Precut Foam For Cases - Tools & Equipment - Contractor Talk
Old 12-06-2018, 07:28 PM   #1
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 1,210
Any one else using foam for the tool cases. Just finished my first tool box all my drywall power tools with some extra storage in the tray. Was frustrating trying to keep some space between them. Hopefully the next ones turn out better
Next boxs to be done will be my wood working tools. 1 box for the joiner and planner. and another for the the nailers. this foam is cheap considering the cost of the tools. Precut foam for cases-20181206_162122.jpeg
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 12-06-2018, 11:48 PM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Re: Precut Foam For Cases
Now what kind of tools are you going to throw on top of them to take up the extra space?
My drywall screw gun is currently at the bottom of a large Packout below, an impact, drill, multi-tool, saw, a few batteries, light, and probably a few other tools I can't remember at the moment. If I only put three tools into a large box, I would have had to buy Home Depot completely out of Packout's over Black Friday and I did a pretty good job of it to begin with. Just repackaged my tiling tools into a rather large stack of Packout's, which I am happy with.
The one place I can see using the Kaisen foam is for my Bosch lasers that I just moved into a Packout. I protect them because I need them accurate. Had a laser go out of whack and it screwed my tile job
Peter_C is offline
Old 12-07-2018, 12:22 AM   #3
Trade: Workaholic
Probably some dust attachments and more batteries.
I'm going to get the larger box for the next one, use thicker foam so I can stand up the tools that are awkward like the joiner and the monster cordless brad nailer, dewalt really f'ed up on not making a medium size box. they got small large and xl.
The laser could use some foam. I remember last year putting in dedicated box but didn't like how it was able to move around. it rides up front with me now.
Old 12-10-2018, 09:46 AM   #4
Designed2Fail's Avatar
Trade: residential construction
Rewards Points: 306
Only for my cordless batteries. I got foam in the top and bottom of the small Ridged case in their rolling cart system. One case has 10 the other 7 and two chargers. Seeing as the batteries cost almost as much as the tool in the HILTI line up figured was worth it.
Designed2Fail is offline
The Following User Says Thank You to Designed2Fail For This Useful Post:
cedarboarder (12-10-2018)
Old 12-12-2018, 12:40 AM   #5
Peter_C's Avatar
Rewards Points: 412
Took a picture the other day for this thread as my "M12" box was sitting open with many tools out of the box in use. I fill it to max capacity
Peter_C is offline
Old 12-12-2018, 02:54 AM   #6
Trade: Workaholic
how deep is this mess of tools?
Old 12-13-2018, 12:46 AM   #7
Peter_C's Avatar
Rewards Points: 412
The same depth as the rest of the mid sized Ridgid boxes, and what Milwaukee calls their "large" Packout box. I pack them pretty tight too, often trying to figure out how to fit everything back in.
Oh look I protected my thinset mixing tool with parts of the tile leveling tools. I even had to cut a couple inches off the mixing tool to safely store it in a Packout. The green parts are kinda like foam right?
Peter_C is offline
Old 12-13-2018, 01:05 AM   #8
Trade: Workaholic
Those tile levelers are like peanut foam...
Also cut off some off the mixing tool. But cut off the wrong end... and now a stubby.. I have to put the whole drill and my hand in the bucket...
Old 12-13-2018, 09:30 PM   #9
Mike-B's Avatar
Rewards Points: 850
That is my M.O. as well.
M18 drill, impact driver, omt, hackzall, light, grinder, charger, 3 batteries, m12 right angle drill, 2 batteries, drill index, bit case, sawzall blades, grinder wheels and omt blades all in a rigid medium box.
Mike-B is offline
Old 12-13-2018, 10:30 PM   #10
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,797
What is this extra space you speak of?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-13-2018, 10:48 PM   #11
CPMKW's Avatar
Trade: GC PM
Rewards Points: 292
Ridgid rolling case - DeWalt cordless
7.25 circle saw
Jigsaw
18 gauge nailer
Sds hammer drill
Impact driver
Hammer drill driver
Charger
4 batteries
Drill/bit cases
Sent from my SM-G930W8 using Tapatalk
CPMKW is online now
Old 12-13-2018, 11:05 PM   #12
LRG WoodCrafting
Leo G's Avatar
No room for foam.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-14-2018, 08:53 AM   #13
Donohue Const's Avatar
Rewards Points: 1,376
Originally Posted by Leo G View Post
No room for foam.
I have not seen that many corded tools in a while
Sent from my SM-G965U using Tapatalk
Ryan
www.ryandonohueconstruction.com
Donohue Const is online now
Old 12-14-2018, 03:25 PM   #14
LRG WoodCrafting
Leo G's Avatar
The jigsaw will be the next to go cordless.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-14-2018, 03:40 PM   #15
Trade: Workaholic
barrel handle or d handle?
not sure why I don't like d handle...
Old 12-14-2018, 06:25 PM   #16
LRG WoodCrafting
Leo G's Avatar
Always had a barrel. Either the Makita or the Milwaukee.
I have both battery platforms in 18v
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-14-2018, 06:26 PM   #17
LRG WoodCrafting
Leo G's Avatar
There's only three. Jigsaw, Multimaster and Belt Sander. The charger doesn't count.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Donohue Const (12-14-2018)
Old 12-14-2018, 08:03 PM   #18
Talking Head
EthanB's Avatar
Rewards Points: 254
A lot of guys use this stuff.
Planer.....
EthanB is offline
Old 12-14-2018, 09:05 PM   #19
Trade: Workaholic
I guess its the perk of specializing I don't need half that stuff you guys have in the tool box haha.
Main reason for the foam was to protect them during transport in the trailer. The roads are fubar here. This box adds up to over a grand Canadian when full. Impact, roto, drywall cutter, screw gun, laser, 4 batts
Old 12-17-2018, 04:35 PM   #20
madmax718's Avatar
Trade: General
Rewards Points: 3,272
There's only three. Jigsaw, Multimaster and Belt Sander. The charger doesn't count. <img src="http://img.contractortalk.com/smilies/whistling2.gif" border="0" alt="" title="Whistling2" class="inlineimg" />
I've been bringing along more corded stuff when needed since getting the powerstation. And I think the only ones I do bring are the SDS, grinders, and a planer.
madmax718 is offline
Spray Foam not adhering to concrete basement wall... Paint & Hammer General Discussion 6 11-04-2012 01:39 PM
progressive foam vs foam clad siding contractorjay Windows, Siding and Doors 15 10-25-2012 08:03 AM
foam insulation question phnola Construction 3 05-01-2011 09:56 AM
the great debate, foam rain screen woodworkbykirk Windows, Siding and Doors 8 09-13-2010 07:54 PM
Spray foam under a slab for insulation -- Mike Finley Construction 22 01-10-2010 02:39 PM
