Router And Table? - Tools & Equipment - Contractor Talk
Router And Table?
Old 06-10-2010, 06:19 PM   #1
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
Router And Table?
Looking to purchase a new router and table setup. Looking for something portable. Whats good out there?
mnjconstruction is offline
Old 06-10-2010, 06:50 PM   #2
mikeswoods's Avatar
Trade: interior remodeling
Rewards Points: 2,664
Re: Router And Table?
If you just want a job site router table --you might be able to make one better than you can buy.
My job site table is a 3/4" melamine covered particle board shelf 4 feet long.
Router base screwed to that.
Four foot long fence (2-1x4 strips of cabinet ply with blocks to keep it square) Screwed to the table on the left side--Quick-Clamp on the right.
I've built raised panel doors and loads of trim ,on site,with one of these.
The fence is the only short coming--no separate adjustment left and right side of the blade--
But seriously--how often would any one need that on a job site?.
----Mike----
mikeswoods is offline
The Following 2 Users Say Thank You to mikeswoods For This Useful Post:
mnjconstruction (06-10-2010), WNYcarpenter (06-10-2010)
Old 06-10-2010, 06:57 PM   #3
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
You can get good results building your own portable table.
I use a Porter Cable 1.5h router that does everything I need working in the field.
WNYcarpenter is offline
The Following User Says Thank You to WNYcarpenter For This Useful Post:
mikeswoods (06-10-2010)
Old 06-10-2010, 07:01 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,748
I can't wait for this:http://www.festool.co.uk/Products/Pa...00-Set-GB-240V
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 06-10-2010, 07:03 PM   #5
mikeswoods's Avatar
That's my favorite router.too. Simple,tough and well balanced.
I just posted this--Depot is closing out the PC 2 1/4 hp variable speed--got one for $89--last week.
Nice table router.
Old 06-10-2010, 07:23 PM   #6
wannabe
Trade: carpentry
Here's my rolling mill....
mnjconstruction (06-11-2010)
Old 06-10-2010, 07:54 PM   #7
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
i built one similar to this however, i made the top a bit beefy..... i made it so i could mount a plate to the router then drop it into the table. however with this the top is too thick and the bit barely comes up through. bought a new router today so some modifications are the plan for the weekend if not building a new table. just cant decide if i want to add a t-track and allow for a mitre gauge slot
woodworkbykirk is offline
Old 06-10-2010, 11:34 PM   #8
mattsk8's Avatar
Trade: Building and remodeling
Rewards Points: 2,738
I got quite a bit of use out of the bosch that HD sells for 190$. It's actally a nice router table. The only shortcoming is oddball sized plate the router screws to. If you ever want to get a routerlift you can't cuz no one makes one that size. Aside from this I have no complaints.
I think my next move is to make my own table top out of melamine or formica some MDF and mount it to the bosch stand, make one about a foot wider, deeper and get the routerlift for it.
If you think you'll ever make cabinets w/ it put the t-track in, almost a must. T-track is cheap and easy and you'll be glad you did it in the long run. Hope this helps. Also, I use the porter cable 892 2 1/4hp router and love that as well. It's about 3 years old now and still works great!
Woodcraft had a really goot deal on a Freud (I think it was a Freud) table and router combo that looked awesome but I don't think they have any more, that was probably a month or two ago.
mattsk8 is offline
Old 06-11-2010, 07:39 AM   #9
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
I use this with my Rousseau table saw
It''s portable
Router is Porter Cable 3-1/4HP
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 06-11-2010, 09:12 AM   #10
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
It''s portable
Hey tcleve4911,
I like that setup. Do you mind if I ask where you found the nice metal router base plate for that extension?
The Rousseau ones I see are all plastic and supposedly prone to bowing when the router is mounted to them, speaking of which, is that blue plate mounted in the middle of the stand one of them?
It almost looks like you have incorporated an actual Rousseau router table into the extension, if so thatís a cool idea.
DuMass is offline
Old 06-11-2010, 11:34 AM   #11
tcleve4911's Avatar
The base plate on the router is a Rousseau base plate. Never had a problem with bowing and that a PC 3-1/4 HP set in it!!!
The plate in the table is a Kreg hold down plate for pocket joining.
The "router table" is a wing extension that I bought from Rousseau and adapted the fence and router to it.
It all breaks down and fits neatly in the trailer.
