Replace Extension Ladder Bolts? - Tools & Equipment - Contractor Talk
Old 04-10-2019, 09:47 PM   #1
ct123123's Avatar
Trade: multi
Rewards Points: 64
I have a 20 foot heavy aluminum extension ladder from the late 70's or early 80's which we've been using since then no problem. All the rungs and everything seem perfect except the bolts which aren't aluminum of course are rusty so I want to replace the bolts.
I emailed Werner and said something like 'hi I don't have the exact model # but what type/grade bolts do you suggest', - they gave me a "The bolts are not to be replaced. Take the ladder out of service." i.e buy another ladder from them.
I don't see what the problem would be granted the bolts fit snugly through the holes with minimal rattle. It's basically just one nylon lock nut and one bolt per Rung Lock which is where all the weight is riding on, and then a nut and bolt on each of the clawed/hinging feet which I often use.
I wouldn't use a full threaded bolt, I'd use threading only on the end so the weight of ladder isn't resting on threaded section.
I know stainless is very rust proof but not very strong unless you spend like $10 per bolt for stronger grade. Hot Dipped Galv also very rust proof but not very strong, usually grade 2. So I'm thinking to use grade 8 yellow zinc, these are probably 1/4" bolts. Sounds good?
I don't know why I may be overthinking this but just asking anyway. I mean the ladder is rated for like 375 pounds, I'm about 180 max with tools/material, and even the weakest grade 2 HDGalv 1/4" bolt would hold thousands of pounds but I just want to make sure I replace them with the best option.
Any suggestions? thanks
Here are examples of that the bolts are replaceable despite what Werner said, and they are thicker on the shaft that the threaded section. What are these bolts called? But I can ask online bolt retailer too no problem.
These are probably grade 5 zinc not as strong or corrosion proof as grade 8 yellow zinc but either way no problem as long as they don't get rusty eventually:
https://www.zoro.com/werner-replacem...iABEgJoYPD_BwE
https://www.rona.ca/en/ladder---extension-ladder-locks
https://www.walmart.com/ip/Rung-Lock...100D/149593176
https://images.app.goo.gl/hRzk9o2mwFUJPiYc8
ct123123 is offline
Old 04-10-2019, 10:15 PM   #2
GC/carpenter
Calidecks's Avatar
Rewards Points: 16,548
Re: Replace Extension Ladder Bolts?
Can you imagine if they gave you info on replacing structural ladder bolts and someone was killed? Get a new ladder. If an employee falls and gets hurt and you wrenched on the ladder you will be named in a lawsuit. And it won't matter if it was the bolt that caused it or not.
It could be the best 200 bucks you've ever spent.
Mike.
_______________
Calidecks is online now
AustinDB (04-15-2019), SmallTownGuy (04-11-2019), Stryker1-1 (04-15-2019)
Old 04-10-2019, 10:19 PM   #3
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,800
Shoulder bolts .
Idothat is offline
Old 04-10-2019, 10:21 PM   #4
ct123123's Avatar
Trade: multi
Rewards Points: 64
yea but I mean a bolt is a bolt granted it's the same or stronger strength and corrosion resistance, and scrapping a ladder for 4 bolts is a bit ridiculous. It would just be me using the ladder also BTW, and seldom do I need this ladder.
true liability is likely why Werner don't get into suggestions on replacement parts if there's no exact model # to go by. This ladder isn't even a werner it's a top of the line pro ladder a roofer left behind once... honestly not stolen or anything BTW.
Shoulder Bolt is what's called the bolt thicker on the shank than the threaded end. I'm just going to email the bolt websites and see what the strongest most rust proof they got in the size I need. The bolt can hold a car each basically, I am overthinking this I think.
ct123123 is offline
Old 04-10-2019, 10:24 PM   #5
Idothat's Avatar
Google Werner ladder parts , you should find what you are looking for.
Idothat is offline
Old 04-10-2019, 10:34 PM   #6
GC/carpenter
Calidecks's Avatar
I thought you had employees.
Mike.
_______________
Old 04-10-2019, 10:37 PM   #7
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 6,478
Buy a new one. They are cheap. Love when I get a new ladder. Gonna grab another 1A 24’ from city ladder next week to keep on my truck for estimates. Think it’s like $220.
NYgutterguy is online now
The Following 2 Users Say Thank You to NYgutterguy For This Useful Post:
Calidecks (04-10-2019), SmallTownGuy (04-11-2019)
Old 04-11-2019, 07:51 AM   #8
John the Builder
SmallTownGuy's Avatar
Rewards Points: 7,272
A thing in most metro areas is bonded and insured and rated ladder repair businesses.
