Portable Work Bench - Page 3 - Tools & Equipment - Contractor Talk
Portable Work Bench
Old 01-03-2015, 08:12 AM   #41
gillisonconstru's Avatar
Trade: General Contractor/ Carpentry
Rewards Points: 344
Re: Portable Work Bench
I used 3/4 Birch Plywood for mine I am sure you could easily add plates, tracks, ect were you would want. Mine is a simpler version of the Paulk bench this thing is a game changer, crazy handy and on the big jobs, were we are staying set-up, helps with organization.
gillisonconstru is offline
The Following User Says Thank You to gillisonconstru For This Useful Post:
Motor (01-04-2015)
Old 01-11-2015, 02:52 PM   #42
T-Hussy's Avatar
Rewards Points: 134
I'm a quarter way finished with the pulk total station. The router insert sold me. I'll post a few pics.
T-Hussy is offline
The Following User Says Thank You to T-Hussy For This Useful Post:
Motor (01-27-2015)
Old 01-11-2015, 09:06 PM   #43
Jswills76's Avatar
Trade: custom carpentry
Rewards Points: 836
Vika 2-in-1 Workbench and Scaffold - Model# 21010 https://www.amazon.com/dp/B001O3FUC0..._xVYSub0PZ4RDK
I use one of these
Jswills76 is offline
The Following 2 Users Say Thank You to Jswills76 For This Useful Post:
Motor (01-27-2015), overanalyze (01-11-2015)
Old 01-11-2015, 09:10 PM   #44
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 12
We also use the Keter folding work surfaces. They are really sturdy and light. We keep one in the van and have another we use as a miter saw stand. $50-$60 at Sams, Costco, and online.
overanalyze is offline
Old 01-11-2015, 09:28 PM   #45
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Is that one the adjustable leg one?
I have one but it does not have the adjustable legs. I wish it did. I am 6' tall and wish it was just a touch taller for me to be a bit more comfortable working at it. Otherwise, I love it. I think it holds more weight than the adjustable leg one but not by much IIRC.
CrpntrFrk is offline
Old 01-11-2015, 09:42 PM   #46
Always Learning
Rewards Points: 12
Yes both of ours have the adjustable legs. We almost always use them on the highest setting. We had it onsite with a ton of heavy porcelain tiles stacked on it last week and it was solid.
The Following 2 Users Say Thank You to overanalyze For This Useful Post:
CrpntrFrk (01-11-2015), Motor (01-27-2015)
Old 01-11-2015, 10:50 PM   #47
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
Costco has the same bench under the Durabench name for $99 shipped. I have both a Vika and a Durabench, and other than the color, they are identical. I really like them, but think they are a bit heavy. I also have a MFT. I like them both. With the MFT you can clamp a door along the front or back.
Rustbucket is offline
The Following User Says Thank You to Rustbucket For This Useful Post:
Motor (01-27-2015)
Old 12-02-2016, 11:20 AM   #48
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
I recently joined the Ron Paulk workbench crowd. It is a little much to drag out and set up, but once it is set up I totally love it. The electrical EMT that supports the table saw holds my Bosch GTS, and I don't find it to be adequate. I do need to put a support leg under the front of the table saw, or possibly replace the EMT with rigid pipe.
I initially wanted to build the workbench at 7 feet of length, as opposed to the full 8 foot. However I went ahead and made it a full 4x8 workbench as designed. What I do like about the two-piece design of the Paulk workbench, is that I can drag out just one piece and have a 2 by 8 foot work surface that is extremely handy!
Aaron Berk is offline
Old 12-04-2016, 02:34 PM   #49
Can I get an Amen?
Aaron Berk's Avatar
Still a few holes to drill. The legs are work stands that I built yrs ago, I made an adapter to mount the Paulk Bench, but I'm not sure it will stay this way. To much to haul arround.
The one good thing about my work stands, is that they mount 1 section of the Paulk Bench really well. And using one 2x8 section is very practical.
The Following 2 Users Say Thank You to Aaron Berk For This Useful Post:
Calidecks (12-04-2016), overanalyze (12-05-2016)
Old 12-04-2016, 02:55 PM   #50
Tom M's Avatar
Rewards Points: 114
I love it Aaron. Nice job on the set up. I could see what you mean by lugging around but must be a pleasure to have when working.
Tom M is online now
Old 12-05-2016, 08:57 AM   #51
Part-Time Wannabe
atypicaltexan's Avatar
Trade: Part-Time Carpentry, AV/Low Voltage Install
Rewards Points: 96
I never tried to use EMT, I used 3/4" rigid for mine from the get-go, and it works very well hanging my DeWalt 7490 (the big DeWalt portable saw) from my Paulk Bench. I used an online pipe deflection calculator and the published numbers for 1" EMT and 3/4" rigid, and that sold me. 3/4" rigid theoretically deflects 25% less than 1" EMT using the numbers I "guestimated." 3/4" rigid is also available at my Lowe's, so I didn't have to go to an electrical supply store.
