Replace Extension Ladder Bolts? - Page 2 - Tools & Equipment - Contractor Talk
Unread 04-11-2019, 11:23 AM   #21
Bull Trout's Avatar
Rewards Points: 320
Re: Replace Extension Ladder Bolts?
Originally Posted by ct123123 View Post
I have a 20 foot heavy aluminum extension ladder from the late 70's or early 80's which we've been using since then no problem. All the rungs and everything seem perfect except the bolts which aren't aluminum of course are rusty so I want to replace the bolts.
I emailed Werner and said something like 'hi I don't have the exact model # but what type/grade bolts do you suggest', - they gave me a "The bolts are not to be replaced. Take the ladder out of service." i.e buy another ladder from them.
or i.e. they care about the safety of people using your ladder
I don't see what the problem would be granted the bolts fit snugly through the holes with minimal rattle. It's basically just one nylon lock nut and one bolt per Rung Lock which is where all the weight is riding on, and then a nut and bolt on each of the clawed/hinging feet which I often use.
I wouldn't use a full threaded bolt, I'd use threading only on the end so the weight of ladder isn't resting on threaded section.
I know stainless is very rust proof but not very strong unless you spend like $10 per bolt for stronger grade. Hot Dipped Galv also very rust proof but not very strong, usually grade 2. So I'm thinking to use grade 8 yellow zinc, these are probably 1/4" bolts. Sounds good?
I don't know why I may be overthinking this but just asking anyway. I mean the ladder is rated for like 375 pounds, I'm about 180 max with tools/material, and even the weakest grade 2 HDGalv 1/4" bolt would hold thousands of pounds but I just want to make sure I replace them with the best option. a new ladder is the best option
Any suggestions? buy a new ladder thanks
you are welcome
Bull Trout is online now
Unread 04-11-2019, 12:53 PM   #22
ct123123's Avatar
Trade: multi
Rewards Points: 52
you sure that's an osha violation to replace a ladder bolt with one of equal or greater strength and corrosion resistance?
It's not a case of neglect, the bolts I'll be using exceeds OEM/osha ladder specs.
Of course the internet forum answer is 'replace the ladder', but I'm just going to replace the bolts.
It's like saying you can't replace a car's wheel studs with aftermarket having equal or greater specs, or to replace the rope of an extension ladder.
At least the info is out there now if someone searches to replace ladder bolts that we've pointed out to use the proper Shoulder bolts and also grade 8 zinc would be extremely strong and corrosion resistant (as would grade 5 silver zinc), don't use the grade 2 bolts usually in the bins at box stores.
ct123123 is offline
Unread 04-11-2019, 01:20 PM   #23
John the Builder
SmallTownGuy's Avatar
Rewards Points: 5,208
No. It's like saying YOU don't know the first thing about OSHA.
And its a **** ing 200 dollar ladder. ffs
God, I love this business. Ya meet all kinds.
SmallTownGuy is online now
The Following 4 Users Say Thank You to SmallTownGuy For This Useful Post:
Bull Trout (04-11-2019), Calidecks (04-11-2019), Fishindude (04-11-2019), Ohio painter (04-11-2019)
Unread 04-11-2019, 01:35 PM   #24
Bull Trout's Avatar
Rewards Points: 320
1910.23(b) refers you to 1910.22(d) When any correction or repair involves the structural integrity of the walking-working surface, a qualified person performs or supervises the correction or repair.
You asked the qualified person, they said to take it out of service, just because you can replace the bolts, doesn't make you qualified to replace them
Your bolts will not exceed specs, they will violate them because, you asked the qualified person and they told you to take the ladder out of service
Neither the rope or the wheel studs are structural walking/working surfaces and would fall under different regulations
At least the wrong info is out there now if someone searches to replace ladder bolts that we've pointed out to use the proper Shoulder bolts and also grade 8 zinc would be extremely strong and corrosion resistant (as would grade 5 silver zinc), don't use the grade 2 bolts usually in the bins at box stores.
You could replace the ladder for less than $300, to me it would be a no brainer, but Im just some guy on the internet
The Following User Says Thank You to Bull Trout For This Useful Post:
Unread 04-11-2019, 01:36 PM   #25
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 6,048
Just change them. Have never ever heard of osha checking the bolts on a ladder or measuring to see if you cut a rung off.
NYgutterguy is online now
Unread 04-11-2019, 01:49 PM   #26
Bull Trout's Avatar
Rewards Points: 320
They probably don't check until after they fail.
I don't remember if it was state or federal, but a local company got fined or threatened with fines because ladders that had their company markings on them and that they were cycling out of service, where tossed in the dumpster, and someone "saved" them and one of the ladders failed, yada, yada, yada, now they cut up their ladders when cycling them out of service
Unread 04-11-2019, 01:51 PM   #27
water re-locater
Do the ladder companies have some top secret, extra super strength bolts or something?
