Paslodes - Tools & Equipment - Contractor Talk
Paslodes
Old 07-16-2015, 10:39 PM   #1
kneeman's Avatar
Trade: Construction
Rewards Points: 12
Paslodes
Just read 4 hours of forums and saw no direct comparisons to....
F350s vs PF350s
On Paslodes website the PF gets blasted and people prefer their old F.
The PF has metal cap, but plastic slide, but has dry fire lock, the PF was reviewed as more fragile but stronger, how they load, depth adjustments, etc etc etc
I just need good opinions on which to get
Not looking for Hitachi, Bostitch, etc recommendations, they are great, I want one of the Paslodes that is 30 degrees that uses paper nails.
Thanks, first post, been reading a while though.
kneeman is offline
Old 07-16-2015, 10:47 PM   #2
kiteman's Avatar
Rewards Points: 16
Re: Paslodes
I've shot like a bazillion nails through that f350s. Don't know anything about the newer one.
Welcome to CT.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 07-17-2015, 12:41 AM   #3
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
Re: Paslodes
As far as I know paslode recently quit marketing the powerframer 350 and is now only selling the F350 again. F350 is all around more durable IMO. Pf350 was an awesome gun, and I own 6 of each kind. But in the long run the F350 is more bang for your buck.
Framer87 is offline
Old 07-17-2015, 12:52 AM   #4
kneeman's Avatar
Trade: Construction
Rewards Points: 12
Re: Paslodes
I haven't seen anything about them discontinuing it, but they aren't sold at as many places.
Paslode doesn't keep their site up to date either because they don't have this 21 degree gun on there searching f350-p or f350-21 but it is at home depot as new
http://www.homedepot.com/p/Paslode-F...specifications
kneeman is offline
Old 07-17-2015, 07:24 AM   #5
mrcharles's Avatar
Trade: GC, Remodeling
Rewards Points: 1,652
Re: Paslodes
Get a F350 ... Great gun and pretty bullet proof
mrcharles is offline
Old 07-17-2015, 07:31 AM   #6
tipitop's Avatar
Trade: carpenter
Rewards Points: 3,741
Re: Paslodes
I have one Paslode framing. Worked for a few years with it. Leak always. Hitachi Koki all the way.
tipitop is offline
Old 07-17-2015, 08:29 AM   #7
mrcharles's Avatar
Re: Paslodes
The OP said he isn't interested in anything other than paslode.....I think you may have had a fluke gun...I've had paslodes for years and no problems
The Following User Says Thank You to mrcharles For This Useful Post:
Framer87 (07-17-2015)
Old 07-17-2015, 09:18 AM   #8
Spyrus's Avatar
Rewards Points: 92
Re: Paslodes
I've only used both guns while they are new. Mh impressions are that I like the pf350 more so for a couple reasons. More power, lighter, different loading action and single finger trigger. I found too often when using grip rite nails, or any of the shorter strips in the f350 they tend to want to try to fall out of the magazine. The opening is too big. The large trigger on the f350 has me questioning if I am holding it down when climbing in the trusses or in tight spaces. The orange trigger doesn't have much tactile feedback so I am pretty cautious of shooting myself with it.
Spyrus is offline
Old 07-17-2015, 10:51 AM   #9
Framer87's Avatar
Trade: Framing
Re: Paslodes
Exactly that, while new. I'd pick the PF350 as well for all the same reasons. However tools don't stay new so for longevity I'd stick with the F350. Here in Canada we can't buy the powerframer new anyways unless the stores still have stock. We were told paslode dropped that line of guns, too bad really cause I liked them while they lasted.
Framer87 is offline
Old 07-17-2015, 04:49 PM   #10
kneeman's Avatar
Trade: Construction
Rewards Points: 12
Re: Paslodes
Thanks for the couple responses.
I knew the f350s was made to last a while wasn't sure about the pf.
Anyone know if the pf gets worse over time?
If they get good longevity then there are some features I'd like more on it.
As for discontinued pf series I haven't read that yet. The paslode site lists the pf and f under the framing nailer category. They don't even list other models, like the 21 degree model, even when you search. So who knows.
kneeman is offline
Old 07-17-2015, 08:56 PM   #11
Framer87's Avatar
Trade: Framing
Re: Paslodes
Looked that up and you're right. Website still shows both nailers. Anyone in Canada still able to buy powerframers? Nobody here caries them anymore. As for longevity I've used f350's problem free for 3+ years. The pf models I've had down within 6 months from new, mostly from abuse though. The F is built stronger and able to handle some slugging while the pf head cannot handle sledge duties. If you're easy on the gun it'll last you years. Also the magnesium housing where the clip mounts by the handle is prone to crack, rendering the gun useless unless you replace entire housing. We've fixed that with a homemade angle bracket coming from the truss hook holder.
Framer87 is offline
Old 07-18-2015, 10:15 PM   #12
gates559's Avatar
Trade: Home Builder
Rewards Points: 100
Re: Paslodes
I use the pf 350s. I have had one start leaking after one house, but that was in an Alberta winter and I was dumping methanol through it to keep it from freezing, so thats probably what did it.
The others have been problem free. I have no problem using them instead of pulling out my stiletto. They have held up great so far.
Paslodes are the standard here, everyone uses them.
gates559 is offline
Old 07-29-2015, 10:20 PM   #13
kneeman's Avatar
Trade: Construction
Rewards Points: 12
Re: Paslodes
Thanks guys. I sold the Bostitch and started using the f350s but I was just given a f350p new 21 degree paslode. Apparently they are just sold in the south right now at Home Depot.
Anybody used one yet?
21 degree nailes are everywhere around, 30s not so much. Wondering about it.
kneeman is offline
Old 08-10-2015, 10:21 PM   #14
kneeman's Avatar
Trade: Construction
Rewards Points: 12
Re: Paslodes
If anyone cares Paslode redid their website and the Power Framers are no longer on there. I guess they did suck.
kneeman is offline
Old 08-10-2015, 11:22 PM   #15
Framer87's Avatar
Trade: Framing
Re: Paslodes
Can still get it from duofast. Think its the df350. Only comes in 21 degree I'm pretty sure.
Framer87 is offline
New cordless paslodes? CJ21 Tools & Equipment 8 12-07-2013 06:44 PM
Good prices on refurbished Paslodes! Sprtman Tools & Equipment 3 09-12-2012 09:23 PM
Are cordless Paslodes reliable? Northwood Tools & Equipment 30 01-26-2010 10:27 PM
Framer and Finish Paslodes, both for $250, New Jersey TBFGhost Contractor Swap 4 02-02-2009 08:38 AM
Paslodes for sale BushWalls Contractor Swap 6 03-20-2006 02:03 PM
