Recommend Small Wire Feed Welder... - Tools & Equipment - Contractor Talk
Old 01-09-2019, 09:04 PM   #1
Fire up the BBQ
griz's Avatar
Rewards Points: 1,838
110v, wire feed.
have always wanted one.
just for odds and ends personal stuff, recreation...
1/4" steel max to weld
welding never been in my wheelhouse, always been around pro fabricators when i needed anything welded.
griz is online now
Old 01-09-2019, 09:54 PM   #2
rrk's Avatar
Rewards Points: 4,854
Re: Recommend Small Wire Feed Welder...
I have a Clarke not sure of model # but it has fit my needs very well
get an automatic helmet also
rrk is online now
griz (01-09-2019)
Old 01-09-2019, 10:13 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,530
The small 110 Lincoln ones are good ,I have an old 135 works pretty good shielded or gas. The little ones are ok , but IMO don't weld like the bigger 220 units. The auto helmet is a must.
Randy Bush is offline
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
griz (01-09-2019), hdavis (01-09-2019)
Old 01-09-2019, 10:15 PM   #4
tgeb's Avatar
Rewards Points: 848
I'm not a welder either. Anything of any consequence, truck hitches, trailer repairs, I have a welder friend of mine that can fix everything but the "break of day."
I bought this little wire feed for a project I had to do last Summer, weld some pipe attachments to steel plate and install by welding rebar stakes to the back of the plate for a landscape border.
It is a wire feed but you must use the flux core wire, it can not be used with gas. Some that are similar can use both flux core and gas shielded.
This welder worked fine for what I was doing, it leaves a bit more splatter than I would like and probably more than a gas shield setup. I ran probably 4 or 5 2 pound spools through it and had no issues.
Could run it off a small generator, is light enough to move around easily.
For the money, (about $200), and my use it worked just fine, I have a better machine in the shop, but it's a 240 volt buzz box and not so portable.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For a little more money you can get one with gas if you need that.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
griz (01-09-2019)
Old 01-09-2019, 10:25 PM   #5
Fire up the BBQ
griz's Avatar
i can see this is not as easy or cheap as i thought it might be...
does wire need to be stored like rod?
griz is online now
Old 01-09-2019, 10:33 PM   #6
tgeb's Avatar
Rewards Points: 848
I don't think the wire needs to be stored specially, you can feed a few inches out and cut it off I suppose if it gets funky from being around damp conditions. I wouldn't think it will spoil the whole spool.
If you were around here, you could take mine and try it out.
www.gebcon.com
tgeb is online now
griz (01-09-2019)
Old 01-09-2019, 10:48 PM   #7
rrk's Avatar
Mine has the gas option but I have never used it.
Also get extra tips and nozzles
rrk is online now
griz (01-09-2019)
Old 01-10-2019, 12:00 AM   #8
hdavis's Avatar
Rewards Points: 1,118
Even MIG welding isn't cheap. I think my argon bottle and regulator ran $175. Forget what the Lincoln Electric 140 ran. Then there are the helmet, gloves, clamps, etc, etc.
Don't forget the cart.
Don't expect to do much better than 3/16" on a 140.
Set aside $1000, and you'll have money left over. Set aside $500, and you'll probably be short.
If you just want to weld something, grab a couple of truck batteries and jumper cables. You still need everything else, but you can mess around with stick welding in a small way at 24V DC.
hdavis is online now
griz (01-10-2019)
Old 01-10-2019, 12:03 AM   #9
hdavis's Avatar
Aluminum welding uses straight argon, steel welding usually uses argon with 10% CO2 to reduce spatter.
Old 01-10-2019, 12:25 AM   #10
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,740
If you want to mig aluminum straight argon is needed and a spool gun attached to a mig welder is the way to go
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
hdavis (01-10-2019)
Old 01-10-2019, 07:05 AM   #11
Donohue Const's Avatar
Rewards Points: 1,722
if you have a 240 volts where you will be welding get a 240 volt welder even if you dont really need one that size
might cost a few hundred more dollars, but they weld much better
I have both sizes, a Lincoln 140(120v), and a Lincoln 180(240v)
no matter what I want to weld I would choose the 180 everytime if I have 240v available to plug into
both are gas welders
gas makes a much nicer looking weld, only need flux core wire if you will be welding outdoors
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is offline
Old 01-10-2019, 09:04 AM   #12
rustyjames's Avatar
Rewards Points: 1,816
110v, wire feed.
You're going to have to step up to a 220 volt machine if you want to weld 1/4" material. Miller is pretty much top dog as far as machines, but Lincoln and Hobart are also good choices.
rustyjames is offline
Old 01-10-2019, 10:14 AM   #13
Randy Bush's Avatar
I have a Honda 7000 gen and I have to run my Lincoln 135 on the 30 amp plug to not trip the breaker and even then I don't get the weld I would with a land line. Startup amps is a killer on welders.
The Following User Says Thank You to Randy Bush For This Useful Post:
hdavis (01-10-2019)
Old 01-10-2019, 10:32 AM   #14
hdavis's Avatar
Seperate 30A breaker in the garage for the welder as well. GFIs required by code for garage outlets, but this is an exception.
Edit - I'll double check the breaker today if I remember, but I'm pretty sure my electrician said 30A.
Old 01-10-2019, 10:47 AM   #15
Randy Bush's Avatar
Mine will run just fine on a 20amp landline.
hdavis (01-10-2019)
Old 01-10-2019, 10:58 AM   #16
hdavis's Avatar
My electrician would overkill something like this. No real added cost.
Randy Bush (01-10-2019)
Old 01-10-2019, 11:13 AM   #17
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,576
Have you thought about going with a stick welder instead of wire feed?
Little easier to use, and a little cheaper.
griz (01-10-2019)
Old 01-10-2019, 03:13 PM   #18
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,381
Harbor Freight.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
sunkist (01-16-2019), tang (01-22-2019)
Old 01-10-2019, 05:04 PM   #19
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,824
I grew up using millermatic 250s and bigger. The Hobart welders have really impressed me for what they cost.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 01-10-2019, 05:10 PM   #20
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 2,036
I have a Lincoln, it has a better duty cycle than a lot of the cheaper ones, but it's still less than 33%. I prefer plain wire wire with C35 shielding gas as opposed to flux core, it makes cleaner looking welds.
I still use my 240 volt machine for almost everything though, it has a 100% duty cycle.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Can You Recommend a Welder for Sheet Metal repair ? plazaman Welding & Steel Trades 24 12-21-2015 09:01 PM
Small voltage in green wire VAviaCo Electrical 8 07-06-2012 08:33 PM
3-way switch with 14/2 wire wadswob Electrical 2 09-23-2008 07:33 AM
Small Mig or Tig welder BlenderWizard Tools & Equipment 17 05-17-2007 09:42 PM
safe hot wire driver Electrical 13 05-12-2006 10:18 PM
