Paslode 6 Vdc Fan - Tools & Equipment - Contractor Talk
Paslode 6 Vdc Fan
Old 12-21-2015, 12:53 PM   #1
music9704's Avatar
Trade: class b contractor
Rewards Points: 591
Paslode 6 Vdc Fan
Has anyone tried to use a regular 6 volt dc fan in any of these guns? I bought one from raido shack and runs ok. I just jumped the wires. The shaft is to short to actually use. It may have ran longer than the original. It cost $4.00 compared to$40. I have the 250 straight trim 16 gauge. The 30 degree framer has the same fan (its like $90.) I know there's a lot of post about these guns, hopefully this isn't a double posting.
music9704 is offline
Old 12-21-2015, 03:21 PM   #2
GettingBy's Avatar
Rewards Points: 6,486
Re: Paslode 6 Vdc Fan
Does your RS fan pull at least as much current as the Paslode fan?
Less current = tool lifetime shortened.
GettingBy is offline
The Following User Says Thank You to GettingBy For This Useful Post:
music9704 (12-22-2015)
Old 12-21-2015, 03:38 PM   #3
music9704's Avatar
Rewards Points: 591
I guess that was part or the question. I can't find any specs on the paslode fan. The fans I've seen have fast or slow speed. It seems the paslode has dual speed. ? I hardly use the trim gun, and I'm definitely not fast. So it's not constant nailing. I like having it tho.
Old 12-21-2015, 03:44 PM   #4
GettingBy's Avatar
What are the diameters and lengths of the Paslode fan motor and your RS motor? Less volume for the RS motor definitely means less power handling.
Motor volume = area x length, area = PI x D squared over 4.
Small motor volume & weight should be a design constraint for Paslode and not so for RS.
Or, can someone with an ammeter & the tool in question or a similar tool help this brutha' out?
Old 12-21-2015, 10:03 PM   #5
music9704's Avatar
Rewards Points: 591
Thank you. You are getting over my head. :what: lol woodbanger here. It's good to know how to figure this. I wish I had more ele. knowledge. The one I had is not as strong. Just thought a non-paslode motor, even the right size might be a lot cheaper. Especially for the framer, it's only sold as a kit for $100. Thats crazy.
Old 12-21-2015, 11:15 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i have purchased guns that don't work just for parts
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
GettingBy (12-22-2015), music9704 (12-22-2015)
Old 12-22-2015, 11:47 AM   #7
music9704's Avatar
Rewards Points: 591
Thanks Tom. I broke down the framing gun to "borrow" the fan; thats how I knew the connections worked. I can't just can't get the blade off. I'm looking for a 250 ii 16 gauge trim, or one that has the same fan. The guns old, so I'll find one, hopefully. To old to spend a lot of $. for now it's back to air.
The Following User Says Thank You to music9704 For This Useful Post:
Tom Struble (12-22-2015)
Old 12-22-2015, 04:17 PM   #8
Trade: siding
Rewards Points: 20
i had the same problem trying to get the fan off too,went thru 3 t6 screwdrivers
music9704 (12-28-2015)
Paslode V Bostitch Finishing Guns hemz Tools & Equipment 27 06-09-2015 11:04 PM
Rebuild of Paslode MU-212-F not right, doesn't shoot a nail, air venting at nose meridian Tools & Equipment 7 05-20-2013 03:46 PM
Paslode 16gauge lith-ion finish nailer SDel Prete Tools & Equipment 4 03-19-2013 04:52 PM
Paslode Angle Trim Nailer Problem. MF Custom Tools & Equipment 3 07-16-2012 10:19 PM
Identify this Paslode Nailgun kb9nvh Carpentry 4 06-25-2012 11:02 PM
