Recommend A Vacuum For Concrete Dust Removal? - Tools & Equipment - Contractor Talk
Old 02-05-2012, 06:16 PM   #1
Project_Pat's Avatar
Trade: Drywall jockie
Rewards Points: 75
Question
Im grinding a slab on grade that has many bumps in it and im using a Hilti DG150 grinder hooked up to a ridgid shop vac and the vacuum cant keep up with the dust removal and shoots the dust out the vacuums exhaust..Im using the dust filter with a bag and still having this problem.
Ive decided it would make things a lot easier to just get another vacuum the question is which one...can anyone recommend a good vacuum for this job?
Project_Pat is offline
Old 02-05-2012, 06:55 PM   #2
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Recommend A Vacuum For Concrete Dust Removal?
Did you rent the grinder? If you did go back and rent the hilti vac that works with it. Are you using the vac you have with a bag and good quality heap rated filter?
www.bcconstructionllc.com
BCConstruction is offline
Old 02-05-2012, 07:13 PM   #3
jlyons's Avatar
Trade: capenter
Rewards Points: 219
Ruwac. that is what we have used for the grinding for densifying concrete and they are amazing.
jlyons is offline
Old 02-06-2012, 03:00 AM   #4
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
buy a DustDeputy first. seriously It will pull 99% of concrete dust by weight before it ever gets to your VAC then buy the Drywall bag and a new filter for your rigid. I Guarantee it will outperform ANY VAC under $650, not using a separator, in time before servicing due to loss of suction and price for bags.
+ YouTube Video
Note I am running a NILFISK with a selfcleaner in the vid but I really dont need it with the Dust Deputy
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Old 02-06-2012, 11:53 AM   #5
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
I went from a ridgid to a fein turbo II when I had to grind thinset off of a concrete floor. the ridgid just couldn't suck the dust up fast enough and it was going everywhere and the hose would clog.
I originally didn't want to use my fein for concrete dust but with a fine filter bag it was fine.
the fein sucked it all up no problem, didn't need my dust mask anymore.
just change the bag before it fills and explodes.
Winchester is offline
Old 02-06-2012, 12:26 PM   #6
Aureli Construction
aureliconstruct's Avatar
Rewards Points: 75
If you can, use water on the area you are grinding/drilling. Very little dust if done correctly. You can use a dry vac later to clean it up.
www.aureliconstruction.com
aureliconstruct is offline
Old 05-16-2013, 03:36 AM   #7
Shockrock's Avatar
Trade: Floor Prep
go for a Starmix ISPARD1435 Vac, i have proven it time and time to be reliable for sucking the dust -
Shockrock is offline
Old 05-16-2013, 06:24 AM   #8
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
I second the hilti vac idea. We used it to cut concrete inside an office with the hilti saw, no dust at all.
jkfox624 is offline
Old 05-16-2013, 07:31 AM   #9
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 783
I second the dust deputy. I used a cup grinder with a dust collection shroud on a Makita grinder to grind about 400 sq. ft. of concrete with a ridged shop vac and a dust deputy.
the air was dust free and I filled up a five gallon bucket about a third of the way with concrete dust and had almost none in the filter.
it helps to have someone move it around for you while you are grinding. but not necessary
nicko
"Quality work for those who know the difference"
nickko is offline
Old 05-18-2013, 10:25 AM   #10
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Ive used my festool 36 AC dust extractor that i use for drywall sanding with excellent results..
As others said they make a hilti extractor which will also work fine.
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 05-18-2013, 02:53 PM   #11
Trade: Construction
i used mine yesterday to grind about 250sqft of concrete. worked great. i def need that blast gate though.
Old 05-18-2013, 07:20 PM   #12
Repair & Renovation
Rich D.'s Avatar
I probably could of saved myself the 55 bucks and done without the blast gate.
I only use it to the clean the filter and using your palm as a blast gate works just as good! I also keep the hose on all the time so i dont have to worry dust escaping in transport.
Rich D. is offline
Old 05-19-2013, 06:58 AM   #13
Trade: Construction
I get sick of pulling that hose out once the bag gets close to full. I must have had close to 100lbs of thinset dust in there the other day. Didn't realize until I tried to pick it up and it felt like it was stuck to the ground lol. Really needed the blast gate then.
Old 05-19-2013, 07:34 AM   #14
duburban's Avatar
Trade: building
Rewards Points: 1,750
i'm glad to hear your 36ac is working well for concrete dust. i dry sand/polish my designer concrete projects and need a good vac for it.
duburban is offline
Old 05-19-2013, 07:46 AM   #15
Trade: Construction
If you got it i think you would be well impressed with it. The customer couldn't believe i ground that floor and didn't leave a spec of dust outside that area. The makita dust shroud helps a lot as well though.
Old 05-19-2013, 08:13 PM   #16
Repair & Renovation
Rich D.'s Avatar
What do you mean?
So true. My vac gets so heavy i only roll it around and over stuff.
How is the makita dust shroud?
I was looking at hiltis surface grinding set up but its to much $ i think for really just a shroud.
Bosch also makes a surface grinder for about 500$. But again thats too much money for a tool ill use maybe 2-3 times a year.
Rich D. is offline
Old 05-19-2013, 08:20 PM   #17
Trade: Construction
What do you mean?
When the vac gets full the filter seems to pick up the dust from the top of the pile and fill the filter up really quick. If I AC and put my hand over the inlet then it clears it for a about 30-40 seconds then it's lost about 70% of it's suction. If I only let it get about half full I dont need to AC it too many times each time I use it.
The makita dust shroud works very well. Almost zero dust comes from it.
Old 05-20-2013, 09:21 AM   #18
Repair & Renovation
Rich D.'s Avatar
That just happend to me. I was 75% full and lost suction real bad. I figured you could full the bag almost to the top but i guess not...
Im guessing the makita shroud only works with a makita grinder...
Rich D. is offline
Old 05-20-2013, 09:31 AM   #19
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
We own the Blastrac BDC 1216, it's designed for concrete grinding and is favorable on drywall dust as well without ruining the motor. Comes with 2 motors and when grinding large floors does not leave that haze of dust floating thru the air
Chris
Chris Johnson is offline
Old 05-20-2013, 11:37 AM   #20
Trade: Construction
It should fit any grinder that size. It clips in the same way as the blade guards. Not sure if they are different sizes.
Insulation Removal Taylor8 Insulation 13 01-22-2016 12:01 PM
nationwide overspray removal service JLN Overspray New Member Introductions 0 04-18-2011 03:41 PM
nationwide overspray removal service JLN Overspray New Member Introductions 0 04-18-2011 03:39 PM
HDPE Pipe vacuum problems turfguy13 Excavation & Site Work 9 01-26-2011 12:46 PM
dealing w/ city/state re: removal of trees AustinDB Landscaping 4 03-22-2009 09:54 PM
