Rotary Hammer Vs. Demo Hammer - Tools & Equipment - Contractor Talk
Old 12-25-2016, 09:43 AM   #1
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
I have a 1 1/8" Bosch SDS+ but will be getting another tool with more chipping power. It will primarily be used for demo of tile floors and mud beds but drilling capability is nice to have.
I'm looking at the makita hr4013 that offers 8.1ft/lbs impact, which is far better than the 2.6ft/lbs from my Bosch. Is this well suited for tile demo over wooden subfloor or should I get a larger demo Hammer and lose drilling capability?
Also, where can I buy refurbished Bosch & makita that is not affiliated with CPO? I haven't come across any alternative dealers.
philcav7 is offline
Old 12-25-2016, 09:59 AM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,052
Re: Rotary Hammer Vs. Demo Hammer
Combination drills and chippers are excellent, the only thing you willl appreciate from a demo hammer is the weight balance and longer reach. With combi hammers you need real long chisels to not be hunched right over.
Inner10 is offline
Old 12-25-2016, 10:05 AM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 2,178
for refurbished try:
www.tylertool.com
www.acmetools.com
griz is online now
Old 12-25-2016, 12:07 PM   #4
philcav7's Avatar
Is a Bosch @ 6.1ft/lbs or Makita @ 8ft/lbs adequate for my application? Do I need more? My only comparison is my existing unit. It works, but at times is a little slow.
Just not sure if there's a happy medium. Obviously for concrete demo and drilling, more power is always better, but that's will be a rare occasion for me.
I was initially looking at Bosch, but the extra power always catches my attention.
philcav7 is offline
Old 12-25-2016, 12:28 PM   #5
Inner10's Avatar
Tile and mud beds shouldn't require much power. Heck you could probably get by with an SDS.
Inner10 is offline
Old 12-25-2016, 02:18 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,327
I have a 1" Makita SDS. It tears up tile and mud beds, no problem.
Tinstaafl is online now
Old 12-25-2016, 02:23 PM   #7
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
They make extension rods and couplers so you can stand while breaking out tile.
RobertCDF is offline
Old 12-25-2016, 02:54 PM   #8
Renaissance Man
superseal's Avatar
Rewards Points: 5,814
I like the old style Milwaukee 5347...can't get them like this anymore except when they pop up on Ebay.
These things hit hard and won't die except for brushes every ten years or so...
http://www.ebay.com/itm/MILWAUKEE-HE...3D271061091889
It'll core up to 6" and SDS adapter works with smaller drill bits. It is spline drive however which I tend to favor anyway.
Rotary Hammer vs. Demo Hammer-scarduzio-crack-005a.jpg   Rotary Hammer vs. Demo Hammer-latini-drain-002a.jpg   Rotary Hammer vs. Demo Hammer-buongiorno-001a.jpg
supersealconstruction.com
superseal is offline
The Following 2 Users Say Thank You to superseal For This Useful Post:
Calidecks (12-25-2016), charimon (12-26-2016)
Old 12-25-2016, 03:15 PM   #9
Eyeway!'s Avatar
Trade: Electrical
Rewards Points: 146
From the names labeled on the pictures , you must work for a lot of Italians!
Sent from my SM-G930T using Tapatalk
Eyeway! is online now
The Following User Says Thank You to Eyeway! For This Useful Post:
superseal (12-25-2016)
Old 12-26-2016, 12:23 AM   #10
philcav7's Avatar
My 1 1/8" does well too, but don't know how much easier a larger will make it.
I think I will save $200 and get the Bosch 6.1ft/lbs unit which is far greater than my 2.6. The money I save will go to the CT36 fund. If I feel it's not enough, I will return it and get the makita.
philcav7 is offline
Old 12-26-2016, 04:32 AM   #11
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
For tile I use the Bosch Bulldogs. The extreme Max has outstanding vibration control. I use them almost exclusively I have several sds Max hammers that do not get used much anymore. I do saw grout joints on concrete and cut through mud bed and CBU assembly's and pull them as tile sized sandwiches. This seems to be the overall fastest/cleanest method for us.
charimon is offline
The Following 2 Users Say Thank You to charimon For This Useful Post:
overanalyze (12-26-2016), TNTRenovate (12-26-2016)
Old 12-26-2016, 12:26 PM   #12
philcav7's Avatar
What do you do for dust management when cutting the grout/mud?
philcav7 is offline
Old 12-26-2016, 12:55 PM   #13
charimon's Avatar
Duct tape (working on a leather one) I hook
them to an Ermator S26
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
superseal (12-27-2016)
Old 12-26-2016, 03:02 PM   #14
Dirtywhiteboy's Avatar
Rewards Points: 10,030
https://www.youtube.com/watch?v=pz2-us9O0U4
That's great! When I did that same thing the dust cloud was huge. I think the neighbors hated us. Why not just use a grinder with a dust shroud and dust port for a vac? They even have tables on them.
Dirtywhiteboy is offline
Old 12-26-2016, 11:11 PM   #15
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,918
i own milwaukee model 5352 . called 1 1/8" machine i believe . your comments on your machine really grabbed my attention .I found the chipping feature to be severely lacking and drilling much over 7/8" out of it's range . I am wondering if I under estimate it's ability . I rented a bigger mahine to run 4" core .could not imagine it handling much more then a 2" core . I have never tried to take up tile with it .
JFM constr is offline
Old 12-26-2016, 11:16 PM   #16
Inner10's Avatar
The size rating is the max recommend, the optimal size is always less. Hammer core bits of any size suck rocks.
Inner10 is offline
Old 12-26-2016, 11:50 PM   #17
Hair Splitter
TNTRenovate's Avatar
Trade: General
Rewards Points: 1,016
I have four...love the Bulldogs.
Tried & True on Facebook
Tried & True Website
TNTRenovate is offline
The Following User Says Thank You to TNTRenovate For This Useful Post:
charimon (12-30-2016)
Old 12-30-2016, 05:42 PM   #18
charimon's Avatar
for cutting up a floor this is more ergonomic than a grinder based platform. It is easier to push the saw, If that makes sense. The worm/hypoids seem to take the hard intermittent use well. This saw was purchased in 2013 and seems to be running fine.
charimon is offline
Rotary or Hammer only demo hammer tgeb Tools & Equipment 16 02-18-2015 07:58 PM
Occidental hammer holder and suspenders asgoodasdead Contractor Swap 5 02-19-2014 06:35 PM
Speeds for a rotary hammer. Robie Tools & Equipment 13 09-15-2012 02:04 PM
Best Demo hammer Calidecks Tools & Equipment 14 08-07-2012 11:17 PM
Rotary Hammer Drill Ground Rod Driver Airrace Electrical 1 02-12-2011 11:36 AM