Unread 04-11-2019, 02:08 PM   #28
Bull Trout's Avatar
Rewards Points: 320
concerning compliance, does it matter?
just because I can build a strong ladder out of 2x4, doesn't mean I can use it on a job site
it might be a regulation too far, but I'm just gonna spend the $300
Unread 04-11-2019, 02:13 PM   #29
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,606
ya because they obviously have such high standards. Why do they build them with a bolt that rusts.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Unread 04-11-2019, 02:14 PM   #30
John the Builder
When you "trimmed" yer ladders, did ya lose sleep over it? Hell no, you got handed a problem, decided on a solution, and moved forward.
And I damned sure would bet you didn't try fixing them BEFORE they were broken.
That right there is the difference.
Unread 04-11-2019, 02:50 PM   #31
Fishindude's Avatar
Trade: Industrial
Rewards Points: 754
If this ladder thing has you stirred up, get to know the OSHA regs and details regarding extension cords.
Fishindude is offline
The Following 3 Users Say Thank You to Fishindude For This Useful Post:
Bull Trout (04-11-2019), Ohio painter (04-11-2019), SmallTownGuy (04-12-2019)
Unread 04-11-2019, 02:55 PM   #32
water re-locater
Lol. There’s a long thread about that couple years back
The Following 3 Users Say Thank You to NYgutterguy For This Useful Post:
Bull Trout (04-11-2019), hdavis (04-11-2019), SmallTownGuy (04-11-2019)
Unread 04-11-2019, 10:21 PM   #33
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,724
Any ladder I remove from service gets cut up, then I give the aluminum to whoever wants to recycle it.
To me this is about respecting the safety of your employees, if you don't have employees do as you wish.
Ohio painter is offline
Unread 04-11-2019, 10:28 PM   #34
GC/carpenter
Calidecks's Avatar
Rewards Points: 14,070
I fell from a ladder in 2000 framing a golf clubhouse (go figure) had surgery and recieved 4 plates 13 screws and part of my hip bone in my right wrist. I was out a full year.
Ladder falls need to be taken seriously and anytime you can control the situation by not using a ladder that's been Frankensteined (or is that Frankensteened) together is a no brainer.
Mike.
_______________
Calidecks is online now
The Following 6 Users Say Thank You to Calidecks For This Useful Post:
Bull Trout (04-11-2019), hdavis (04-13-2019), Ohio painter (04-12-2019), SmallTownGuy (04-12-2019), tgeb (04-12-2019), TxElectrician (04-15-2019)
Unread 04-11-2019, 10:33 PM   #35
GC/carpenter
Calidecks's Avatar
Technically any repairs done on any equipment has to be done by someone that can certify the repair. I believe. Not positive about this. But I think extension cords can't be repaired unless done by an electrician. Again not exactly sure on this.
EDIT: I SEE FISHNDUDE ALREADY COVERED THIS
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
Bull Trout (04-11-2019), Ohio painter (04-12-2019)
Unread 04-13-2019, 07:33 AM   #36
Box Builder
Morning Wood's Avatar
Rewards Points: 9,604
I’ve replaced the catches on my ladders before. I wouldn’t hesitate to replace parts on a ladder assuming they are the correct replacement parts. For the most part I am the only one using my ladders. With common sense it’s fairly simple to tell if your ladder is safe or not.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Randy Bush (04-13-2019)
Unread 04-13-2019, 11:03 AM   #37
hdavis's Avatar
Rewards Points: 6,210
If anyone has ever seen any of the ladders used in barns....
hdavis is online now
SmallTownGuy (04-13-2019)
Unread 04-13-2019, 11:19 AM   #38
hdavis's Avatar
I'm not too worried about bolts. I never heard of bolts giving way on any ladder.
Wood rot? Yup.
Split wood? Yup
Bent ladder? Yup
Overload? Yup.
I've actually seen a case where an aluminum ladder had the feet replaced with PT and attached to a building as a fire escape. BIs apparently didn't have an issue with it, It was sturdy.
If the visual is good, foot it solidly, tie it off, and don't overload it. That covers the majority of ladder issues. Setting aluminum ladders around power lines is obviously an issue.
Unread 04-15-2019, 09:39 PM   #39
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 2,038
By the time you figure out what bolts to get and go get them then take it all apart and replace it isn't your one better spent making money?
I can be to HD and back in 20 min with a new ladder would cost me about $200.
Would take me an hour or two to go and find the bolts replace them and so on. In two hours I can easily make $200.
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
The Following 2 Users Say Thank You to Stryker1-1 For This Useful Post:
Bull Trout (04-15-2019), hdavis (04-15-2019)
Unread 04-15-2019, 11:10 PM   #40
hdavis's Avatar
You aren't getting a 375 lb rated ladder for $200.
replace coping or pour coping Santa's Helpers Pool Construction & Enclosures 2 04-05-2013 11:02 AM
Any ideas other than to replace it all? Dustincoc Electrical 37 11-29-2012 09:49 PM
Telescopic Extension Ladder Inner10 Tools & Equipment 20 06-27-2012 10:56 AM
Galvanized Bolts Mitch M General Discussion 16 09-21-2010 05:23 PM
40' Aluminium Extension Ladder LNG24 Tools & Equipment 0 02-06-2007 11:05 PM
