
test
Trade: Workaholic
I felt the same about the drill and batteries. one year of use then trashed.
Old 12-06-2018, 07:38 PM   #10
Rewards Points: 112
I bought the ryobi caulk gun. It broke. I probably got less than two cases out of it. Caulk guns don’t like me, I get 30 tubes max out of any caulk gun before it breaks. Quart or 10 oz.. I don’t buy the cheap guns either.
Old 12-06-2018, 07:57 PM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 920
I love my little Grex gas finisher. However I will never be able to vouch for it when it's real cold.
Mike.
_______________
Calidecks is offline
Old 12-06-2018, 08:15 PM   #12
TimNJ's Avatar
Rewards Points: 5,216
Going through the same thing with my new Makita.
Sensor problem according to the guy at the service center.
taking it back tomorrow...again.
TimNJ is offline
Old 12-06-2018, 08:27 PM   #13
John the Builder
No and HELL NO !
Old 12-06-2018, 08:32 PM   #14
Lettusbee's Avatar
Rewards Points: 964
I've been using my Ryobi Narrow crown stapler for a year now. But when weather got cold a couple of weeks ago, and it stayed outside overnight in the gang box, I learned that nope, they definitely don't work when it's cold. Was only like 40 degrees too. Did get down to mid 20s at night though.
Lettusbee is offline
Old 12-06-2018, 08:58 PM   #15
hdavis's Avatar
Rewards Points: 350
I bring all the lithium batteries in. I left a jump pack in the car, and it was worthless until it warmed up for quite awhile. NiCad works fine, but they just don't have power density.
hdavis is offline
Old 12-06-2018, 09:07 PM   #16
Lettusbee's Avatar
Rewards Points: 964
My dewalt battery nailer worked just fine.
I usually park inside so hadn't had that perspective on my cordless tools in a while.
The Following User Says Thank You to Lettusbee For This Useful Post:
cedarboarder (12-07-2018)
Old 12-06-2018, 10:06 PM   #17
edward trowelhands
Trade: Diplomat
Rewards Points: 190
Mike.
_______________
Have they made more than an 18 gauge yet?
Old 12-06-2018, 10:10 PM   #18
GC/carpenter
Calidecks's Avatar
Rewards Points: 920
Not that I know of.
Mike.
_______________
Golden view (12-06-2018)
Old 12-06-2018, 10:19 PM   #19
edward trowelhands
Trade: Diplomat
Rewards Points: 190
Not that I know of.
Mike.
_______________
Just looked, they have a pinner coming. How's your gun work after it's been sitting for a few weeks? Fires right up?
Old 12-06-2018, 10:40 PM   #20
GC/carpenter
Calidecks's Avatar
Rewards Points: 920
Yep so far. The only nuance is I'm left handed and I keep hitting the latch button for the gas cartridge. But it's not too bad.
Mike.
_______________
Window Trim options stipeoutwest Historical Restoration 2 05-03-2016 08:22 PM
painting costs for trim Ron Brown General Discussion 5 04-24-2016 11:07 PM
ryobi battery powered brad nailer scottktmrider Tools & Equipment 10 06-01-2015 10:24 PM
Another Azek trim ? (Lone) redwood Carpentry 26 03-08-2015 03:12 PM
Trim Carpenter Wants More Money.... rdr8887 General Discussion 104 06-10-2012 03:47 PM
