Rockwell Sonicrafter Vs. Fein Multimaster - Tools & Equipment - Contractor Talk
Old 12-04-2009, 02:50 PM   #1
Duck042's Avatar
Rewards Points: 75
Anyone tried both that can weigh in on the pros & cons of each, such as vibration, heat, blade life, etc.
Thanks in advance,
-Duck042
Duck042 is offline
Old 12-04-2009, 03:00 PM   #2
Mickey
mickey69125's Avatar
Trade: residential remodeling
Rewards Points: 75
Re: Rockwell Sonicrafter Vs. Fein Multimaster
Haven't tried the rockwell so maybe this won't help you. I bought the Fmm250Q multimaster a while back and can't believe how I ever got along without it. It is a very well made tool and the quick change lever for changing blades works really well. Blades are expensive, so far I've only used off brand blades and they seem to be OK. Haven't had it long enough to really tell if they are as good as the Fein ones though.
I always learn more by listening that I do by talking.
mickey69125 is offline
Old 01-07-2010, 08:02 AM   #3
AndersonsWworks's Avatar
Trade: Custom Cabinetry
Rewards Points: 75
Like Mickey, I have the Multimaster and don't know how I did without it. When you are on a job and you say to yourself "How am I going to do that?" the Multimaster is the tool. My main use has been in installing a base cabinet in the middle of a baseboard run. Instead of removing maybe 12' of baseboard I can easily cut out the section for the cabinet.
Mickey, where do you get your off brand blades?
Rocky
AndersonsWoodworks.com
AndersonsWworks is offline
Old 01-07-2010, 08:40 AM   #4
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,414
Al in California is one of us:
http://www.multiblades.com/
http://www.imperialblades.com/
We Fix Houses is online now
The Following User Says Thank You to We Fix Houses For This Useful Post:
AndersonsWworks (01-07-2010)
Old 01-07-2010, 08:58 AM   #5
rayh78's Avatar
Trade: GC - Home repair
Rewards Points: 280
I have not used the rockwell but have heard it works about as good and the best of the clones.
Its a better buy, and I myself would try it if I ever need to replace my Fein.
Everything about the Fein is great, but I feel they really take advantage with the blade prices.
By the way, if you ever need to cut something that you know will ruin a blade, then just use a cheap $5.99 harbor freight blade.
It will still work on my newer Fein with the star pattern blades. It does not fit in the star pattern but clamps tight against it with the tool less blade change.
Only done this a couple of times but it has worked.
rayh78 is offline
Old 01-07-2010, 09:46 AM   #6
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Originally Posted by We Fix Houses View Post
Thank you for that link
Has anyone else had trouble with the metal cutting blades? Cutting nails or small bolts.....They don't seem to cut as well as they should. Just curious.
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 01-07-2010, 10:00 AM   #7
I have the MM 250Q. I think its safe to say that with any of these blades as soon as you hit a nail the blade is toast. It does very poorly cutting steel nails. A bit better cutting soft metals. Forget about cutting bolts. I was a little disappointed too. Not like a Sawzall.
At $15 - $25 a blade I've stayed away from cutting nails / bolts. If I do, I plan to add $40 - $50 or so even on to a small job which is a lot compared to what I usually add for shop supplies / disposables ??
Old 01-07-2010, 10:03 AM   #8
tcleve4911's Avatar
Where do you get your blades?
Back in Maine
Dubbin' Around
Old 01-07-2010, 10:10 AM   #9
Originally Posted by tcleve4911 View Post
Who makes the MM250Q? Just curious. Where do you get your blades?
http://www.fein.de/fein-multimaster/...ster_sets.html
Got mine last July. Have since bought about $200 in Fein blades. I needed them the next day...Next blade buy will be with the links I posted. Just like a Sawzall, I've got to have a wide assortment.
Old 01-07-2010, 02:39 PM   #10
The Deck Guy
Greg Di's Avatar
Rewards Points: 2,000
If you get an older Multimaster without the star on the blade holder, you can buy a little adapter from Fein to add the star to the tool. It makes a big difference as the blades won't vibrate loose which was an issue on the original MMs.
I just welded the adapter to my MM so it will never get lost.
But, stupid me didn't register it 90 to the tool body, so every time I put on a blade, it's like 10 off kilter.
Greg Di is offline
Old 01-07-2010, 03:01 PM   #11
Mickey
Rewards Points: 75
All the blades that I have are from Imperial Blades. They seem to be a decent blade and they are about half price of Fein.
