Plywood Saw Horses - Tools & Equipment - Contractor Talk
Plywood Saw Horses
Old 12-29-2013, 02:47 PM   #1
Localday's Avatar
Trade: General contractor
Rewards Points: 75
Plywood Saw Horses
When I was out west I saw guys who made a set of saw horses out of one sheet of 3/4" cdx, anyone have a pattern for these?
Localday is offline
Old 12-29-2013, 03:43 PM   #2
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
Re: Plywood Saw Horses
http://www.basswoodmodular.com/default.asp?m=0
Brian Peters is offline
The Following 3 Users Say Thank You to Brian Peters For This Useful Post:
basswood (12-29-2013), CanningCustom (01-02-2014), donerightwyo (12-29-2013)
Old 12-29-2013, 05:06 PM   #3
asgoodasdead's Avatar
Rewards Points: 2,214
how much weight could those really hold? we build our horses out of 2x4 or 2x6 but only make them to cut rafters on and load them up pretty heavy.
asgoodasdead is offline
Old 12-29-2013, 05:15 PM   #4
Localday's Avatar
Rewards Points: 75
The ones I saw were similar, they were three piece, not three legged. I saw guys load em up pretty good, they were a lot stronger than they looked
Localday is offline
Old 12-29-2013, 08:10 PM   #5
Artisan Carpentry
basswood's Avatar
Trade: trim carpenter
Rewards Points: 1,030
Mine are 3/4 CDX (one sheet per horse), but they are glued up, double thickness, so about the same thickness as 2x and with rails about 12" deep. Very strong. The engineer I am working with thinks we can put a truck on them, though we have not done the load testing yet.
These are the ones linked above, they can be 3 or 4-legged. I have a photo from the summer using them for notching 6x6's. The shipping ticket put these posts at 320 lbs. and I was working them with a 50 lb. beam saw and they had plenty of capacity left.
Let me know if you have any other questions.
Plywood saw horses-183138_520423211327173_1736018995_n.jpg   Plywood saw horses-1374134_581191331917027_311282265_n.jpg
basswood is offline
Old 12-29-2013, 09:38 PM   #6
Localday's Avatar
Rewards Points: 75
They were pretty muck like the four legged one you have there, but a little more crude and without the holes, thanks
Localday is offline
Old 12-29-2013, 11:04 PM   #7
muskoka guy's Avatar
Trade: framer/builder
Rewards Points: 558
We build our horses out of pieces of wood I . you can make them as long as you need them. We generally make them about five feet long. You nail approx. 9 inch 2x4 to underside and nail 32 inch legs up under top flange and to 9 inch piece. We found plywooding the ends made them extra strong. We set whole lifts of material on them with our telehandler and have not had any problems. Good advice to put blocks under legs if you are putting whole lifts on them, otherwise you may drive the legs through the subfloor.
muskoka guy is offline
Old 12-30-2013, 11:52 PM   #8
Rewards Points: 748
I saw these on a site when we were on vacation in Bend, OR this summer. Not nearly as pretty as those above
Timuhler is offline
Old 12-30-2013, 11:54 PM   #9
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Why were you vacationing on a construction site?
"I could agree with you, but then we'd both be wrong."
svronthmve is offline
Old 12-30-2013, 11:59 PM   #10
Rewards Points: 748
On a bike ride and I look over and see this frame, hit the brakes and take a look. Very cool project.
then back to the bike ride (dark by then so it was by moon light
Timuhler is offline
The Following User Says Thank You to Timuhler For This Useful Post:
svronthmve (12-31-2013)
Old 12-31-2013, 12:15 AM   #11
svronthmve's Avatar
Trade: Contractor
Rewards Points: 2
Was just busting ya! Glad you got some "down" time.
The Following User Says Thank You to svronthmve For This Useful Post:
Timuhler (12-31-2013)
Old 01-02-2014, 02:38 PM   #12
Sharkman's Avatar
Rewards Points: 25
http://www.youtube.com/watch?v=JSz-6WazgS4&sns=em
Can buy the plans or just use the video as a guide.
Sharkman is offline
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 10:51 PM
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Fat Max Horses TBFGhost Tools & Equipment 30 06-10-2012 08:05 PM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