The only 2 issues with using the 3/4" rigid was 1) I had to drill 1 1/16" holes, and finding a bit to do that was difficult; forstners are available, but expensive, so I used a router guide bushing, template and plunge bit combination that gave me a 1 1/16" hole. 2) the pipe is a tight fit in the hole, so I had to use a file to remove the globs of excess zinc on the outside of the pipe to prevent it from snagging when it slides in and out.
The best part is that I bought 2 pieces of 10' rigid and only used 6' of each, so I combined the remaining 4' pieces with a rigid 90 and voila, free vacuum boom arm
https://drive.google.com/open?id=0B0...nc1Tkp3cVRiM00
atypicaltexan is offline
Old 12-05-2016, 10:13 AM   #52
hdavis's Avatar
Rewards Points: 74
Link?
hdavis is online now
Old 12-05-2016, 11:11 AM   #53
Part-Time Wannabe
Rewards Points: 96
Bottom calculator on this page:
http://www.engineering.com/calculators/beams.htm
Conduit specs from anywhere, but I think I used this one:
http://www.falsonsupply.com/catalog/123fs.pdf
The calculator is not for a cantilever beam, but you can tell when you plug in the numbers and check the deflection for equal loads and beam lengths that the 3/4" rigid is more rigid than the 1" EMT (no pun intended ).
The Following User Says Thank You to atypicaltexan For This Useful Post:
hdavis (12-05-2016)
Old 12-05-2016, 06:45 PM   #54
JAH's Avatar
Trade: carpenter
Rewards Points: 1,910
This is my portable bench. Its light, easy to move and you can tear it down or set it up in under 2 min.
Its not as pretty as some of the benches in this thread but suits my needs perfectly.
Portable work bench-13087643_10201900226505040_6248214195304190449_n.jpg   Portable work bench-13096273_10201900226985052_3286532832963166347_n.jpg   Portable work bench-13151555_10201900227225058_1849119944311604077_n.jpg
JAH is offline
The Following 5 Users Say Thank You to JAH For This Useful Post:
CharlieDelta (12-06-2016), hdavis (12-05-2016), Motor (12-05-2016), overanalyze (12-05-2016), Philament (12-06-2016)
Old 12-05-2016, 06:46 PM   #55
JAH's Avatar
Trade: carpenter
Last one.
JAH is offline
The Following 3 Users Say Thank You to JAH For This Useful Post:
Lettusbee (12-05-2016), Motor (12-05-2016), Philament (12-06-2016)
Old 12-05-2016, 07:34 PM   #56
Motor's Avatar
Rewards Points: 60
Great idea. Mine is a 4x8 sheet of 1-inch MDF with a few holes drilled in it on saw horses. Weighs a ton. So I may do something up like yours. Thx!
Motor is offline
Old 12-05-2016, 08:15 PM   #57
JAH's Avatar
Trade: carpenter
I made mine from 2 sheets of 5/8 AC.
The table top is 40"x7'. Just big enough to work on a pre hung 3'x6'8" door. Because the top folds its easy to store. No problem to carry through a furnished house. I cut the holes for the handle wider than normal so if you have on bulky winter gloves its easily graspable.
I need to replace the right angle brackets for mounting the table. They need to be longer. Right now its a knuckle buster.
The 2 main beams in the frame are doubled 5/8 ply. With single ply cross members, half laps.
This bench has changed my life....
JAH is offline
The Following User Says Thank You to JAH For This Useful Post:
Motor (12-05-2016)
Old 12-06-2016, 09:17 PM   #58
smpcarpentry's Avatar
Trade: general contractor
Rewards Points: 254
So for an ideal size portable bench what size would you guys say or use. Im thinking im going to build a paulk bench but not sure what size would be best. Four by eight im sure is nice but a bit large for transport dayly. Mft3 is roughly two and a half by four im thinking to small. Im thinking three by five would be good. Small enough to transport easily and big enough to use for most thing what do u guys think. I can make it out of baltic birch because it is easier to get nere me rather than russian birch too.
smpcarpentry is offline
Old 12-07-2016, 01:50 AM   #59
The.Handyman's Avatar
Trade: Finish Carpentry-Remodeling-Custom Furniture
Rewards Points: 400
My take. I had both CNC'd. 1" thick Baltic Birch plywood.
3'x5'
56"x28.5" (to fit vertical in the back of the station wagon)
The.Handyman is offline
The Following 3 Users Say Thank You to The.Handyman For This Useful Post:
Motor (12-07-2016), Philament (12-07-2016), Tom M (12-07-2016)
Old 12-07-2016, 09:02 AM   #60
Can I get an Amen?
Aaron Berk's Avatar
Ron has plans for a smaller version. Like 4x6 or something. And then also sells one through fastcap
Insurance wont release depreciation on completed work!!! GContractorTX General Discussion 11 07-31-2014 03:14 AM
Kid needed decks and finish work toronto bbgcarpentry Help Wanted or Looking For Work 3 04-23-2013 09:55 PM
New Work Bench...Feedback? TNTRenovate Tools & Equipment 31 09-07-2012 06:33 PM
Any Plumbers looking for work in Boston, MA area? sadegs Help Wanted or Looking For Work 2 02-20-2009 07:45 PM
