Question Should I Get A Corded Or Cordless Hammer Drill - Tools & Equipment - Contractor Talk
Old 10-22-2018, 05:18 PM   #1
tonyc56's Avatar
Trade: Window Treatments
Rewards Points: 3,534
As a rule I don't do any work that involves drilling into concrete. However for this particular job I have no choice. I'll be drilling into an old building that has reinforced concrete to attach window roller shades. What type of SDS hammer drill would you recomend that is both powerful and lightweight.
tonyc56 is offline
Old 10-22-2018, 05:37 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,890
Re: Question Should I Get A Corded Or Cordless Hammer Drill
I have 4 corded and 4 cordless. The one that gets by far the most use is the DeWalt 20V L-Shape drill. That damn thing just won't quit, good for small tapcons right up to 5/8" anchors.
I'd get a small SDS on whatever battery platform you currently have.
Inner10 is offline
The Following 3 Users Say Thank You to Inner10 For This Useful Post:
cedarboarder (11-13-2018), overanalyze (10-22-2018), tonyc56 (10-22-2018)
Old 10-22-2018, 05:59 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,253
IMO, there's little point in going with battery if it's a tool you'll only use once in a blue moon--unless you have other regularly-used tools that take that same battery.
Corded tools have an indefinite shelf life.
Tinstaafl is online now
The Following 9 Users Say Thank You to Tinstaafl For This Useful Post:
BlueRidgeGreen (10-23-2018), griz (10-22-2018), MarkJames (10-23-2018), META (10-27-2018), sunkist (10-23-2018), tgeb (10-23-2018), TheConstruct (10-22-2018), tonyc56 (10-22-2018), Xtrememtnbiker (10-23-2018)
Old 10-22-2018, 08:19 PM   #4
Inner10's Avatar
Guy installs blinds for a living...You wanna do that with a cord even in a blue moon?
Inner10 is offline
Old 10-22-2018, 08:27 PM   #5
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 294
Makes more sense for a rare use item.
Xtrememtnbiker is online now
Old 10-22-2018, 08:50 PM   #6
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,188
Usually an outlet near windows. Or do you do exterior work?
Golden view is offline
Old 10-22-2018, 08:52 PM   #7
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
What size holes do you plan to drill?
Window roller shades should not require a big hole if they are regular sized windows. I would just use my 1/2" cordless hammer drill.
Peter_C is offline
Old 10-22-2018, 09:12 PM   #8
Capra aegagrus
Tinstaafl's Avatar
I don't want to do it either way.
But yeah, for blue moon work I'd still go with a cord. That's a lot more likely to still work a year or two later when the next moon rolls around.
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
BlueRidgeGreen (10-23-2018), Tom M (10-23-2018)
Old 10-22-2018, 11:12 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 1,834
i had 80 some roller shades to install into masonry walls.
guys used battery hammer drills....
like max 1/4" holes, many 1/8"....
done in a day....
don't over think it....
griz is online now
Old 10-23-2018, 12:26 AM   #10
GC/carpenter
Calidecks's Avatar
Rewards Points: 16,526
Love my cordless rotohammer. I use the **** out of the 7/8" Milwaukee Fuel. Battery life is amazing considering the workload I do with it.
Mike.
_______________
Calidecks is online now
Old 10-23-2018, 02:30 AM   #11
VinylHanger's Avatar
Rewards Points: 9,920
Yep. Just a 20v hammer drill. Or you could probably get away with a 12v. Like griz said, don't over think it. Besides, a hammerdrill s small and lightweight when drilling above your head.
VinylHanger is online now
Old 10-23-2018, 07:13 AM   #12
edward trowelhands
Trade: Diplomat
Even with 3/16" holes, depending on concrete, a small roto hammer might be 4x faster, and you barely have to push. I feel like a hammer drill requires pushing.
Old 10-23-2018, 07:19 AM   #13
Inner10's Avatar
Using anything but an SDS is idiotic.
Inner10 is offline
The Following 4 Users Say Thank You to Inner10 For This Useful Post:
Calidecks (10-23-2018), tgeb (10-23-2018), Tom M (10-23-2018), TRThomas (10-27-2018)
Old 10-23-2018, 09:09 AM   #14
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,886
[QUOTE=Inner10;7393101]Using anything but an SDS is idiotic.
why ? why would an sds be that better with 3/16 bit then just a chucked tool .
JFM constr is online now
Old 10-23-2018, 09:16 AM   #15
r a s's Avatar
Trade: division twelve
Rewards Points: 1,170
We use this https://amzn.to/2CZ5yXp to install manual and motorized window coverings. Buy some extra SDS drill bits and the job will be a lot easier than you're anticipating.
If you don't use Makita I'm sure Milwaukee or your chosen battery platform has something similar.
Even if you're not using fascia take fascia brackets. The extra two holes for mounting may prove useful in some of the walls. eg. hitting rebar
Tangentially, it may be less expensive, and stressful, to sub out the installation. There are professional installers in your area that won't compete with you on the sales end.
Good luck!
r a s is offline
Old 10-23-2018, 09:32 AM   #16
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,135
window roller shades..inside work...how many?
Sounds like a hammer drill (one handed operation) is worth trying first, then corded SDS (two-handed) if you really need it.
Side note: I have the Milwaukee M18 hammer drill, which I think is lame in hammer mode compared to the Dewalt 18V my electrician uses. Can anybody confirm this, or is it just my imagination?
MarkJames is online now
Old 10-23-2018, 10:52 AM   #17
GC/carpenter
Calidecks's Avatar
Hammer drills suck.
Mike.
_______________
The Following 8 Users Say Thank You to Calidecks For This Useful Post:
avenge (10-23-2018), BlueRidgeGreen (10-23-2018), Mordekyle (10-23-2018), mrcat (10-23-2018), tgeb (10-23-2018), TheConstruct (10-23-2018), TRThomas (10-27-2018), Xtrememtnbiker (10-23-2018)
Old 10-23-2018, 02:45 PM   #18
Inner10's Avatar
[quote=JFM constr;7393163]
Try it and find out.
Inner10 is offline
mrcat (10-23-2018)
Old 10-23-2018, 06:24 PM   #19
Box Builder
Morning Wood's Avatar
Rewards Points: 9,686
Cordless for holes that small. Id imagine youre drilling 5/32 or 3/16 holes. I agree going with an SDS drill. I used a 1/2 hammer drill for years. Then got a SDS max drill for larger stuff. Than most recently bought a small SDS plus drill. Its all I use for tapcons now. Dont even know where my 1/2 hammer drill is.
Morning Wood is offline
Old 10-23-2018, 07:31 PM   #20
tonyc56's Avatar
Cordless for holes that small. I’d imagine you’re drilling 5/32 or 3/16” holes. I agree going with an SDS drill. I used a 1/2” hammer drill for years. Then got a SDS max drill for larger stuff. Than most recently bought a small SDS plus drill. It’s all I use for tapcons now. Don’t even know where my 1/2” hammer drill is
What brand and model small SDS plus drill did you purchase.
tonyc56 is offline
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Cordless drill aggravation Ryzach Tools & Equipment 20 04-16-2013 09:37 PM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Bosch Drill 99 dollars JonM Tools & Equipment 21 02-21-2013 01:19 PM
3/8" corded drill mnjconstruction Carpentry 22 05-15-2010 11:16 AM
