Repairing Aluma Plank Walkboards - Tools & Equipment - Contractor Talk
Old 10-20-2014, 05:05 PM   #1
Brickie's Avatar
Trade: One on top of Two
Rewards Points: 570
I have a bunch of Werner ( & a few Bil Jak) Aluma Plank walkboards that need the plywood replaced. Has anyone had any luck doing this? Are there kits that one can buy or do you do it from scratch?
Indiana is a Right To Work State. Proud To Be Non-Union
Brickie is offline
Old 10-20-2014, 05:20 PM   #2
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 272
Re: Repairing Aluma Plank Walkboards
I set the skill at 1/4 ..Then run down the center . The ply will pull out somewhat easy. The bitch Is getting the the new ply In. I Just lightly pry on the flanges with a drywall hatchet [ The blade] Before sliding the new board in. It takes a few choice words to get the new ply in but It will slide in and fit tight !!
I need to replace the ply on 8 10' Planks ..My problem Is finding 10' ply.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 10-20-2014, 05:25 PM   #3
Drywall Slave
blacktop's Avatar
Rewards Points: 272
Originally Posted by blacktop View Post
I set the skill at 1/4 ..Then run down the center . The ply will pull out somewhat easy. The bitch Is getting the the new ply In. I Just lightly pry on the flanges with a drywall hatchet [ The blade] It takes a few choice words to get the new ply in but It will slide in and fit tight !!
I think the last time I used a scrap 2x to bang the ply in .
It's not that hard to replace them ! Thanks for the thread ...Maybe I'll get off my ass and get my chit up to OSHA!!!
blacktop is offline
Old 10-20-2014, 05:37 PM   #4
Drywall Slave
blacktop's Avatar
Rewards Points: 272
You are speaking of this type of walk boards ?
blacktop is offline
Old 10-20-2014, 05:39 PM   #5
Brickie's Avatar
Rewards Points: 570
I have the 7 footers (5307-19) & have about 8 of them to repair.
Brickie is offline
Old 10-20-2014, 05:42 PM   #6
Brickie's Avatar
Rewards Points: 570
Yes, like the one on the right in your photo where the plywood is riveted to the plank.
Brickie is offline
Old 10-20-2014, 05:56 PM   #7
Drywall Slave
blacktop's Avatar
Rewards Points: 272
Pop the rivets ! Replace them with bolts & nuts That's worked for me.
Like this Bro ! A shorter bolt would be wise .
blacktop is offline
Old 10-20-2014, 06:03 PM   #8
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I drill the rivets out
jlsconstruction is offline
Old 10-20-2014, 07:49 PM   #9
AustinDB's Avatar
Rewards Points: 1,268
instead of carriage bolts, you might consider the bolts they use on roll up doors (on box vans). Sorry, I forget the name of that type of bolt, flat head and about 1 1/4" in diameter
AustinDB is offline
Old 10-20-2014, 07:53 PM   #10
AustinDB's Avatar
elevator bolt
http://store.stepvanparts.com/D-ELEVATOR-BOLT-20001.HTM
AustinDB is offline
Old 10-20-2014, 09:03 PM   #11
Brickie's Avatar
Rewards Points: 570
those look nice!
Brickie is offline
Quick Plank Replacement Tip PrecisionFloors Flooring 5 05-23-2013 07:20 PM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
Strange smell from old plank subfloors bob_cntrctr Flooring 9 09-09-2012 06:49 PM
Cost to install Hardie plank siding Dbca Construction 1 01-11-2012 04:01 PM
Hardie Plank finish flaking off? arpy911 Windows, Siding and Doors 4 12-08-2010 10:43 PM
