Portable Planers.... - Tools & Equipment - Contractor Talk
Old 04-26-2017, 07:22 PM   #1
BrooklynBravest's Avatar
Trade: Carpentry - Welding/Fabrication
Rewards Points: 804
Alright, so I have wanted one of these things for years and I think I am going to pull the trigger.
The few options I am looking at are
Used Delta 22-560 for $200 in excellent condition. Looks barely used.
New Porter Cable for $220 + tax
New DeWalt DW734 $#50 + tax.
Obviously the dewalt is the best, being a 3 blade vs the others as a two blade model. I really will use this thing very rarely so I don't want to go nuts if I don't really have to though.
Is the delta a decent machine? Is that a fair price for it or should I stick with the other two or a different one altogether?
BrooklynBravest is offline
Old 04-26-2017, 07:37 PM   #2
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 270
Re: Portable Planers....
I haven't used a lunchbox planer in years. Used to have the delta & it done a decent job. No experience with the others.
pinwheel is offline
Old 04-26-2017, 08:15 PM   #3
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,256
I've had the best luck with the Dewalt 735, woodcraft periodically gives the stand for free. The stand is actually pretty nice. 734 is a nice unit and much more portable. No matter what, don't have too much of an expectation of these portables, blades seem to not last that long before you got lines.
StrongTower is offline
Old 04-26-2017, 11:11 PM   #4
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,066
I had a dewalt and loved it til it was stolen. I currently use a Delta I've had for ten years and it still works great and does a fine job. In the last year it has started making a god awful noise til that you can hear twenty miles away but stops once you put the wood in. I just use my ear muffs.
Edit: one thing I just remembered is that the blades for the Delta are not as easy to find anymore. I use to stroll into HD or Lowe's but they stopped carrying them. I haven't done research to find them online yet but I figure I'll just get another planer when I need the blades that bad. This story to be continued on the TBA thread.
illbuildit.dd is offline
Old 04-27-2017, 05:59 AM   #5
rrk's Avatar
Rewards Points: 406
I have a Cutech spiral head planer, they have several models.
Have worked great for me for 2 years now. Each tip has 2 edges so they can be rotated or replaced individually.
rrk is offline
Old 04-27-2017, 11:05 AM   #6
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,442
On what planer? And how much did it run you?
J L is offline
Old 04-27-2017, 11:12 AM   #7
AustinDB's Avatar
Rewards Points: 954
moving the dewalt 734 was brutal b/c of its weight-and that's when I was 10 years younger. Flip side is the weight helps when feeding large stock.
AustinDB is offline
Old 04-30-2017, 01:13 AM   #8
GC/carpenter
Californiadecks's Avatar
Rewards Points: 9,540
I've got an old PC126. The cutter head on mine is new. It's an great tool.
Has the spiral cutter
Edit: Sorry gentlemen. I assumed a door planer.
_____________
Californiadecks is online now
Old 04-30-2017, 09:08 AM   #9
VinylHanger's Avatar
Rewards Points: 8,726
Well, technically it is portable.
VinylHanger is online now
Old 05-01-2017, 05:09 AM   #10
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 9,144
Are you going to be moving it around a lot? None of those can really handle much. There's no real beef to a lunchbox. Unless you're planing like window or door bucks on site. If you had to move it a lot I guess it makes sense but buying a mobile base for a big Hitachi 12 or 13" makes more sense. Occasionally you can find a decent 15" powermatic for the same price as the Dewalt 4 poster. I ran a 15 for a long time before moving to a 24".
He knows nothing about everything and isn't afraid to prove it, so he defends ignorance with stupidity.
Deckhead is online now
Old 05-01-2017, 11:53 AM   #11
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 1,658
this does really depend on what your using it for .obviously the big dewalt has advantages in cutting . i have the makita lunch box[2012nb] . had two of them and for years they were my only thickness planer . blade change was easy . surface was great . i now have a large 15" with helical head in the shop that is way faster and obviously the helical head is killer .
but a lunch box is still a great tool to own . years ago when i got the makita it had the best reviews by far .cost a bit more also . have used a ridged and really liked it .have used several dewalts -did not like having the dumb snipe lock bar .Do the dewalts still have them ?
used a Delta ,built an outfeed table for it and snipe issue was gone .
lacking carbide blades they can dull fast on paint .
JFM constr is online now
Old 05-09-2017, 01:24 PM   #12
Dirtywhiteboy's Avatar
Rewards Points: 9,058
Makita makes a very good planer.
Dirtywhiteboy is online now
Old 05-09-2017, 06:05 PM   #13
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Those Porter Cable 126, the best hand planer ever made in my opinion. Can you still get the blades?? Last I seen, nope!
Dave in Pa is offline
Old 05-09-2017, 10:07 PM   #14
GC/carpenter
I was able to get a brand new one. Many years ago. I have two cutter heads. I believe they will get me to retirement, since I only use it for doors.
_____________
Old 05-09-2017, 10:17 PM   #15
JFM constr's Avatar
_____________
mine gathers dust .tracksaw does drs easier
The Following 2 Users Say Thank You to JFM constr For This Useful Post:
Californiadecks (05-09-2017), Dirtywhiteboy (05-10-2017)
Old 05-09-2017, 10:23 PM   #16
GC/carpenter
To be honest, it's been years since I've cut a door to fit an opening, most are pre-hung these days.
_____________
Old 11-16-2018, 08:59 PM   #17
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 5,438
Reviving thread. I need to pick up a planer. Dewalt 734 vs 735 vs Ridgid?
Half of all people are below average.
Golden view is online now
Old 11-16-2018, 09:14 PM   #18
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 264
Out of those 3 the 735. I have then 734 and it is ok but not great.
overanalyze is online now
Golden view (11-16-2018)
Old 11-16-2018, 09:26 PM   #19
rrk's Avatar
Rewards Points: 406
I still like my $500 Cutech which has a spiral cutter head
https://www.cutechtool.com/category-s/154.htm
rrk is offline
Old 11-16-2018, 09:44 PM   #20
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 516
I have the dewalt 735. Very rugged machine , it has handled much abuse from me and cuts nice .
Only drawback is weight, which is an advantage also .
Oh yeah , another drawback is pricey blades about $50 but , they are double edged
I bought this machine years ago when my other portable broke , in the middle of a job, and I wanted a more durable replacement . It has been very durable and handled everything Iíve thrown at it. At 100 lbs portable is a two man job , if you need to go any distance.
Idothat is online now
The Following User Says Thank You to Idothat For This Useful Post:
Portable planers WilsonRMDL Tools & Equipment 12 03-22-2011 05:45 PM
portable thickness planers trimman2 Tools & Equipment 19 05-15-2009 08:19 PM