That is because the liability even on a new ladder is huge.
If you are a single proprietor/no employee outfit, yeah, we all have done "stuff". For the rest of us, you dick with it - you carry the full burden of whatever sh!t befalls you.
Throw the GD thing away. ffs
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Calidecks (04-11-2019)
Old 04-11-2019, 08:07 AM   #9
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,163
I've got a 40' with a sketchy rung that I should retire. I keep it because it's relatively lightweight for the size, but the round rungs are tough on the feet.
Every once in a while I jump on the loose rung to see if it's still holding. So far, so good.
Oh, and almost forgot that I have trouble collapsing the ladder, so I need a second ladder to reach up and hold open the mechanism as it collapses.
(Honestly, this ladder just sits in the yard now, but all of the above was true for a while.) :
MarkJames is online now
Old 04-11-2019, 08:13 AM   #10
VinylHanger's Avatar
Rewards Points: 9,934
A 40 year old ladder and you are worried about buying a new one?
Who even uses aluminum anymore. Those old ones have crappy locks and by now it has to be a bit floppy.
I wouldn't put any employees on it, or myself for that matter.
Also, why call Werner if it isn't their ladder?
VinylHanger is online now
Old 04-11-2019, 08:16 AM   #11
water re-locater
All my ladders are aluminum. You only use fiberglass ?
The Following User Says Thank You to NYgutterguy For This Useful Post:
Old 04-11-2019, 09:10 AM   #12
Fishindude's Avatar
Trade: Industrial
Rewards Points: 820
Scrap that antique out and buy a new one.
It is an OSHA violation to modify a ladder in any way, meaning you can't change bolts.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
Old 04-11-2019, 09:14 AM   #13
water re-locater
I have a 35’ ladder that used to be a 36’. Also have a 31’ that used to be a 32’. Truck clipped the back of my truck lol.
Old 04-11-2019, 09:16 AM   #14
Fishindude's Avatar
Trade: Industrial
Rewards Points: 820
OSHA Violations if push came to shove.
Old 04-11-2019, 09:59 AM   #15
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,784
If you inspect the ladder very closely you may see other signs of wear, if they ride around on ladder racks that is surprisingly hard on aluminum ladders and they can wear where they ride on the racks.
Like others have said we have all done stuff we shouldn't but if you have an employee or anyone but you will climb it then forget fixing it and scrap it.
If you are an empoyer you open yourself up to massive liability should something happen and that is how you have to think. No one likes it.
Ohio painter is offline
Old 04-11-2019, 10:08 AM   #16
As a side story regarding ladders, one of my employees had an old step ladder that he owned in the back of his truck. One day I looked at it and suggested he replace it as it was in poor shape. He knew he should but never did. I finally was tired of seeing it and worrying about him or someone else on it (not on a job but at his home on a weekend) so I cut the ladder up and went and bought him a new one.
Yea I take ladder safety seriously and I did not want my employee hurt in a fall on his own time.
The Following User Says Thank You to Ohio painter For This Useful Post:
Fishindude (04-11-2019)
Old 04-11-2019, 10:10 AM   #17
Ed Hartmann's Avatar
Rewards Points: 208
If your ladder was much older it would be cut up and leaning on a living room wall holding a quilt. You will like a new one.
Ed Hartmann is offline
Old 04-11-2019, 10:27 AM   #18
hdavis's Avatar
Rewards Points: 1,722
Rusty bolts? Wire brush, tape off, spray, done.
hdavis is online now
Old 04-11-2019, 10:32 AM   #19
Yep. Aluminum isn't safe around wires and I can't stand to touch it. It's an OCD thing.
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
Calidecks (04-11-2019), hdavis (04-11-2019)
Old 04-11-2019, 10:34 AM   #20
hdavis's Avatar
I have an extension ladder older than the OP's that rated for 650lbs or so. Almost never need it. I'm not getting a new one in my lifetime unless that one gets ruined.
replace coping or pour coping Santa's Helpers Pool Construction & Enclosures 2 04-05-2013 11:02 AM
Any ideas other than to replace it all? Dustincoc Electrical 37 11-29-2012 09:49 PM
Telescopic Extension Ladder Inner10 Tools & Equipment 20 06-27-2012 10:56 AM
Galvanized Bolts Mitch M General Discussion 16 09-21-2010 05:23 PM
40' Aluminium Extension Ladder LNG24 Tools & Equipment 0 02-06-2007 11:05 PM