The Following User Says Thank You to mickey69125 For This Useful Post:
Old 01-07-2010, 03:15 PM   #12
jcalvin's Avatar
Rewards Points: 534
Rockwell Owner Here
I wanted the MM but wasn't sure enough about how frequently I would use it so I bought the Rockwell instead. I figured a bill was easier to have sitting on the shelf un used than four. I am VERY satisfied with the tool. I have never used a MM so can't really give them both a fair shake on which is better but there is only two things I don't like about the Rockwell, but they are minor. The blade change isn't tool free like the MM and is somewhat aggrivating but no worse than a allen head screw on the sawzall. The other thing is there is about 10 feet of cord on it with enough room in the case for 5 feet. Somewhat a pain to put it back up, but again tolerable. I wouldn't pay the difference to have these two things changed. As far as the blades go, I buy mine from Amazon. Cheapest price with fast free shipping. Liked the tool so well and was tired of having to loan it out to my dad, I bought him one for christmas.
Cal
You hired WHO
jcalvin is offline
Old 01-07-2010, 07:18 PM   #13
galla35's Avatar
Rewards Points: 250
I have a MM and love it.. Ive used the dremel version and they suck compared to the Fein
galla35 is offline
Old 01-08-2010, 12:02 AM   #14
Northwood's Avatar
Rewards Points: 266
I have a magazine that reviewed 5 of them (Home Workshop, Canadian).
Here was what the 3 editors thought:
Fein:Best overall for power, quality, and versatility. And Expensive. Great tool free design.
Rockwell: Most power, lack of variable speed, heavier, may have some tool slippage due to tool attachment system.
Dremel: Most comfortable, light, good tool attachment.
King: Very affordable, no variable speed, lower quality.
Bosch: Cordless very convenient, good tool holding system, good in all areas,lightweight, and very quiet.
Seemed they liked the fein cuz its the best, bosch because it was very good and convenient, and the dremel as the a great value on a budget.
Northwood is offline
Old 01-08-2010, 10:59 AM   #15
jcalvin's Avatar
Rewards Points: 534
I had some problems early on with the blades coming loose on mine, but after checking it out, I wasn't tightening the cap screw on the blade enough. I gave it an extra grunt when I put it on and haven't had a problem since.
Cal
You hired WHO
jcalvin is offline
Old 01-08-2010, 11:16 AM   #16
Likewise.
I'm happy with the Rockwell
for the bucks.
I do see it as very important
to keep the recess on the arbor screw
cleaned out well.
If the allen wrench doesn't seat
it would be easy to round it out.....
neolitic is offline
Old 01-08-2010, 05:44 PM   #17
MHIC licensed contractor
eXpatRioteX's Avatar
Trade: Home Improvement
Rewards Points: 150
Used the heck out of the harbor freight and the dremmel versions this week. Set the dremmel on high and never changed the speed. For the $29 i paid for the HF one i got my money's worth. I always thought all these tools were a scam, but they actually worked, go figure.
eXpatRioteX is offline
Old 01-15-2010, 08:50 PM   #18
Ashcon's Avatar
Trade: Renovation contractor, finish carpenter
I have the fein multimaster, bought it with the gray metal case a few years back. Really like it it cost me about $450-$500 if I remember correctly. Last year I bought a chicago tool from harbour frieght. Cost $ 39.00 the blades about $5 each, the complete tool cost less than the blades for my MM. We are doing alot of windows this last year and we use the HF one for alot of our work. If one of the guys drop a $ 40 tool from a ladder it is forgivable. I prefer the length of cord on the MM. If you are not sure go for the HF it will get you through most jobs. I can use the MM for more kinds of work. For cutting the glazing from windows or removing the caulk from brick, I even use it to cut off shims. Cheap or expensive if you remodel you need one of these tools. Good luck!
Ashcon is offline
Old 01-15-2010, 09:26 PM   #19
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
I use the Dremel...it gets HOT when you run it for a long period of time, but I use it for small things like cutting molding that is already mounted, under cutting jambs, cutting outlets in cherry paneling, I also use it to finish plunge cuts in flooring made with my circ saw.
TBFGhost is offline
Old 01-17-2010, 11:38 AM   #20
Aiken Colon's Avatar
Trade: Construction Supplier
Rewards Points: 150
The Bosch Multi X blades will fit your saw, and they are 25%-50% cheaper, and might be a little easier to find.
JJ
Aiken Colon is offline
Fein MultiMaster tool BrianFox Finish Carpentry 21 05-24-2012 08:49 AM
Fein multimaster. Who has one or tried one? BCConstruction Tools & Equipment 64 12-23-2009 10:11 PM
Fein Multimaster rayh78 Tools & Equipment 45 05-12-2009 07:39 PM
multimaster vs crain 820 for undercutting denverboz Flooring 8 07-31-2008 10:45 PM
Fein Multimaster newenergy Tools & Equipment 12 06-17-2008 02:28 PM