This pic shows the entire table top setup in the above pic now shown packed in the trailer. If you look close, the Maktable saw is in the cubby to the right. It's all in there!!!!!
Thanks for the comments
Tom C
Back in Maine
Dubbin' Around
The Following User Says Thank You to tcleve4911 For This Useful Post:
DuMass (06-12-2010)
Old 06-11-2010, 02:25 PM   #12
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Tom C
You my friend are damn near my hero with your ability to use space. I have seen your set-up before and really love the fact that you get all that in the trailer and its i organized. Everything has it cubby which makes for going to get tools fast and you know exactly when you have a tool missing. I was a auto-body mech. when I got out of high school, my tool box "looked" like your trailer...everything had a home, and when I left a tool in a car by accident I knew right away.
While I don't take everytool to every job, I would like to set-up a trailer to house the tools and when I get the larger trim jobs I can just pull and park the trailer there...
On a total side not and thread jack, I am looking to upgrade to a GMC 2500HD with-in the month, and then will start looking into buying and building a trailer similar to yours...
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
tcleve4911 (06-24-2010)
Old 06-12-2010, 12:54 PM   #13
topsail's trimcat
Rewards Points: 384
ok so i just picked up a mounting plate for a router, gonna start modifying the table i built or may have to build a new one..... what should the underside of the top look like and such. any pointers for how to fix the router to the table,
i have a milwaukee router
Old 06-12-2010, 06:40 PM   #14
alboston's Avatar
Rewards Points: 688
As another Rousseau fan, tcleve has an excellent setup. I have had the Rousseau table saw setup for a while and have slowly added to it with mostly outfeed tables. The Kreg clamp down mod may be next with the router extention to follow. No miter slot though right?
alboston is offline
Old 06-16-2010, 10:11 AM   #15
Gary L's Avatar
Trade: Mission Oak Furniture Builder
Rewards Points: 91
I had a Powermatic 66 but needed something to horse around to job sites in my trailer.
I bought a new Royobi BT 3000 and began setting it up with all the gadgets available back then and also a router Quick Lift set up. It has been a great saw and set up and produced plenty of dust along the way.
Turning perfectly good wood in to dust.
Gary L is offline
Old 06-26-2010, 06:30 PM   #16
topsail's trimcat
Rewards Points: 384
so i just finished building my router table today, today was just making a fence, installing t track and putting some laminate on the top
all in all
$6 in mdf
$15 1/2 plywood for the top
$15 for the switch
$8 for the laminate and contact cement
$10 for the two toggle clamps
$5 track
$ 6 10 pack of t track bolts
$6 2 knobs for the fence
router and table?-roter-table.jpg   router and table?-router2.jpg   router and table?-router3.jpg
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mnjconstruction (06-26-2010)
Old 06-27-2010, 09:37 AM   #17
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
I'm planning on building my own table, similar to that but I want a slot for a featherboard both on the flat and the fence. The bosch table is not a bad deal at 190. I just want the table to be longer I need to find a place to buy the T track and accessories from.
I want to incorporate that quick lift insert as well because I like how you can change the height from the top of the table.
ApgarNJ is offline
Old 06-27-2010, 10:41 AM   #18
Gary L's Avatar
Rewards Points: 91
I am very satisfied with the Quick lift and adjustment is a breeze and very accurate. There are other brands I looked in to but this one seemed to suit my needs well.
I did have a Bosch plunge mounted under and found it a total PITA to get it adjusted which is what pushed me to buy the lift.
Feather boards are a great idea and very useful.
Pics when you get it built Apgar.
Gary
Gary L is offline
Old 06-27-2010, 10:55 AM   #19
topsail's trimcat
Rewards Points: 384
i bought my track and compoents at busy bee tools. lee valley has the stuff as well but for more $$$
as for the wood, it was mdf i had lying around along with the poplar plywood. i bought the laminate and glue for this
BEST router table, Lift and router combination? grafcustom Tools & Equipment 22 07-21-2011 06:00 PM
table mounted router notillegal Tools & Equipment 17 04-19-2010 10:27 PM
Bosch router table w/ router mattsk8 Contractor Swap 0 01-01-2010 10:51 PM
router table plans platinumLLC Tools & Equipment 2 04-29-2009 07:14 AM
Replacement fence for Porter Cable 698 router table Panzer5 Carpentry 4 04-10-2009 10:47 AM
